Xiaomi Gateway on Synology
Dragon548
Post by Dragon548 »
Version: Domoticz Stable V3.8153 for DSM 6.1
Platform: Synology DS413J
I have some problems about running the Xiaomi Gateway on Domoticz installed on my Synology DS413J.
Indeed, the Gateway does not appear in the list of devices.
I followed this tutorial: https://www.domoticz.com/wiki/Xiaomi_Gateway_(Aqara)
You will find my log below:
2017-10-21 16:05:04.148 New sensors allowed for 5 minutes...
2017-10-21 16:05:18.265 XiaomiGateway: will listen on 9898 for hardware id 2
2017-10-21 16:05:18.266 XiaomiGateway: Delaying worker startup...
2017-10-21 16:05:23.282 XiaomiGateway: Worker started...
2017-10-21 16:05:23.283 XiaomiGateway: Using 192.168.1.19 for local IP address.
I also tried to install Domoticz on my PC (Windows) and everything works fine. The Gateway is recognized immediately.
Here are the logs I get with Domoticz installed on Windows:
2017-10-21 13:49:36.980 New sensors allowed for 5 minutes...
2017-10-21 13:49:43.941 XiaomiGateway: will listen on 9898 for hardware id 2
2017-10-21 13:49:43.941 XiaomiGateway: Delaying worker startup...
2017-10-21 13:49:48.943 XiaomiGateway: Worker started...
2017-10-21 13:49:55.226 XiaomiGateway: New Switch Device Found (016d6b47)
2017-10-21 13:49:55.243 (Test) Light/Switch (Unknown)
2017-10-21 13:49:55.268 (Test) General/Voltage (Xiaomi Voltage)
2017-10-21 13:49:59.905 XiaomiGateway: New Gateway Found (0088ce01/Xiaomi RGB Gateway)
2017-10-21 13:49:59.916 (Test) Lighting Limitless/Applamp (Unknown)
2017-10-21 13:49:59.920 XiaomiGateway: New Switch Device Found (0088ce01)
2017-10-21 13:49:59.933 (Test) Lux (Xiaomi Gateway Lux)
2017-10-21 13:49:59.944 (Test) Light/Switch (Unknown)
2017-10-21 13:49:59.952 XiaomiGateway: New Switch Device Found (0088ce01)
2017-10-21 13:49:59.963 (Test) Light/Switch (Unknown)
2017-10-21 13:49:59.971 XiaomiGateway: New Switch Device Found (0088ce01)
2017-10-21 13:49:59.983 (Test) Light/Switch (Unknown)
2017-10-21 13:49:59.990 XiaomiGateway: New Switch Device Found (0088ce01)
2017-10-21 13:50:00.002 (Test) Light/Switch (Unknown)
2017-10-21 13:50:00.009 XiaomiGateway: New Switch Device Found (0088ce01)
2017-10-21 13:50:00.021 (Test) Light/Switch (Unknown)
2017-10-21 13:50:00.359 (Test) Lux (Xiaomi Gateway Lux)
2017-10-21 13:50:00.917 (Test) Lux (Xiaomi Gateway Lux)
2017-10-21 13:50:01.335 (Test) Lux (Xiaomi Gateway Lux)
2017-10-21 13:51:33.730 (Test) Lighting Limitless/Applamp (Xiaomi RGB Gateway)
2017-10-21 13:51:33.737 (Test) Lux (Xiaomi Gateway Lux)
2017-10-21 13:51:34.917 (Test) Lighting Limitless/Applamp (Xiaomi RGB Gateway)
2017-10-21 13:51:34.925 (Test) Lux (Xiaomi Gateway Lux)
2017-10-21 13:51:35.116 (Test) Lux (Xiaomi Gateway Lux)
2017-10-21 13:51:37.069 (Test) Lux (Xiaomi Gateway Lux)
2017-10-21 13:51:37.871 (Test) Lux (Xiaomi Gateway Lux)
2017-10-21 13:52:23.943 (Test) Lighting Limitless/Applamp (Xiaomi RGB Gateway)
2017-10-21 13:52:23.949 (Test) Lux (Xiaomi Gateway Lux)
2017-10-21 13:52:24.663 (Test) Lighting Limitless/Applamp (Xiaomi RGB Gateway)
2017-10-21 13:52:24.670 (Test) Lux (Xiaomi Gateway Lux)
2017-10-21 13:52:24.940 (Test) Lighting Limitless/Applamp (Xiaomi RGB Gateway)
2017-10-21 13:52:24.947 (Test) Lux (Xiaomi Gateway Lux)
2017-10-21 13:52:25.644 (Test) Lux (Xiaomi Gateway Lux)
2017-10-21 13:52:42.562 (Test) Lighting Limitless/Applamp (Xiaomi RGB Gateway)
