dzVents constantly restarts 'EventSystem' and OpenZWave
Posted: Tuesday 03 October 2017 14:23
With dzVents enabled the 'EventSystem' is restarted every 3 minutes and the scripts re-written, OpenZWave is also restarted on a similar frequency - with dzVents disabled neither of these things happen. I'm certain this wasn't the case a few weeks ago, but I'm noticing more and more basic timer tasks (eg. light off at sunrise) not working consistently/being missed.
However what led me to investigate this is that swithOn().forMins(10) doesn't seem to work, the switch on occurs, but the device is never switched off.
Log samples are below - is this normal behaviour or do I have a problem with my set-up somewhere??
and OpenZWave:
2017-10-01 08:40:07.249 EventSystem: reset all events...
2017-10-01 08:40:07.250 EventSystem: Write file: /config/scripts/dzVents/generated_scripts/WirelessSwitch.lua
2017-10-01 08:40:07.250 EventSystem: Write file: /config/scripts/dzVents/generated_scripts/lts_hallpir_on.lua
2017-10-01 08:40:07.251 EventSystem: Write file: /config/scripts/dzVents/generated_scripts/lts_k+d_nightautooff.lua
2017-10-01 08:40:07.251 EventSystem: Write file: /config/scripts/dzVents/generated_scripts/status_someonehome.lua
2017-10-01 08:40:07.251 EventSystem: Write file: /config/scripts/dzVents/generated_scripts/lts_k+d_S2.lua
2017-10-01 08:40:07.252 EventSystem: Write file: /config/scripts/dzVents/generated_scripts/UFH.lua
2017-10-01 08:40:07.252 EventSystem: reset all device statuses...
2017-10-01 08:40:07.301 Python EventSystem: Initalizing event module.
2017-10-01 08:40:07.301 EventSystem: Started
2017-10-01 08:40:07.301 EventSystem: Queue thread started...
2017-10-01 08:43:01.037 EventSystem: reset all events...
2017-10-01 08:43:01.038 EventSystem: Write file: /config/scripts/dzVents/generated_scripts/WirelessSwitch.lua
2017-10-01 08:43:01.038 EventSystem: Write file: /config/scripts/dzVents/generated_scripts/lts_hallpir_on.lua
2017-10-01 08:43:01.039 EventSystem: Write file: /config/scripts/dzVents/generated_scripts/lts_k+d_nightautooff.lua
2017-10-01 08:43:01.039 EventSystem: Write file: /config/scripts/dzVents/generated_scripts/status_someonehome.lua
2017-10-01 08:43:01.039 EventSystem: Write file: /config/scripts/dzVents/generated_scripts/lts_k+d_S2.lua
2017-10-01 08:43:01.039 EventSystem: Write file: /config/scripts/dzVents/generated_scripts/UFH.lua
2017-10-01 08:43:08.117 EventSystem: reset all events...
2017-10-01 08:43:08.119 EventSystem: Write file: /config/scripts/dzVents/generated_scripts/WirelessSwitch.lua
2017-10-01 08:43:08.119 EventSystem: Write file: /config/scripts/dzVents/generated_scripts/lts_hallpir_on.lua
2017-10-01 08:43:08.120 EventSystem: Write file: /config/scripts/dzVents/generated_scripts/lts_k+d_nightautooff.lua
2017-10-01 08:43:08.120 EventSystem: Write file: /config/scripts/dzVents/generated_scripts/status_someonehome.lua
2017-10-01 08:43:08.120 EventSystem: Write file: /config/scripts/dzVents/generated_scripts/lts_k+d_S2.lua
2017-10-01 08:43:08.121 EventSystem: Write file: /config/scripts/dzVents/generated_scripts/UFH.lua
2017-10-01 08:43:08.121 EventSystem: reset all device statuses...
2017-10-01 08:43:08.167 Python EventSystem: Initalizing event module.
2017-10-01 08:43:08.167 EventSystem: Queue thread started...
2017-10-01 08:43:08.167 EventSystem: Started
2017-10-01 08:46:01.565 EventSystem: reset all events...
2017-10-01 08:46:01.566 EventSystem: Write file: /config/scripts/dzVents/generated_scripts/WirelessSwitch.lua
2017-10-01 08:46:01.566 EventSystem: Write file: /config/scripts/dzVents/generated_scripts/lts_hallpir_on.lua
2017-10-01 08:46:01.566 EventSystem: Write file: /config/scripts/dzVents/generated_scripts/lts_k+d_nightautooff.lua
2017-10-01 08:46:01.566 EventSystem: Write file: /config/scripts/dzVents/generated_scripts/status_someonehome.lua
2017-10-01 08:46:01.567 EventSystem: Write file: /config/scripts/dzVents/generated_scripts/lts_k+d_S2.lua
2017-10-01 08:46:01.567 EventSystem: Write file: /config/scripts/dzVents/generated_scripts/UFH.lua
2017-10-01 08:46:08.646 EventSystem: reset all events...
2017-10-01 08:46:08.647 EventSystem: Write file: /config/scripts/dzVents/generated_scripts/WirelessSwitch.lua
2017-10-01 08:46:08.649 EventSystem: Write file: /config/scripts/dzVents/generated_scripts/lts_hallpir_on.lua
2017-10-01 08:46:08.649 EventSystem: Write file: /config/scripts/dzVents/generated_scripts/lts_k+d_nightautooff.lua
2017-10-01 08:46:08.650 EventSystem: Write file: /config/scripts/dzVents/generated_scripts/status_someonehome.lua
2017-10-01 08:46:08.651 EventSystem: Write file: /config/scripts/dzVents/generated_scripts/lts_k+d_S2.lua
2017-10-01 08:46:08.651 EventSystem: Write file: /config/scripts/dzVents/generated_scripts/UFH.lua
2017-10-01 08:46:08.652 EventSystem: reset all device statuses...
