what is wrong with this script?
tiga
Post by tiga »
i combined some scripts together to make this function:
when i measure a windgust >6m/s(cpnj wind) it puts on a dummyswitch ('windvlaag >6m/s 15 min').
when it is not updated to on for more than 15 minutes....then it should go to off.
t1 = os.time()
s = otherdevices_lastupdate['windvlaag >6m/s 15 min']
year = string.sub(s, 1, 4)
month = string.sub(s, 6, 7)
day = string.sub(s, 9, 10)
hour = string.sub(s, 12, 13)
difference = (os.difftime (t1, t2))
if devicechanged['cpnj wind'] then
--Windmeter data:
sWindDirectionDegrees, sWindDirection, sWindSpeed, sWindGust, sWindTemperature, sWindFeel = otherdevices_svalues['cpnj wind']:match("([^;]+);([^;]+);([^;]+);([^;]+);([^;]+);([^;]+)")
sWindDirectionDegrees = tonumber(sWindDirectionDegrees);
sWindDirection = (sWindDirection);
sWindSpeed = tonumber(sWindSpeed);
sWindGust = tonumber(sWindGust);
sWindTemperature = tonumber(sWindTemperature);
sWindFeel = tonumber(sWindFeel);
print("Windmeter: Winddirection (in degrees) is: " .. sWindDirectionDegrees .. " ");
print("Windmeter: Winddirection is: " .. sWindDirection .. " ");
print("Windmeter: Windspeed is: " .. sWindSpeed .. " ");
print("Windmeter: Windgust is: " .. sWindGust .. " ");
print("Windmeter: Windtemperature is: " .. sWindTemperature .. " ");
print("Windmeter: Windfeel is: " .. sWindFeel .. " ");
if sWindGust > 60 then
    commandArray['windvlaag >6m/s 15 min']='On'
if (otherdevices['windvlaag >6m/s 15 min'] == 'On' and difference > 900) then
    commandArray['windvlaag >6m/s 15 min']='Off'
but this is what i see in my log:
2017-10-25 22:01:46.949 Error: EventSystem: in >15m/s_test: [string "t1 = os.time()..."]:38: attempt to compare number with nil
what is wrong with this code?
i run this script in the 'all' mode
Wolfgang
Re: what is wrong with this script?
Post by Wolfgang »
Hi ,
are you sure that the variable sWindGust has really content in it ?
'nil' is an empty content.
tiga
Post by tiga »
i think i have fixed the problem...
this is how it looks now:
t1 = os.time()
-- returns a date time like 2013-07-11 17:23:12
--Windmeter data:
--print("Windmeter: Winddirection (in degrees) is: " .. sWindDirectionDegrees .. " ");
--print("Windmeter: Winddirection is: " .. sWindDirection .. " ");
--print("Windmeter: Windspeed is: " .. sWindSpeed .. " ");
--print("Windmeter: Windgust is: " .. sWindGust .. " ");
--print("Windmeter: Windtemperature is: " .. sWindTemperature .. " ");
--print("Windmeter: Windfeel is: " .. sWindFeel .. " ");
    print("Windmeter:windvlaag > dan 6m/s, timer in werking voor 15 minuten")
i have moved the "end" a little bit and run it on "device"
tiga
Post by tiga »
now i am ficing an other problem.if the last time 'windvlaag >6m/s 15 min' was triggert...lets say yesterday...
if the script gets triggert today, the condition "difference > 900" is immediately true so 'windvlaag >6m/s 15 min' is turnd off directly.
is it possible to get the last "On" update time from a device???that would fix the problem.
i attempted: s = otherdevices_lastupdate['windvlaag >6m/s 15 min']=='On' but that doesn't work
DutchHans
Post by DutchHans »
Instead of >900 make it >900 and <930 than it only fires once.
Cheers, Hans
tiga
Post by tiga »
thanks hans that could do the trick.
i have changed the script a little bit and i think i have got it.
--Windmeter data:
if (otherdevices['windvlaag >6m/s 15 min']=='On') then
    t1 = os.time()
    --print ("last update:"..tostring(s))
if (otherdevices['windvlaag >6m/s 15 min']=='On' and difference > 900) then
i need to test it a little bit but i thinks this works
