The learning curve with Domoticz is steep but think I am getting there.
I have an issue with python scripts not firing automatically.
it is saved in the ~/domoticz/scripts/python folder and called script_time_smartplug.py so from my understanding should fire every minute which it is not I can fire the same code either manually from SSH or via a virtual switch.
Any advice on where to start looking is much appreciated.
Python Script not automatically firing
crazynight
- Target OS: -
Domoticz v3.8153 - Rpi
RFLink r48- Arduino Mega Chinese 433 RX TX
2x bye bye Standby Switches
TP-Link HS100
1x DHT11 & 1x ds18B20 connected directly yo the RPi
Nodemcu flashed with ESPEasy
1x ds18B20 connected to the Nodemcu
TP-Link HS100
crazynight
- Target OS: -
Re: Python Script not automatically firing
solved my own issue turns out python is not enabled as standard, found a work around.
TP-Link HS100
TP-Link HS100
DutchHans
Nice that you found a workaround.. maybe tell us how, you might help others too.
Cheers, Hans
Cheers, Hans
crazynight
- Target OS: -
sorry yes the work around was to setup an event like this; seems to fire every minute I expect it not to fire at 00:00 but can live with that.
TP-Link HS100
TP-Link HS100