2017-10-01 08:46:08.701 Python EventSystem: Initalizing event module.
2017-10-01 08:46:08.701 EventSystem: Queue thread started...
2017-10-01 08:46:08.701 EventSystem: StartedCode: Select all
2017-10-01 08:40:02.961 OpenZWave: Value_Added: Node: 6 (0x06), CommandClass: SWITCH MULTILEVEL, Label: Dec, Instance: 1
2017-10-01 08:40:02.961 OpenZWave: Value_Added: Node: 6 (0x06), CommandClass: SWITCH MULTILEVEL, Label: Level, Instance: 1
2017-10-01 08:40:02.961 OpenZWave: Value_Added: Node: 6 (0x06), CommandClass: SWITCH MULTILEVEL, Label: Bright, Instance: 1
2017-10-01 08:40:02.962 OpenZWave: Value_Added: Node: 6 (0x06), CommandClass: SWITCH MULTILEVEL, Label: Dim, Instance: 1
2017-10-01 08:40:02.962 OpenZWave: Value_Added: Node: 6 (0x06), CommandClass: SWITCH MULTILEVEL, Label: Step Size, Instance: 2
2017-10-01 08:40:02.962 OpenZWave: Value_Added: Node: 6 (0x06), CommandClass: SWITCH MULTILEVEL, Label: Inc, Instance: 2
2017-10-01 08:40:02.962 OpenZWave: Value_Added: Node: 6 (0x06), CommandClass: SWITCH MULTILEVEL, Label: Dec, Instance: 2
2017-10-01 08:40:02.962 OpenZWave: Value_Added: Node: 6 (0x06), CommandClass: SWITCH MULTILEVEL, Label: Level, Instance: 2
2017-10-01 08:40:02.962 OpenZWave: Value_Added: Node: 6 (0x06), CommandClass: SWITCH MULTILEVEL, Label: Bright, Instance: 2
2017-10-01 08:40:02.962 OpenZWave: Value_Added: Node: 6 (0x06), CommandClass: SWITCH MULTILEVEL, Label: Dim, Instance: 2
2017-10-01 08:40:02.963 OpenZWave: Value_Added: Node: 6 (0x06), CommandClass: METER, Label: Energy, Instance: 1
2017-10-01 08:40:02.963 OpenZWave: Value_Added: Node: 6 (0x06), CommandClass: METER, Label: Energy, Instance: 2
2017-10-01 08:40:02.963 OpenZWave: Value_Added: Node: 6 (0x06), CommandClass: METER, Label: Power, Instance: 1
2017-10-01 08:40:02.963 OpenZWave: Value_Added: Node: 6 (0x06), CommandClass: METER, Label: Power, Instance: 2
2017-10-01 08:40:02.964 OpenZWave: Value_Added: Node: 6 (0x06), CommandClass: ALARM, Label: Alarm Type, Instance: 1
2017-10-01 08:40:02.964 OpenZWave: Value_Added: Node: 6 (0x06), CommandClass: ALARM, Label: Alarm Level, Instance: 1
2017-10-01 08:40:02.964 OpenZWave: Value_Added: Node: 6 (0x06), CommandClass: ALARM, Label: SourceNodeId, Instance: 1
2017-10-01 08:40:02.964 OpenZWave: Value_Added: Node: 6 (0x06), CommandClass: ALARM, Label: Heat, Instance: 1
2017-10-01 08:40:02.964 OpenZWave: Value_Added: Node: 6 (0x06), CommandClass: ALARM, Label: Power Management, Instance: 1
2017-10-01 08:40:26.757 OpenZWave: Received timeout notification from HomeID: 4248490723, NodeID: 6 (0x06)
2017-10-01 08:40:28.748 OpenZWave: All Nodes queried
2017-10-01 08:43:03.617 OpenZWave: using config in: /var/lib/domoticz/Config/
2017-10-01 08:43:03.620 OpenZWave: Starting...
