dzVents has me stumped - simple logic switch on/off
rjblake
Post by rjblake »
I've just take a look at using dzVents; but I'm missing something in my logic of how it works. For example, I'm trying to create a simple script to turn on a switch 10 minutes after sunset and turn off 10 minutes before sunrise. I think I have it working as 2 separate scripts; but surely I can create the logic in a single script? I'm sure it can be done; but for some reason my brain is malfunctioning today...Any tips?
Switch ON
    active = true,
        timer = {
            '10 minutes after sunset',
    execute = function(domoticz, devices)
            domoticz.devices('Switch [WS01]').switchOn().checkFirst()
Switch OFF
    active = true,
        timer = {
            '10 minutes before sunrise',
            domoticz.devices('Switch [WS01]').switchOff().checkFirst()
emme
Domoticz version: latest
Re: dzVents has me stumped - simple logic switch on/off
Post by emme »
since sunrise and sunset are in the morning and in the afternoon, I would use AM or PM from the time/date object?
mine is just a guess.... :P
ciao
M
    active = true,
        timer = {
            if os.date("%p") == 'AM' then  --sunrise
"We always done this way"
rjblake
Post by rjblake »
emme wrote: Sunday 22 October 2017 18:53 since sunrise and sunset are in the morning and in the afternoon, I would use AM or PM from the time/date object?
ciao
M
    active = true,
        timer = {
Thanks for that - In the end, I think I've not gotten my brain back in gear some. I've applied the following code (tested based on 'at 19:00' type logic) which is working
	active = true,
	    timer = {
	execute = function(domoticz, myDevice, triggerInfo)
		local myDevice = domoticz.devices('Switch [WS01]')
		if (triggerInfo.trigger == '10 minutes after sunset') then
		    myDevice.switchOn().checkFirst()
		elseif  (triggerInfo.trigger == '10 minutes before sunrise') then
		    myDevice.switchOff().checkFirst()
dannybloe
Post by dannybloe »
Yes, the last one is how you 'should' do it. That's what the triggerInfo was intended for.
emme
Post by emme »
uh... trigger info.....
...my fault :P :P
rjblake
Post by rjblake »
dannybloe wrote: Monday 23 October 2017 8:53 Yes, the last one is how you 'should' do it. That's what the triggerInfo was intended for.
Yeah - finally got a better understanding of your dzVents (at least a basic level). Thanks for creating this awesome addition - now to look to convert my other LUA, PHP and Python scripts all to dzVents - nice winter project!
dannybloe
Post by dannybloe »
Good luck and let’s make it ours. Not just mine.