2017-10-21 13:52:42.569 (Test) Lux (Xiaomi Gateway Lux)
2017-10-21 13:52:42.945 (Test) Lighting Limitless/Applamp (Xiaomi RGB Gateway)
2017-10-21 13:52:42.952 (Test) Lux (Xiaomi Gateway Lux)
2017-10-21 13:52:43.733 (Test) Lighting Limitless/Applamp (Xiaomi RGB Gateway)
2017-10-21 13:52:43.740 (Test) Lux (Xiaomi Gateway Lux)
2017-10-21 13:52:43.887 (Test) Lux (Xiaomi Gateway Lux)
2017-10-21 13:52:44.714 (Test) Lighting Limitless/Applamp (Xiaomi RGB Gateway)
2017-10-21 13:52:44.721 (Test) Lux (Xiaomi Gateway Lux)
2017-10-21 13:52:44.887 (Test) Lighting Limitless/Applamp (Xiaomi RGB Gateway)
2017-10-21 13:52:44.894 (Test) Lux (Xiaomi Gateway Lux)
2017-10-21 13:52:46.560 (Test) Lighting Limitless/Applamp (Xiaomi RGB Gateway)
2017-10-21 13:52:46.575 (Test) Lux (Xiaomi Gateway Lux)
2017-10-21 13:52:47.076 (Test) Lighting Limitless/Applamp (Xiaomi RGB Gateway)
2017-10-21 13:52:47.090 (Test) Lux (Xiaomi Gateway Lux)
2017-10-21 13:52:47.547 (Test) Lighting Limitless/Applamp (Xiaomi RGB Gateway)
2017-10-21 13:52:47.554 (Test) Lux (Xiaomi Gateway Lux)
2017-10-21 13:53:48.603 XiaomiGateway: unhandled model: sensor_motion.aq2
2017-10-21 13:53:55.509 New sensors allowed for 5 minutes...
So i don't understand why it don't work on the Synology.
Comparing the two logs I have the impression that on Synology, Domoticz attributes another IP to the Gateway. I do not know if the worry comes from that. (The log says: "Using 192.168.1.19 for local IP address.").
Can someone help me?
Thanking you in advance.
pvm
Domoticz version: 4.10538
Re: Xiaomi Gateway on Synology
Post by pvm »
Are your synology, windows machine and gateway on same subnet 192.168.1.xxx?
Dragon548
Post by Dragon548 »
Yes there are on the same subnet.
The synology is 192.168.1.19
The Gateway is 192.168.1.2
Thanks to your analyse I realize that the Ip that Domoticz gives for the gateway corresponds to the ip of the Synology.
How to fix this?
pvm
Post by pvm »
I'm not an expert, but I understood (from another thread) the IP adres should be of you Domoticz machine, so that should be fine.
I also run Domoticz on my Synology, checked my logs, look identical but is followed by detecting the devices
Dragon548
Post by Dragon548 »
Thanks for your answer.
If it's working for you with the same configuration i don't know where can my problem come from?
AiROnE
Post by AiROnE »
Edit: My apologize ! I just add port 9898 in Syno Firewall and it work directly !!!!
I got the same issue on my system. Brand new Xiaomy Gateway updated to v149 (2.3.7)
My Domoticz is on Xpenology DSM 6.1, last jadahl version ( Was on Stable but try beta too) and same error for me :
2017-10-30 19:22:01.910 XiaomiGateway: will listen on 9898 for hardware id 5
2017-10-30 19:22:01.910 XiaomiGateway: Delaying worker startup...
2017-10-30 19:22:06.910 XiaomiGateway: Worker started...
2017-10-30 19:22:06.910 XiaomiGateway: Using 192.168.0.150 for local IP address.
192.168.0.150 is my Syno/domo IP.
Try with port 54321 also ... not worked . I nmap port 9898 on gateway and it's open.
Please help us :cry:
Dragon548
Post by Dragon548 »
AiROnE is right !
It works fine with 9898 UDP open in Syno Firewall !
Thanks a lot !
EDIT : I speek to fast... All the devices are correctly recognized.
I don't see the motion sensor.
Does somebody have an idea ?
