Door open blockly troubles
Mace
Domoticz version: 3.8153
Post by Mace »
Trying to get the following working: If the front door is open for longer then 1 minute, play a sound thru the Xiaomi gateway en send an alert.
These are my blockly's:
Set door open.PNG (11.21 KiB) Viewed 3697 times
As I don't want an alert everytime the door is opened for a short time, I first set a trigger when the door is open for a longer period (for test sake 10 seconds).
If I just use this script, the 'Door open switch' is triggered after 10 seconds.
Then the actual action :
Door open.PNG (52.94 KiB) Viewed 3697 times
I get a notification that the door is open, but the 'Door open switch' doesn't get triggered anymore, I see that the Xiaomi Gateway Doorbell is triggered, but get no sound. I do get the notification that the door is open, but not that it is closed again when I close the testdoor again.
Doing something wrong, but what?
Mace
Re: Door open blockly troubles
Post by Mace »
No one a clue?
Amsterdam020
Domoticz version: 3.5629
Post by Amsterdam020 »
In the test you set the door open switch.
If door open set door open switch.
In your second script you have...
If door sensor open AND switch open.
THEN
This situation does not exist because you do not set the switch to open like in the first working script.
I am not an expert. Hope it helps
Rp3, youlesss, rfxcom, philips hue, dsb1820
Mace
Post by Mace »
Thanks! Totally looked over that. Removed the "Door sensor Test'= open from the second script, now it works!
Slinkos
Domoticz version: 3.4834
Post by Slinkos »
Still this will not work, because the door open switch will be set to 'On' after 10 seconds anyway, even if you close the door before the 10 seconds have passed. Instead you should use a time script.
freijn
Domoticz version: Stable
Post by freijn »
I have done this in Lua. See the Lua GarageDoor example.. in the wiki
Mace
Post by Mace »
@slinkos: Found that out...;) Can you tell me more about a good time script for this?
@freijn: Thanks, I'll look into that!
Slinkos
Post by Slinkos »
Yes, with the GarageDoor example as freijn says. So in your case it would look like this:
-- script_time_dooropen.lua
t1 = os.time()
s = otherdevices_lastupdate['Door open switch']
-- returns a date time like 2013-07-11 17:23:12
year = string.sub(s, 1, 4)
month = string.sub(s, 6, 7)
day = string.sub(s, 9, 10)
hour = string.sub(s, 12, 13)
difference = (os.difftime (t1, t2))
if (otherdevices['Door open switch'] == 'On' and difference > 10 and difference < 20) then
   commandArray['SendNotification']='Door is open#Door is open for more than 10 seconds!'
   print("Door is open")
What this does, is that it compares the last update time of your switch, with the current time. If that is more than 10 seconds, it will send you a notification. The <20 is so that you only get notificated once, because 20/30/40/whatever seconds is also more than 10.
Now there is a problem with this script, because it runs every minute, there's a good chance that by the time it runs, the last update is more than 20 seconds in the past. So you should consider in changing your "less than value" to < 65 seconds, that's the minimum for this to work.
Here's your code that should work:
t1 = os.time()
if (otherdevices['Door open switch'] == 'On' and difference > 10 and difference < 65) then
Slinkos
Post by Slinkos »
Actually, I used your "Door open switch" in my example. But you no longer need to use that switch off course. You should just change that to the name of your door sensor. And maybe replace 'On' with 'Open'.
Mace
Post by Mace »
Thanks for the help! I tested it, but I don't get a message after 60 seconds. Where should this be send to? In the log?
And preferably, I would like it that a switch is actually triggered, so I can work with this switch in Blockly
Slinkos
Post by Slinkos »
should be doing the same as the send notification in yout blocky.
should appear in your domoticz log, do you see that one?