2017-10-01 08:43:03.620 OpenZWave: Version: 1.4-2754-ge4c265e2-dirty
2017-10-01 08:43:03.834 OpenZWave: Driver Ready
2017-10-01 08:43:03.836 OpenZWave: Value_Added: Node: 3 (0x03), CommandClass: SWITCH MULTILEVEL, Label: Step Size, Instance: 1
2017-10-01 08:43:03.836 OpenZWave: Value_Added: Node: 3 (0x03), CommandClass: SWITCH MULTILEVEL, Label: Inc, Instance: 1
2017-10-01 08:43:03.836 OpenZWave: Value_Added: Node: 3 (0x03), CommandClass: SWITCH MULTILEVEL, Label: Dec, Instance: 1
2017-10-01 08:43:03.836 OpenZWave: Value_Added: Node: 3 (0x03), CommandClass: SWITCH MULTILEVEL, Label: Level, Instance: 1
2017-10-01 08:43:03.836 OpenZWave: Value_Added: Node: 3 (0x03), CommandClass: SWITCH MULTILEVEL, Label: On, Instance: 1
2017-10-01 08:43:03.836 OpenZWave: Value_Added: Node: 3 (0x03), CommandClass: SWITCH MULTILEVEL, Label: Off, Instance: 1
2017-10-01 08:43:03.836 OpenZWave: Value_Added: Node: 3 (0x03), CommandClass: SWITCH MULTILEVEL, Label: Step Size, Instance: 2
2017-10-01 08:43:03.836 OpenZWave: Value_Added: Node: 3 (0x03), CommandClass: SWITCH MULTILEVEL, Label: Inc, Instance: 2
2017-10-01 08:43:03.836 OpenZWave: Value_Added: Node: 3 (0x03), CommandClass: SWITCH MULTILEVEL, Label: Dec, Instance: 2
2017-10-01 08:43:03.836 OpenZWave: Value_Added: Node: 3 (0x03), CommandClass: SWITCH MULTILEVEL, Label: Level, Instance: 2
2017-10-01 08:43:03.837 OpenZWave: Value_Added: Node: 3 (0x03), CommandClass: SWITCH MULTILEVEL, Label: Bright, Instance: 2
2017-10-01 08:43:03.837 OpenZWave: Value_Added: Node: 3 (0x03), CommandClass: SWITCH MULTILEVEL, Label: Dim, Instance: 2
2017-10-01 08:43:03.837 OpenZWave: Value_Added: Node: 3 (0x03), CommandClass: SENSOR MULTILEVEL, Label: Power, Instance: 4
2017-10-01 08:43:03.837 OpenZWave: Value_Added: Node: 3 (0x03), CommandClass: METER, Label: Energy, Instance: 1
2017-10-01 08:43:03.837 OpenZWave: Value_Added: Node: 3 (0x03), CommandClass: METER, Label: Power, Instance: 1
2017-10-01 08:43:03.837 OpenZWave: Value_Added: Node: 3 (0x03), CommandClass: ALARM, Label: Alarm Type, Instance: 1
2017-10-01 08:43:03.837 OpenZWave: Value_Added: Node: 3 (0x03), CommandClass: ALARM, Label: Alarm Level, Instance: 1
2017-10-01 08:43:03.837 OpenZWave: Value_Added: Node: 3 (0x03), CommandClass: ALARM, Label: SourceNodeId, Instance: 1
2017-10-01 08:43:03.837 OpenZWave: Value_Added: Node: 3 (0x03), CommandClass: ALARM, Label: Heat, Instance: 1
2017-10-01 08:43:03.837 OpenZWave: Value_Added: Node: 3 (0x03), CommandClass: ALARM, Label: Power Management, Instance: 1
2017-10-01 08:43:03.838 OpenZWave: Value_Added: Node: 3 (0x03), CommandClass: ALARM, Label: System, Instance: 1
2017-10-01 08:43:03.838 OpenZWave: Value_Added: Node: 4 (0x04), CommandClass: SWITCH MULTILEVEL, Label: Step Size, Instance: 1
2017-10-01 08:43:03.838 OpenZWave: Value_Added: Node: 4 (0x04), CommandClass: SWITCH MULTILEVEL, Label: Inc, Instance: 1
2017-10-01 08:43:03.838 OpenZWave: Value_Added: Node: 4 (0x04), CommandClass: SWITCH MULTILEVEL, Label: Dec, Instance: 1
2017-10-01 08:43:03.838 OpenZWave: Value_Added: Node: 4 (0x04), CommandClass: SWITCH MULTILEVEL, Label: Level, Instance: 1
2017-10-01 08:43:03.838 OpenZWave: Value_Added: Node: 4 (0x04), CommandClass: SWITCH MULTILEVEL, Label: On, Instance: 1
2017-10-01 08:43:03.838 OpenZWave: Value_Added: Node: 4 (0x04), CommandClass: SWITCH MULTILEVEL, Label: Off, Instance: 1
2017-10-01 08:43:03.838 OpenZWave: Value_Added: Node: 4 (0x04), CommandClass: SWITCH MULTILEVEL, Label: Step Size, Instance: 2
2017-10-01 08:43:03.838 OpenZWave: Value_Added: Node: 4 (0x04), CommandClass: SWITCH MULTILEVEL, Label: Inc, Instance: 2
2017-10-01 08:43:03.838 OpenZWave: Value_Added: Node: 4 (0x04), CommandClass: SWITCH MULTILEVEL, Label: Dec, Instance: 2
2017-10-01 08:43:03.838 OpenZWave: Value_Added: Node: 4 (0x04), CommandClass: SWITCH MULTILEVEL, Label: Level, Instance: 2
2017-10-01 08:43:03.838 OpenZWave: Value_Added: Node: 4 (0x04), CommandClass: SWITCH MULTILEVEL, Label: Bright, Instance: 2
2017-10-01 08:43:03.839 OpenZWave: Value_Added: Node: 4 (0x04), CommandClass: SWITCH MULTILEVEL, Label: Dim, Instance: 2
