dzVents has me stumped - simple logic switch on/off
Posted: Sunday 22 October 2017 18:18
by rjblake
I've just take a look at using dzVents; but I'm missing something in my logic of how it works. For example, I'm trying to create a simple script to turn on a switch 10 minutes after sunset and turn off 10 minutes before sunrise. I think I have it working as 2 separate scripts; but surely I can create the logic in a single script? I'm sure it can be done; but for some reason my brain is malfunctioning today...Any tips?
Switch ON
active = true,
timer = {
'10 minutes after sunset',
execute = function(domoticz, devices)
domoticz.devices('Switch [WS01]').switchOn().checkFirst()
Switch OFF
active = true,
timer = {
'10 minutes before sunrise',
domoticz.devices('Switch [WS01]').switchOff().checkFirst()
Re: dzVents has me stumped - simple logic switch on/off
Posted: Sunday 22 October 2017 18:53
by emme
since sunrise and sunset are in the morning and in the afternoon, I would use AM or PM from the time/date object?
mine is just a guess....
ciao
M
active = true,
timer = {
if os.date("%p") == 'AM' then --sunrise
Posted: Sunday 22 October 2017 20:51
by rjblake
emme wrote: Sunday 22 October 2017 18:53
ciao
M
active = true,
timer = {
Thanks for that - In the end, I think I've not gotten my brain back in gear some. I've applied the following code (tested based on 'at 19:00' type logic) which is working
active = true,
timer = {
execute = function(domoticz, myDevice, triggerInfo)
local myDevice = domoticz.devices('Switch [WS01]')
if (triggerInfo.trigger == '10 minutes after sunset') then
myDevice.switchOn().checkFirst()
elseif (triggerInfo.trigger == '10 minutes before sunrise') then
myDevice.switchOff().checkFirst()
Posted: Monday 23 October 2017 8:53
by dannybloe
Yes, the last one is how you 'should' do it. That's what the triggerInfo was intended for.
Posted: Monday 23 October 2017 9:18
by emme
uh... trigger info.....
...my fault
Posted: Monday 23 October 2017 20:13
by rjblake
dannybloe wrote: Monday 23 October 2017 8:53
Yeah - finally got a better understanding of your dzVents (at least a basic level). Thanks for creating this awesome addition - now to look to convert my other LUA, PHP and Python scripts all to dzVents - nice winter project!
Posted: Monday 23 October 2017 21:52
by dannybloe
Good luck and let’s make it ours. Not just mine.
