error with domoticz.variables
bigpea
Post by bigpea »
I have one problem with the instruction "domoticz.variables".
I take the value of one variable with the instrunction:
allPromemoria = domoticz.variables('listaPromemoria').value
domoticz.log('allPromemoria: '..allPromemoria..'/', domoticz.LOG_DEBUG)
and the result is correct:
startTextmy NoteendTextstartData2017-10-18 16:14:00endData
after that, I execute the script and, at the end, I cancel the value in the user variable with this instruction:
domoticz.variables('listaPromemoria').set('')
In the User Variable section of domoticz I can see that the value has been deleted:
But at the next run of the script the log of the variable report the same value:
In the user variable section the value is empty.
If I restart the raspberry all works fine until I insert new value in this variable.
Do you have any idea?
Thanks.
dannybloe
Re: error with domoticz.variables
Post by dannybloe »
Ah, good catch. Indeed that's a bug.. Setting an empty string doesn't update the internal value caches. We'll fix it.
bigpea
Post by bigpea »
Thanks. I solved, waiting the fix, setting it with a fake string.
bigpea
Post by bigpea »
One question, the lenght of the text (string type) in the domoticz.variables, have a max number of char?
I have some problem when I try to insert one String.
jvandenbroek
Post by jvandenbroek »
bigpea wrote: Thursday 19 October 2017 21:00 One question, the lenght of the text (string type) in the domoticz.variables, have a max number of char?
The limit is set to max 200 chars. Fix for this one (empty value) is coming soon ;)
bigpea
Post by bigpea »
Ok thanks.