2017-10-01 08:43:03.839 OpenZWave: Value_Added: Node: 4 (0x04), CommandClass: SENSOR MULTILEVEL, Label: Power, Instance: 4
2017-10-01 08:43:03.839 OpenZWave: Value_Added: Node: 4 (0x04), CommandClass: METER, Label: Energy, Instance: 1
2017-10-01 08:43:03.839 OpenZWave: Value_Added: Node: 4 (0x04), CommandClass: METER, Label: Power, Instance: 1
2017-10-01 08:43:03.839 OpenZWave: Value_Added: Node: 4 (0x04), CommandClass: ALARM, Label: Alarm Type, Instance: 1
2017-10-01 08:43:03.839 OpenZWave: Value_Added: Node: 4 (0x04), CommandClass: ALARM, Label: Alarm Level, Instance: 1
2017-10-01 08:43:03.839 OpenZWave: Value_Added: Node: 4 (0x04), CommandClass: ALARM, Label: SourceNodeId, Instance: 1
2017-10-01 08:43:03.839 OpenZWave: Value_Added: Node: 4 (0x04), CommandClass: ALARM, Label: Heat, Instance: 1
2017-10-01 08:43:03.839 OpenZWave: Value_Added: Node: 4 (0x04), CommandClass: ALARM, Label: Power Management, Instance: 1
2017-10-01 08:43:03.839 OpenZWave: Value_Added: Node: 4 (0x04), CommandClass: ALARM, Label: System, Instance: 1
2017-10-01 08:43:03.840 OpenZWave: Value_Added: Node: 6 (0x06), CommandClass: SWITCH BINARY, Label: Switch, Instance: 1
2017-10-01 08:43:03.840 OpenZWave: Value_Added: Node: 6 (0x06), CommandClass: SWITCH BINARY, Label: Switch, Instance: 2
2017-10-01 08:43:03.840 OpenZWave: Value_Added: Node: 6 (0x06), CommandClass: SWITCH MULTILEVEL, Label: Step Size, Instance: 1
2017-10-01 08:43:03.840 OpenZWave: Value_Added: Node: 6 (0x06), CommandClass: SWITCH MULTILEVEL, Label: Inc, Instance: 1
2017-10-01 08:43:03.840 OpenZWave: Value_Added: Node: 6 (0x06), CommandClass: SWITCH MULTILEVEL, Label: Dec, Instance: 1
2017-10-01 08:43:03.840 OpenZWave: Value_Added: Node: 6 (0x06), CommandClass: SWITCH MULTILEVEL, Label: Level, Instance: 1
2017-10-01 08:43:03.840 OpenZWave: Value_Added: Node: 6 (0x06), CommandClass: SWITCH MULTILEVEL, Label: Bright, Instance: 1
2017-10-01 08:43:03.840 OpenZWave: Value_Added: Node: 6 (0x06), CommandClass: SWITCH MULTILEVEL, Label: Dim, Instance: 1
2017-10-01 08:43:03.840 OpenZWave: Value_Added: Node: 6 (0x06), CommandClass: SWITCH MULTILEVEL, Label: Step Size, Instance: 2
2017-10-01 08:43:03.840 OpenZWave: Value_Added: Node: 6 (0x06), CommandClass: SWITCH MULTILEVEL, Label: Inc, Instance: 2
2017-10-01 08:43:03.840 OpenZWave: Value_Added: Node: 6 (0x06), CommandClass: SWITCH MULTILEVEL, Label: Dec, Instance: 2
2017-10-01 08:43:03.840 OpenZWave: Value_Added: Node: 6 (0x06), CommandClass: SWITCH MULTILEVEL, Label: Level, Instance: 2
2017-10-01 08:43:03.841 OpenZWave: Value_Added: Node: 6 (0x06), CommandClass: SWITCH MULTILEVEL, Label: Bright, Instance: 2
2017-10-01 08:43:03.841 OpenZWave: Value_Added: Node: 6 (0x06), CommandClass: SWITCH MULTILEVEL, Label: Dim, Instance: 2
2017-10-01 08:43:03.841 OpenZWave: Value_Added: Node: 6 (0x06), CommandClass: METER, Label: Energy, Instance: 1
2017-10-01 08:43:03.841 OpenZWave: Value_Added: Node: 6 (0x06), CommandClass: METER, Label: Energy, Instance: 2
2017-10-01 08:43:03.841 OpenZWave: Value_Added: Node: 6 (0x06), CommandClass: METER, Label: Power, Instance: 1
2017-10-01 08:43:03.841 OpenZWave: Value_Added: Node: 6 (0x06), CommandClass: METER, Label: Power, Instance: 2
2017-10-01 08:43:03.842 OpenZWave: Value_Added: Node: 6 (0x06), CommandClass: ALARM, Label: Alarm Type, Instance: 1
2017-10-01 08:43:03.842 OpenZWave: Value_Added: Node: 6 (0x06), CommandClass: ALARM, Label: Alarm Level, Instance: 1
2017-10-01 08:43:03.842 OpenZWave: Value_Added: Node: 6 (0x06), CommandClass: ALARM, Label: SourceNodeId, Instance: 1
2017-10-01 08:43:03.842 OpenZWave: Value_Added: Node: 6 (0x06), CommandClass: ALARM, Label: Heat, Instance: 1
2017-10-01 08:43:03.842 OpenZWave: Value_Added: Node: 6 (0x06), CommandClass: ALARM, Label: Power Management, Instance: 1
2017-10-01 08:43:22.117 OpenZWave: Received timeout notification from HomeID: 4248490723, NodeID: 6 (0x06)
2017-10-01 08:43:23.145 OpenZWave: All Nodes queried
2017-10-01 08:46:04.146 OpenZWave: using config in: /var/lib/domoticz/Config/
2017-10-01 08:46:04.147 OpenZWave: Starting...
