Xiaomi Gateway on Synology
Posted: Sunday 22 October 2017 18:33
Version: Domoticz Stable V3.8153 for DSM 6.1
Platform: Synology DS413J
I have some problems about running the Xiaomi Gateway on Domoticz installed on my Synology DS413J.
Indeed, the Gateway does not appear in the list of devices.
I followed this tutorial: https://www.domoticz.com/wiki/Xiaomi_Gateway_(Aqara)
You will find my log below:
I also tried to install Domoticz on my PC (Windows) and everything works fine. The Gateway is recognized immediately.
Here are the logs I get with Domoticz installed on Windows:
So i don't understand why it don't work on the Synology.
Comparing the two logs I have the impression that on Synology, Domoticz attributes another IP to the Gateway. I do not know if the worry comes from that. (The log says: "Using 192.168.1.19 for local IP address.").
Can someone help me?
Thanking you in advance.
2017-10-21 16:05:04.148 New sensors allowed for 5 minutes...
2017-10-21 16:05:18.265 XiaomiGateway: will listen on 9898 for hardware id 2
2017-10-21 16:05:18.266 XiaomiGateway: Delaying worker startup...
2017-10-21 16:05:23.282 XiaomiGateway: Worker started...
2017-10-21 16:05:23.283 XiaomiGateway: Using 192.168.1.19 for local IP address. Here are the logs I get with Domoticz installed on Windows:
2017-10-21 13:49:36.980 New sensors allowed for 5 minutes...
2017-10-21 13:49:43.941 XiaomiGateway: will listen on 9898 for hardware id 2
2017-10-21 13:49:43.941 XiaomiGateway: Delaying worker startup...
2017-10-21 13:49:48.943 XiaomiGateway: Worker started...
2017-10-21 13:49:55.226 XiaomiGateway: New Switch Device Found (016d6b47)
2017-10-21 13:49:55.243 (Test) Light/Switch (Unknown)
2017-10-21 13:49:55.268 (Test) General/Voltage (Xiaomi Voltage)
2017-10-21 13:49:59.905 XiaomiGateway: New Gateway Found (0088ce01/Xiaomi RGB Gateway)
2017-10-21 13:49:59.916 (Test) Lighting Limitless/Applamp (Unknown)
2017-10-21 13:49:59.920 XiaomiGateway: New Switch Device Found (0088ce01)
2017-10-21 13:49:59.933 (Test) Lux (Xiaomi Gateway Lux)
2017-10-21 13:49:59.944 (Test) Light/Switch (Unknown)
2017-10-21 13:49:59.952 XiaomiGateway: New Switch Device Found (0088ce01)
2017-10-21 13:49:59.963 (Test) Light/Switch (Unknown)
2017-10-21 13:49:59.971 XiaomiGateway: New Switch Device Found (0088ce01)
2017-10-21 13:49:59.983 (Test) Light/Switch (Unknown)
2017-10-21 13:49:59.990 XiaomiGateway: New Switch Device Found (0088ce01)
2017-10-21 13:50:00.002 (Test) Light/Switch (Unknown)
2017-10-21 13:50:00.009 XiaomiGateway: New Switch Device Found (0088ce01)
2017-10-21 13:50:00.021 (Test) Light/Switch (Unknown)
2017-10-21 13:50:00.359 (Test) Lux (Xiaomi Gateway Lux)
2017-10-21 13:50:00.917 (Test) Lux (Xiaomi Gateway Lux)
2017-10-21 13:50:01.335 (Test) Lux (Xiaomi Gateway Lux)
2017-10-21 13:51:33.730 (Test) Lighting Limitless/Applamp (Xiaomi RGB Gateway)
2017-10-21 13:51:33.737 (Test) Lux (Xiaomi Gateway Lux)
2017-10-21 13:51:34.917 (Test) Lighting Limitless/Applamp (Xiaomi RGB Gateway)
2017-10-21 13:51:34.925 (Test) Lux (Xiaomi Gateway Lux)
2017-10-21 13:51:35.116 (Test) Lux (Xiaomi Gateway Lux)
2017-10-21 13:51:37.069 (Test) Lux (Xiaomi Gateway Lux)
2017-10-21 13:51:37.871 (Test) Lux (Xiaomi Gateway Lux)
2017-10-21 13:52:23.943 (Test) Lighting Limitless/Applamp (Xiaomi RGB Gateway)
2017-10-21 13:52:23.949 (Test) Lux (Xiaomi Gateway Lux)
2017-10-21 13:52:24.663 (Test) Lighting Limitless/Applamp (Xiaomi RGB Gateway)
2017-10-21 13:52:24.670 (Test) Lux (Xiaomi Gateway Lux)
2017-10-21 13:52:24.940 (Test) Lighting Limitless/Applamp (Xiaomi RGB Gateway)
2017-10-21 13:52:24.947 (Test) Lux (Xiaomi Gateway Lux)
2017-10-21 13:52:25.644 (Test) Lux (Xiaomi Gateway Lux)
2017-10-21 13:52:42.562 (Test) Lighting Limitless/Applamp (Xiaomi RGB Gateway)
2017-10-21 13:52:42.569 (Test) Lux (Xiaomi Gateway Lux)
2017-10-21 13:52:42.945 (Test) Lighting Limitless/Applamp (Xiaomi RGB Gateway)
2017-10-21 13:52:42.952 (Test) Lux (Xiaomi Gateway Lux)
2017-10-21 13:52:43.733 (Test) Lighting Limitless/Applamp (Xiaomi RGB Gateway)
2017-10-21 13:52:43.740 (Test) Lux (Xiaomi Gateway Lux)
2017-10-21 13:52:43.887 (Test) Lux (Xiaomi Gateway Lux)
2017-10-21 13:52:44.714 (Test) Lighting Limitless/Applamp (Xiaomi RGB Gateway)
2017-10-21 13:52:44.721 (Test) Lux (Xiaomi Gateway Lux)
2017-10-21 13:52:44.887 (Test) Lighting Limitless/Applamp (Xiaomi RGB Gateway)
2017-10-21 13:52:44.894 (Test) Lux (Xiaomi Gateway Lux)
2017-10-21 13:52:46.560 (Test) Lighting Limitless/Applamp (Xiaomi RGB Gateway)
2017-10-21 13:52:46.575 (Test) Lux (Xiaomi Gateway Lux)
2017-10-21 13:52:47.076 (Test) Lighting Limitless/Applamp (Xiaomi RGB Gateway)
2017-10-21 13:52:47.090 (Test) Lux (Xiaomi Gateway Lux)
2017-10-21 13:52:47.547 (Test) Lighting Limitless/Applamp (Xiaomi RGB Gateway)
2017-10-21 13:52:47.554 (Test) Lux (Xiaomi Gateway Lux)
2017-10-21 13:53:48.603 XiaomiGateway: unhandled model: sensor_motion.aq2
2017-10-21 13:53:55.509 New sensors allowed for 5 minutes...Comparing the two logs I have the impression that on Synology, Domoticz attributes another IP to the Gateway. I do not know if the worry comes from that. (The log says: "Using 192.168.1.19 for local IP address.").
