Page 1 of 2
check domoticz with monit and restart when check fails
Posted: Thursday 26 October 2017 20:26
by curious
I installed monit to check my raspberry and particular domoticz because I often have to restart the domoticz service
I use code below in monit config to restart domoticz when "things" go wrong.
The code runs fine only the check fails :
url
http://127.0.0.1:8080/json.htm?type=com ... getversion
and content = '"status" : "OK"'
Does it always have to be 127.0.0.1:8080 or should it be an other ip-address (my domoticz ip for example) ?
check process domoticz with pidfile /var/run/domoticz.pid
start program = "/etc/init.d/domoticz.sh start"
stop program = "/etc/init.d/domoticz.sh stop"
if failed
url http://127.0.0.1:8080/json.htm?type=command¶m=getversion
for 2 cycles
then restart
if 5 restarts within 5 cycles then exec "/sbin/reboot"
if cpu usage > 70% for 3 cycles then restart
I am using Raspberry 2
Re: check domoticz with monit and restart when check fails
Posted: Thursday 26 October 2017 20:53
by jvdz
Posted: Friday 27 October 2017 9:28
by curious
@Jos
I don't know. It's not what is in the downloaded code.
But should 127.0.0.1 be correct ? I can ping this address by the way but when adding portnumber it says host unknown
This is the error message :
connection failed to 127.0.0.1:8080/json.htm?type=command¶m=getversion [HTTP via TCP]
Posted: Friday 27 October 2017 10:45
by mark.sellwood
My monit config contains the following:-
# Monitor Domoticz
if failed
url
for 2 cycles
then restart
In Domoticz on the Settings Tab do you have 127.0.0.1 entered under Local Networks (no username/password): ?
Posted: Friday 27 October 2017 12:00
by curious
I indeed forgot to add the ip-address, but now I did, the errors remains.
'domoticz' failed protocol test [HTTP] at INET[127.0.0.1:8080/json.htm?type=command¶m=getversion] via TCP -- HTTP error: Regular expression doesn't match: No match
Posted: Friday 27 October 2017 12:53
by mark.sellwood
Try replacing 127.0.0.* with 127.0.0.1
Posted: Friday 27 October 2017 14:30
by curious
mark.sellwood wrote: Friday 27 October 2017 12:53
Still the same error
Posted: Friday 27 October 2017 15:01
by mark.sellwood
Are you sure the web interface is running on port 8080?
From another computer on your network what do you get if you enter:-
http://x.x.x.x:8080/json.htm?type=comma ... getversion
Where x.x.x.x is the IP of you Domoticz computer
Posted: Friday 27 October 2017 15:12
by curious
I was pretty sure about that
but checking doesn't harm.
The results are :
"DomoticzUpdateURL" : "
http://www.domoticz.com/download.php?ch ... ine=armv7l",
"HaveUpdate" : false,
"Revision" : 8153,
"SystemName" : "linux",
"build_time" : "2017-07-30 12:19:41",
"hash" : "494fff7",
"status" : "OK",
"title" : "GetVersion",
"version" : "3.8153"
In the file I have this line of code too:
allow 10.0.0.4/10.0.0.255 # allow localhost to connect to the server and
Should I add some other ip-addresses ?
Posted: Friday 27 October 2017 15:50
by mark.sellwood
I don't think the allow statement is correct from memory, I'll have a look at my config when I'm back at home later today.
Posted: Friday 27 October 2017 16:57
by curious
The IP-range of my local network is from 10.0.0.1-10.0.0.255
The code of the 'allow'-part :
set httpd port 2812 and
use address 10.0.0.12 # only accept connection from localhost
allow admin:monit # require user 'admin' with password 'monit'
allow @monit # allow users of group 'monit' to connect (rw)
allow @users readonly # allow users of group 'users' to connect readonly
Posted: Friday 27 October 2017 18:22
by mark.sellwood
My allow is:-
allow 192.168.1.0/24 # allow localhost to connect to the server and
So I think yours should be:-
Did you try the command
This should check your config file & tell you if there are any errors.
Remember to restart monit with
Posted: Friday 27 October 2017 20:27
by curious
After changing the allow- line it seems to work now.
Correct me if I am wrong but the example code is not very clear.
However, thank you for your help.
EDIT : Does not work after al. I forgot to uncomment some lines. And after that the same error-message returned.
Will try to play with some ip adresses in the allow-line.
Syntax is OK
Posted: Friday 27 October 2017 21:30
by mark.sellwood
I think the Wiki needs to be updated as things have changed in monit. I'm rebuilding my systems at present & I know I had to change my existing config as it didnt work.
Below is my config for the webserver bit
Configure Webservice
use address 127.0.0.1 # only accept connection from localhost
Posted: Friday 27 October 2017 21:54
by curious
Still doesn't work and as I am not a script specialist I only can rely on whats in the wiki.
So i am afraid it ends for me here. Monitor runs fine now, and I will keep watching it so now and then to see if there is something special
Posted: Monday 18 June 2018 19:06
by Andyf66
The monitor check seems to be failing at the moment on raspberry pi due to the '&' in the URL, which isn't being escaped and breaks syntax. I fixed it by changing the monitrc file to look like this:
if failed host 127.0.0.1 port 80 protocol http
and request "/json.htm?type=command¶m=getversion"
for 2 cycles
then restart
Posted: Monday 18 June 2018 19:48
by jake
Sometimes Domoticz is acting weird with the & sign in the url.
You can try a quick work-around as I have successfully done as well in this topic:
viewtopic.php?p=170057#p170057
Simply put the 'param=...' part of the url in a different order, in such a way that & isn't followed by 'p'. For the JSON command it doesn't make a difference, but it will gve you the right hyperlink without breaking it up or adding funny characters in between.
So change line 1 into line 2 to try:
http://127.0.0.1:8080/json.htm?param=ge ... pe=command
I would recommond to keep for the rest the original script. In your version you're not checking for the Status = OK version, so I wonder what the script checks at the moment.
Posted: Monday 18 June 2018 19:55
by waaren
I check my domoticz instance using this monit check:
# Check domoticz
check process Domoticz with pidfile /var/run/domoticz.pid
if not exist for 8 cycles then restart # 8 minutes
if failed
url http://192.168.192.nn:nnnn/json.htm?type=command¶m=getversion # comment
if memory usage > 80% then restart
if 5 restarts within 5 cycles then alert
alert [email protected]
the availability of the system itself and port 80 is checked from another system with.
# Check PI's using ping / port
check host PI-1 address PI-1
if failed ping then alert
if failed port 80 protocol http then alert
alert [email protected] with reminder on 10 cycles
check host PI-2 address PI-2
# if failed port 80 protocol http then alert # test system
check host PI-3 address PI-3
# if failed port 80 protocol http then alert # development system
#end
Posted: Thursday 09 August 2018 19:29
by Theedoek
I have the exact same thing but can't get it to work.
When I execute "
http://192.168.0.100:8080/json.htm?type ... getversion" from a remote host (PC running Win10) on the same network, I get a reply containing a JSON array with data like the Domoticz version number, update url and so on.
If I execute "curl
http://127.0.0.1:8080/json.htm?type=com ... getversion" from the command line (via putty), I get a
I have added 127.0.0.1 to the local networks list. Before I did that I used to get an access denied message.
What can be wrong here? I am dying to get this sorted out, but I am not a guru in this
Posted: Thursday 09 August 2018 20:24
by waaren
You could try with
curl -s -X GET "http://127.0.0.1:8080/json.htm?type=command¶m=getversion"