2017-10-01 08:46:04.148 OpenZWave: Version: 1.4-2754-ge4c265e2-dirty
2017-10-01 08:46:04.348 OpenZWave: Driver Ready
2017-10-01 08:46:04.352 OpenZWave: Value_Added: Node: 3 (0x03), CommandClass: SWITCH MULTILEVEL, Label: Step Size, Instance: 1
2017-10-01 08:46:04.352 OpenZWave: Value_Added: Node: 3 (0x03), CommandClass: SWITCH MULTILEVEL, Label: Inc, Instance: 1
2017-10-01 08:46:04.353 OpenZWave: Value_Added: Node: 3 (0x03), CommandClass: SWITCH MULTILEVEL, Label: Dec, Instance: 1
2017-10-01 08:46:04.353 OpenZWave: Value_Added: Node: 3 (0x03), CommandClass: SWITCH MULTILEVEL, Label: Level, Instance: 1
2017-10-01 08:46:04.353 OpenZWave: Value_Added: Node: 3 (0x03), CommandClass: SWITCH MULTILEVEL, Label: On, Instance: 1
2017-10-01 08:46:04.353 OpenZWave: Value_Added: Node: 3 (0x03), CommandClass: SWITCH MULTILEVEL, Label: Off, Instance: 1
2017-10-01 08:46:04.354 OpenZWave: Value_Added: Node: 3 (0x03), CommandClass: SWITCH MULTILEVEL, Label: Step Size, Instance: 2
2017-10-01 08:46:04.354 OpenZWave: Value_Added: Node: 3 (0x03), CommandClass: SWITCH MULTILEVEL, Label: Inc, Instance: 2
2017-10-01 08:46:04.354 OpenZWave: Value_Added: Node: 3 (0x03), CommandClass: SWITCH MULTILEVEL, Label: Dec, Instance: 2
2017-10-01 08:46:04.354 OpenZWave: Value_Added: Node: 3 (0x03), CommandClass: SWITCH MULTILEVEL, Label: Level, Instance: 2
2017-10-01 08:46:04.354 OpenZWave: Value_Added: Node: 3 (0x03), CommandClass: SWITCH MULTILEVEL, Label: Bright, Instance: 2
2017-10-01 08:46:04.355 OpenZWave: Value_Added: Node: 3 (0x03), CommandClass: SWITCH MULTILEVEL, Label: Dim, Instance: 2
2017-10-01 08:46:04.355 OpenZWave: Value_Added: Node: 3 (0x03), CommandClass: SENSOR MULTILEVEL, Label: Power, Instance: 4
2017-10-01 08:46:04.355 OpenZWave: Value_Added: Node: 3 (0x03), CommandClass: METER, Label: Energy, Instance: 1
2017-10-01 08:46:04.355 OpenZWave: Value_Added: Node: 3 (0x03), CommandClass: METER, Label: Power, Instance: 1
2017-10-01 08:46:04.356 OpenZWave: Value_Added: Node: 3 (0x03), CommandClass: ALARM, Label: Alarm Type, Instance: 1
2017-10-01 08:46:04.356 OpenZWave: Value_Added: Node: 3 (0x03), CommandClass: ALARM, Label: Alarm Level, Instance: 1
2017-10-01 08:46:04.356 OpenZWave: Value_Added: Node: 3 (0x03), CommandClass: ALARM, Label: SourceNodeId, Instance: 1
2017-10-01 08:46:04.356 OpenZWave: Value_Added: Node: 3 (0x03), CommandClass: ALARM, Label: Heat, Instance: 1
2017-10-01 08:46:04.357 OpenZWave: Value_Added: Node: 3 (0x03), CommandClass: ALARM, Label: Power Management, Instance: 1
2017-10-01 08:46:04.357 OpenZWave: Value_Added: Node: 3 (0x03), CommandClass: ALARM, Label: System, Instance: 1
2017-10-01 08:46:04.357 OpenZWave: Value_Added: Node: 4 (0x04), CommandClass: SWITCH MULTILEVEL, Label: Step Size, Instance: 1
2017-10-01 08:46:04.357 OpenZWave: Value_Added: Node: 4 (0x04), CommandClass: SWITCH MULTILEVEL, Label: Inc, Instance: 1
2017-10-01 08:46:04.358 OpenZWave: Value_Added: Node: 4 (0x04), CommandClass: SWITCH MULTILEVEL, Label: Dec, Instance: 1
2017-10-01 08:46:04.358 OpenZWave: Value_Added: Node: 4 (0x04), CommandClass: SWITCH MULTILEVEL, Label: Level, Instance: 1
2017-10-01 08:46:04.358 OpenZWave: Value_Added: Node: 4 (0x04), CommandClass: SWITCH MULTILEVEL, Label: On, Instance: 1
2017-10-01 08:46:04.358 OpenZWave: Value_Added: Node: 4 (0x04), CommandClass: SWITCH MULTILEVEL, Label: Off, Instance: 1
2017-10-01 08:46:04.358 OpenZWave: Value_Added: Node: 4 (0x04), CommandClass: SWITCH MULTILEVEL, Label: Step Size, Instance: 2
2017-10-01 08:46:04.358 OpenZWave: Value_Added: Node: 4 (0x04), CommandClass: SWITCH MULTILEVEL, Label: Inc, Instance: 2
2017-10-01 08:46:04.359 OpenZWave: Value_Added: Node: 4 (0x04), CommandClass: SWITCH MULTILEVEL, Label: Dec, Instance: 2
2017-10-01 08:46:04.359 OpenZWave: Value_Added: Node: 4 (0x04), CommandClass: SWITCH MULTILEVEL, Label: Level, Instance: 2
2017-10-01 08:46:04.359 OpenZWave: Value_Added: Node: 4 (0x04), CommandClass: SWITCH MULTILEVEL, Label: Bright, Instance: 2
2017-10-01 08:46:04.359 OpenZWave: Value_Added: Node: 4 (0x04), CommandClass: SWITCH MULTILEVEL, Label: Dim, Instance: 2
