Dummy Switch wont update as wanted
mrox
Post by mrox »
i have a door switch that gives 1 or 0. I get the data from an API. For any reason my code below does not work as expected:
If value from door switch API = 1 and dummy switch == on, then set dummy switch Off
If value from door switch API = 0 and dummy switch == off, then set dummy switch On
   if (tuergartenhaus == '1' and otherdevices['Tür Gartenhaus'] == 'On') then
        commandArray['Tür Gartenhaus'] = 'Off'
    if (tuergartenhaus == '0' and otherdevices['Tür Gartenhaus'] == 'Off') then
        commandArray['Tür Gartenhaus'] = 'On'
I guess it must be something stupid, but i cant get it to work.
jvdz
Domoticz version: 4.107
Re: Dummy Switch wont update as wanted
Post by jvdz »
What type of device is the tuergartenhaus actually and does it really contain a string '1' or maybe rather have a value 1?
Jos
mrox
Post by mrox »
Sorry for not beeing that precise! Here is the full code.
now=os.date("*t")
if now.min % 1 == 0 then
   local stringTuerGartenhaus = assert(io.popen("curl -s http://10.168.2.60:8088/rest/devices/Tuerrkontakt/attributes/Tuer1/value" , 'r'))
   local tuergartenhaus = stringTuerGartenhaus:read('*all')
    print("Tuer Gartenhaus: "..tuergartenhaus)
This is in my log:
2017-10-22 09:47:38.912 dzVents: Tuer Gartenhaus: 1
Users browsing this forum: Ahrefs [Bot] and 1 guest