2017-10-01 08:46:04.359 OpenZWave: Value_Added: Node: 4 (0x04), CommandClass: SENSOR MULTILEVEL, Label: Power, Instance: 4
2017-10-01 08:46:04.359 OpenZWave: Value_Added: Node: 4 (0x04), CommandClass: METER, Label: Energy, Instance: 1
2017-10-01 08:46:04.359 OpenZWave: Value_Added: Node: 4 (0x04), CommandClass: METER, Label: Power, Instance: 1
2017-10-01 08:46:04.360 OpenZWave: Value_Added: Node: 4 (0x04), CommandClass: ALARM, Label: Alarm Type, Instance: 1
2017-10-01 08:46:04.360 OpenZWave: Value_Added: Node: 4 (0x04), CommandClass: ALARM, Label: Alarm Level, Instance: 1
2017-10-01 08:46:04.360 OpenZWave: Value_Added: Node: 4 (0x04), CommandClass: ALARM, Label: SourceNodeId, Instance: 1
2017-10-01 08:46:04.360 OpenZWave: Value_Added: Node: 4 (0x04), CommandClass: ALARM, Label: Heat, Instance: 1
2017-10-01 08:46:04.360 OpenZWave: Value_Added: Node: 4 (0x04), CommandClass: ALARM, Label: Power Management, Instance: 1
2017-10-01 08:46:04.361 OpenZWave: Value_Added: Node: 4 (0x04), CommandClass: ALARM, Label: System, Instance: 1
2017-10-01 08:46:04.361 OpenZWave: Value_Added: Node: 6 (0x06), CommandClass: SWITCH BINARY, Label: Switch, Instance: 1
2017-10-01 08:46:04.361 OpenZWave: Value_Added: Node: 6 (0x06), CommandClass: SWITCH BINARY, Label: Switch, Instance: 2
2017-10-01 08:46:04.362 OpenZWave: Value_Added: Node: 6 (0x06), CommandClass: SWITCH MULTILEVEL, Label: Step Size, Instance: 1
2017-10-01 08:46:04.362 OpenZWave: Value_Added: Node: 6 (0x06), CommandClass: SWITCH MULTILEVEL, Label: Inc, Instance: 1
2017-10-01 08:46:04.362 OpenZWave: Value_Added: Node: 6 (0x06), CommandClass: SWITCH MULTILEVEL, Label: Dec, Instance: 1
2017-10-01 08:46:04.362 OpenZWave: Value_Added: Node: 6 (0x06), CommandClass: SWITCH MULTILEVEL, Label: Level, Instance: 1
2017-10-01 08:46:04.362 OpenZWave: Value_Added: Node: 6 (0x06), CommandClass: SWITCH MULTILEVEL, Label: Bright, Instance: 1
2017-10-01 08:46:04.362 OpenZWave: Value_Added: Node: 6 (0x06), CommandClass: SWITCH MULTILEVEL, Label: Dim, Instance: 1
2017-10-01 08:46:04.362 OpenZWave: Value_Added: Node: 6 (0x06), CommandClass: SWITCH MULTILEVEL, Label: Step Size, Instance: 2
2017-10-01 08:46:04.362 OpenZWave: Value_Added: Node: 6 (0x06), CommandClass: SWITCH MULTILEVEL, Label: Inc, Instance: 2
2017-10-01 08:46:04.363 OpenZWave: Value_Added: Node: 6 (0x06), CommandClass: SWITCH MULTILEVEL, Label: Dec, Instance: 2
2017-10-01 08:46:04.363 OpenZWave: Value_Added: Node: 6 (0x06), CommandClass: SWITCH MULTILEVEL, Label: Level, Instance: 2
2017-10-01 08:46:04.363 OpenZWave: Value_Added: Node: 6 (0x06), CommandClass: SWITCH MULTILEVEL, Label: Bright, Instance: 2
2017-10-01 08:46:04.363 OpenZWave: Value_Added: Node: 6 (0x06), CommandClass: SWITCH MULTILEVEL, Label: Dim, Instance: 2
2017-10-01 08:46:04.363 OpenZWave: Value_Added: Node: 6 (0x06), CommandClass: METER, Label: Energy, Instance: 1
2017-10-01 08:46:04.363 OpenZWave: Value_Added: Node: 6 (0x06), CommandClass: METER, Label: Energy, Instance: 2
2017-10-01 08:46:04.363 OpenZWave: Value_Added: Node: 6 (0x06), CommandClass: METER, Label: Power, Instance: 1
2017-10-01 08:46:04.364 OpenZWave: Value_Added: Node: 6 (0x06), CommandClass: METER, Label: Power, Instance: 2
2017-10-01 08:46:04.364 OpenZWave: Value_Added: Node: 6 (0x06), CommandClass: ALARM, Label: Alarm Type, Instance: 1
2017-10-01 08:46:04.364 OpenZWave: Value_Added: Node: 6 (0x06), CommandClass: ALARM, Label: Alarm Level, Instance: 1
2017-10-01 08:46:04.364 OpenZWave: Value_Added: Node: 6 (0x06), CommandClass: ALARM, Label: SourceNodeId, Instance: 1
2017-10-01 08:46:04.364 OpenZWave: Value_Added: Node: 6 (0x06), CommandClass: ALARM, Label: Heat, Instance: 1
2017-10-01 08:46:04.365 OpenZWave: Value_Added: Node: 6 (0x06), CommandClass: ALARM, Label: Power Management, Instance: 1
2017-10-01 08:46:22.348 OpenZWave: Received timeout notification from HomeID: 4248490723, NodeID: 6 (0x06)
2017-10-01 08:46:23.372 OpenZWave: All Nodes queried
2017-10-01 08:49:04.666 OpenZWave: using config in: /var/lib/domoticz/Config/
2017-10-01 08:49:04.667 OpenZWave: Starting...
2017-10-01 08:49:04.667 OpenZWave: Version: 1.4-2754-ge4c265e2-dirty
2017-10-01 08:49:04.863 OpenZWave: Driver Ready
2017-10-01 08:49:04.866 OpenZWave: Value_Added: Node: 3 (0x03), CommandClass: SWITCH MULTILEVEL, Label: Step Size, Instance: 1
2017-10-01 08:49:04.866 OpenZWave: Value_Added: Node: 3 (0x03), CommandClass: SWITCH MULTILEVEL, Label: Inc, Instance: 1
2017-10-01 08:49:04.866 OpenZWave: Value_Added: Node: 3 (0x03), CommandClass: SWITCH MULTILEVEL, Label: Dec, Instance: 1
2017-10-01 08:49:04.867 OpenZWave: Value_Added: Node: 3 (0x03), CommandClass: SWITCH MULTILEVEL, Label: Level, Instance: 1
2017-10-01 08:49:04.867 OpenZWave: Value_Added: Node: 3 (0x03), CommandClass: SWITCH MULTILEVEL, Label: On, Instance: 1
2017-10-01 08:49:04.867 OpenZWave: Value_Added: Node: 3 (0x03), CommandClass: SWITCH MULTILEVEL, Label: Off, Instance: 1
2017-10-01 08:49:04.867 OpenZWave: Value_Added: Node: 3 (0x03), CommandClass: SWITCH MULTILEVEL, Label: Step Size, Instance: 2
2017-10-01 08:49:04.867 OpenZWave: Value_Added: Node: 3 (0x03), CommandClass: SWITCH MULTILEVEL, Label: Inc, Instance: 2
2017-10-01 08:49:04.867 OpenZWave: Value_Added: Node: 3 (0x03), CommandClass: SWITCH MULTILEVEL, Label: Dec, Instance: 2
2017-10-01 08:49:04.867 OpenZWave: Value_Added: Node: 3 (0x03), CommandClass: SWITCH MULTILEVEL, Label: Level, Instance: 2
2017-10-01 08:49:04.867 OpenZWave: Value_Added: Node: 3 (0x03), CommandClass: SWITCH MULTILEVEL, Label: Bright, Instance: 2
2017-10-01 08:49:04.867 OpenZWave: Value_Added: Node: 3 (0x03), CommandClass: SWITCH MULTILEVEL, Label: Dim, Instance: 2
2017-10-01 08:49:04.867 OpenZWave: Value_Added: Node: 3 (0x03), CommandClass: SENSOR MULTILEVEL, Label: Power, Instance: 4
2017-10-01 08:49:04.868 OpenZWave: Value_Added: Node: 3 (0x03), CommandClass: METER, Label: Energy, Instance: 1
2017-10-01 08:49:04.868 OpenZWave: Value_Added: Node: 3 (0x03), CommandClass: METER, Label: Power, Instance: 1
2017-10-01 08:49:04.868 OpenZWave: Value_Added: Node: 3 (0x03), CommandClass: ALARM, Label: Alarm Type, Instance: 1
2017-10-01 08:49:04.868 OpenZWave: Value_Added: Node: 3 (0x03), CommandClass: ALARM, Label: Alarm Level, Instance: 1
2017-10-01 08:49:04.868 OpenZWave: Value_Added: Node: 3 (0x03), CommandClass: ALARM, Label: SourceNodeId, Instance: 1
2017-10-01 08:49:04.868 OpenZWave: Value_Added: Node: 3 (0x03), CommandClass: ALARM, Label: Heat, Instance: 1
2017-10-01 08:49:04.868 OpenZWave: Value_Added: Node: 3 (0x03), CommandClass: ALARM, Label: Power Management, Instance: 1
2017-10-01 08:49:04.868 OpenZWave: Value_Added: Node: 3 (0x03), CommandClass: ALARM, Label: System, Instance: 1
2017-10-01 08:49:04.869 OpenZWave: Value_Added: Node: 4 (0x04), CommandClass: SWITCH MULTILEVEL, Label: Step Size, Instance: 1
2017-10-01 08:49:04.869 OpenZWave: Value_Added: Node: 4 (0x04), CommandClass: SWITCH MULTILEVEL, Label: Inc, Instance: 1
2017-10-01 08:49:04.869 OpenZWave: Value_Added: Node: 4 (0x04), CommandClass: SWITCH MULTILEVEL, Label: Dec, Instance: 1
2017-10-01 08:49:04.869 OpenZWave: Value_Added: Node: 4 (0x04), CommandClass: SWITCH MULTILEVEL, Label: Level, Instance: 1
2017-10-01 08:49:04.869 OpenZWave: Value_Added: Node: 4 (0x04), CommandClass: SWITCH MULTILEVEL, Label: On, Instance: 1
2017-10-01 08:49:04.869 OpenZWave: Value_Added: Node: 4 (0x04), CommandClass: SWITCH MULTILEVEL, Label: Off, Instance: 1
2017-10-01 08:49:04.869 OpenZWave: Value_Added: Node: 4 (0x04), CommandClass: SWITCH MULTILEVEL, Label: Step Size, Instance: 2
2017-10-01 08:49:04.869 OpenZWave: Value_Added: Node: 4 (0x04), CommandClass: SWITCH MULTILEVEL, Label: Inc, Instance: 2
2017-10-01 08:49:04.869 OpenZWave: Value_Added: Node: 4 (0x04), CommandClass: SWITCH MULTILEVEL, Label: Dec, Instance: 2
2017-10-01 08:49:04.869 OpenZWave: Value_Added: Node: 4 (0x04), CommandClass: SWITCH MULTILEVEL, Label: Level, Instance: 2
2017-10-01 08:49:04.870 OpenZWave: Value_Added: Node: 4 (0x04), CommandClass: SWITCH MULTILEVEL, Label: Bright, Instance: 2
2017-10-01 08:49:04.870 OpenZWave: Value_Added: Node: 4 (0x04), CommandClass: SWITCH MULTILEVEL, Label: Dim, Instance: 2
2017-10-01 08:49:04.870 OpenZWave: Value_Added: Node: 4 (0x04), CommandClass: SENSOR MULTILEVEL, Label: Power, Instance: 4
2017-10-01 08:49:04.870 OpenZWave: Value_Added: Node: 4 (0x04), CommandClass: METER, Label: Energy, Instance: 1
2017-10-01 08:49:04.870 OpenZWave: Value_Added: Node: 4 (0x04), CommandClass: METER, Label: Power, Instance: 1
2017-10-01 08:49:04.870 OpenZWave: Value_Added: Node: 4 (0x04), CommandClass: ALARM, Label: Alarm Type, Instance: 1
2017-10-01 08:49:04.870 OpenZWave: Value_Added: Node: 4 (0x04), CommandClass: ALARM, Label: Alarm Level, Instance: 1
2017-10-01 08:49:04.870 OpenZWave: Value_Added: Node: 4 (0x04), CommandClass: ALARM, Label: SourceNodeId, Instance: 1
2017-10-01 08:49:04.871 OpenZWave: Value_Added: Node: 4 (0x04), CommandClass: ALARM, Label: Heat, Instance: 1
2017-10-01 08:49:04.871 OpenZWave: Value_Added: Node: 4 (0x04), CommandClass: ALARM, Label: Power Management, Instance: 1
2017-10-01 08:49:04.871 OpenZWave: Value_Added: Node: 4 (0x04), CommandClass: ALARM, Label: System, Instance: 1
2017-10-01 08:49:04.875 OpenZWave: Value_Added: Node: 6 (0x06), CommandClass: SWITCH BINARY, Label: Switch, Instance: 1
2017-10-01 08:49:04.875 OpenZWave: Value_Added: Node: 6 (0x06), CommandClass: SWITCH BINARY, Label: Switch, Instance: 2
2017-10-01 08:49:04.875 OpenZWave: Value_Added: Node: 6 (0x06), CommandClass: SWITCH MULTILEVEL, Label: Step Size, Instance: 1
2017-10-01 08:49:04.875 OpenZWave: Value_Added: Node: 6 (0x06), CommandClass: SWITCH MULTILEVEL, Label: Inc, Instance: 1
2017-10-01 08:49:04.875 OpenZWave: Value_Added: Node: 6 (0x06), CommandClass: SWITCH MULTILEVEL, Label: Dec, Instance: 1
2017-10-01 08:49:04.875 OpenZWave: Value_Added: Node: 6 (0x06), CommandClass: SWITCH MULTILEVEL, Label: Level, Instance: 1
2017-10-01 08:49:04.875 OpenZWave: Value_Added: Node: 6 (0x06), CommandClass: SWITCH MULTILEVEL, Label: Bright, Instance: 1
2017-10-01 08:49:04.875 OpenZWave: Value_Added: Node: 6 (0x06), CommandClass: SWITCH MULTILEVEL, Label: Dim, Instance: 1
2017-10-01 08:49:04.876 OpenZWave: Value_Added: Node: 6 (0x06), CommandClass: SWITCH MULTILEVEL, Label: Step Size, Instance: 2
2017-10-01 08:49:04.876 OpenZWave: Value_Added: Node: 6 (0x06), CommandClass: SWITCH MULTILEVEL, Label: Inc, Instance: 2
2017-10-01 08:49:04.876 OpenZWave: Value_Added: Node: 6 (0x06), CommandClass: SWITCH MULTILEVEL, Label: Dec, Instance: 2
2017-10-01 08:49:04.876 OpenZWave: Value_Added: Node: 6 (0x06), CommandClass: SWITCH MULTILEVEL, Label: Level, Instance: 2
2017-10-01 08:49:04.876 OpenZWave: Value_Added: Node: 6 (0x06), CommandClass: SWITCH MULTILEVEL, Label: Bright, Instance: 2
2017-10-01 08:49:04.876 OpenZWave: Value_Added: Node: 6 (0x06), CommandClass: SWITCH MULTILEVEL, Label: Dim, Instance: 2
2017-10-01 08:49:04.876 OpenZWave: Value_Added: Node: 6 (0x06), CommandClass: METER, Label: Energy, Instance: 1
2017-10-01 08:49:04.876 OpenZWave: Value_Added: Node: 6 (0x06), CommandClass: METER, Label: Energy, Instance: 2
2017-10-01 08:49:04.876 OpenZWave: Value_Added: Node: 6 (0x06), CommandClass: METER, Label: Power, Instance: 1
2017-10-01 08:49:04.876 OpenZWave: Value_Added: Node: 6 (0x06), CommandClass: METER, Label: Power, Instance: 2
2017-10-01 08:49:04.877 OpenZWave: Value_Added: Node: 6 (0x06), CommandClass: ALARM, Label: Alarm Type, Instance: 1
2017-10-01 08:49:04.877 OpenZWave: Value_Added: Node: 6 (0x06), CommandClass: ALARM, Label: Alarm Level, Instance: 1
2017-10-01 08:49:04.877 OpenZWave: Value_Added: Node: 6 (0x06), CommandClass: ALARM, Label: SourceNodeId, Instance: 1
2017-10-01 08:49:04.877 OpenZWave: Value_Added: Node: 6 (0x06), CommandClass: ALARM, Label: Heat, Instance: 1
2017-10-01 08:49:04.877 OpenZWave: Value_Added: Node: 6 (0x06), CommandClass: ALARM, Label: Power Management, Instance: 1
2017-10-01 08:49:22.880 OpenZWave: Received timeout notification from HomeID: 4248490723, NodeID: 6 (0x06)
2017-10-01 08:49:23.919 OpenZWave: All Nodes queried
