However what led me to investigate this is that swithOn().forMins(10) doesn't seem to work, the switch on occurs, but the device is never switched off.
Log samples are below - is this normal behaviour or do I have a problem with my set-up somewhere??
2017-10-01 08:40:07.249 EventSystem: reset all events...
2017-10-01 08:40:07.250 EventSystem: Write file: /config/scripts/dzVents/generated_scripts/WirelessSwitch.lua
2017-10-01 08:40:07.250 EventSystem: Write file: /config/scripts/dzVents/generated_scripts/lts_hallpir_on.lua
2017-10-01 08:40:07.251 EventSystem: Write file: /config/scripts/dzVents/generated_scripts/lts_k+d_nightautooff.lua
2017-10-01 08:40:07.251 EventSystem: Write file: /config/scripts/dzVents/generated_scripts/status_someonehome.lua
2017-10-01 08:40:07.251 EventSystem: Write file: /config/scripts/dzVents/generated_scripts/lts_k+d_S2.lua
2017-10-01 08:40:07.252 EventSystem: Write file: /config/scripts/dzVents/generated_scripts/UFH.lua
2017-10-01 08:40:07.252 EventSystem: reset all device statuses...
2017-10-01 08:40:07.301 Python EventSystem: Initalizing event module.
2017-10-01 08:40:07.301 EventSystem: Started
2017-10-01 08:40:07.301 EventSystem: Queue thread started...
2017-10-01 08:43:01.037 EventSystem: reset all events...
2017-10-01 08:43:01.038 EventSystem: Write file: /config/scripts/dzVents/generated_scripts/WirelessSwitch.lua
2017-10-01 08:43:01.038 EventSystem: Write file: /config/scripts/dzVents/generated_scripts/lts_hallpir_on.lua
2017-10-01 08:43:01.039 EventSystem: Write file: /config/scripts/dzVents/generated_scripts/lts_k+d_nightautooff.lua
2017-10-01 08:43:01.039 EventSystem: Write file: /config/scripts/dzVents/generated_scripts/status_someonehome.lua
2017-10-01 08:43:01.039 EventSystem: Write file: /config/scripts/dzVents/generated_scripts/lts_k+d_S2.lua
2017-10-01 08:43:01.039 EventSystem: Write file: /config/scripts/dzVents/generated_scripts/UFH.lua
2017-10-01 08:43:08.117 EventSystem: reset all events...
2017-10-01 08:43:08.119 EventSystem: Write file: /config/scripts/dzVents/generated_scripts/WirelessSwitch.lua
2017-10-01 08:43:08.119 EventSystem: Write file: /config/scripts/dzVents/generated_scripts/lts_hallpir_on.lua
2017-10-01 08:43:08.120 EventSystem: Write file: /config/scripts/dzVents/generated_scripts/lts_k+d_nightautooff.lua
2017-10-01 08:43:08.120 EventSystem: Write file: /config/scripts/dzVents/generated_scripts/status_someonehome.lua
2017-10-01 08:43:08.120 EventSystem: Write file: /config/scripts/dzVents/generated_scripts/lts_k+d_S2.lua
2017-10-01 08:43:08.121 EventSystem: Write file: /config/scripts/dzVents/generated_scripts/UFH.lua
2017-10-01 08:43:08.121 EventSystem: reset all device statuses...
2017-10-01 08:43:08.167 Python EventSystem: Initalizing event module.
2017-10-01 08:43:08.167 EventSystem: Queue thread started...
2017-10-01 08:43:08.167 EventSystem: Started
2017-10-01 08:46:01.565 EventSystem: reset all events...
2017-10-01 08:46:01.566 EventSystem: Write file: /config/scripts/dzVents/generated_scripts/WirelessSwitch.lua
2017-10-01 08:46:01.566 EventSystem: Write file: /config/scripts/dzVents/generated_scripts/lts_hallpir_on.lua
2017-10-01 08:46:01.566 EventSystem: Write file: /config/scripts/dzVents/generated_scripts/lts_k+d_nightautooff.lua
2017-10-01 08:46:01.566 EventSystem: Write file: /config/scripts/dzVents/generated_scripts/status_someonehome.lua
2017-10-01 08:46:01.567 EventSystem: Write file: /config/scripts/dzVents/generated_scripts/lts_k+d_S2.lua
2017-10-01 08:46:01.567 EventSystem: Write file: /config/scripts/dzVents/generated_scripts/UFH.lua
2017-10-01 08:46:08.646 EventSystem: reset all events...
2017-10-01 08:46:08.647 EventSystem: Write file: /config/scripts/dzVents/generated_scripts/WirelessSwitch.lua
2017-10-01 08:46:08.649 EventSystem: Write file: /config/scripts/dzVents/generated_scripts/lts_hallpir_on.lua
2017-10-01 08:46:08.649 EventSystem: Write file: /config/scripts/dzVents/generated_scripts/lts_k+d_nightautooff.lua
2017-10-01 08:46:08.650 EventSystem: Write file: /config/scripts/dzVents/generated_scripts/status_someonehome.lua
2017-10-01 08:46:08.651 EventSystem: Write file: /config/scripts/dzVents/generated_scripts/lts_k+d_S2.lua
2017-10-01 08:46:08.651 EventSystem: Write file: /config/scripts/dzVents/generated_scripts/UFH.lua
2017-10-01 08:46:08.652 EventSystem: reset all device statuses...
2017-10-01 08:46:08.701 Python EventSystem: Initalizing event module.
2017-10-01 08:46:08.701 EventSystem: Queue thread started...
2017-10-01 08:46:08.701 EventSystem: StartedCode: Select all
2017-10-01 08:40:02.961 OpenZWave: Value_Added: Node: 6 (0x06), CommandClass: SWITCH MULTILEVEL, Label: Dec, Instance: 1
2017-10-01 08:40:02.961 OpenZWave: Value_Added: Node: 6 (0x06), CommandClass: SWITCH MULTILEVEL, Label: Level, Instance: 1
2017-10-01 08:40:02.961 OpenZWave: Value_Added: Node: 6 (0x06), CommandClass: SWITCH MULTILEVEL, Label: Bright, Instance: 1
2017-10-01 08:40:02.962 OpenZWave: Value_Added: Node: 6 (0x06), CommandClass: SWITCH MULTILEVEL, Label: Dim, Instance: 1
2017-10-01 08:40:02.962 OpenZWave: Value_Added: Node: 6 (0x06), CommandClass: SWITCH MULTILEVEL, Label: Step Size, Instance: 2
2017-10-01 08:40:02.962 OpenZWave: Value_Added: Node: 6 (0x06), CommandClass: SWITCH MULTILEVEL, Label: Inc, Instance: 2
2017-10-01 08:40:02.962 OpenZWave: Value_Added: Node: 6 (0x06), CommandClass: SWITCH MULTILEVEL, Label: Dec, Instance: 2
2017-10-01 08:40:02.962 OpenZWave: Value_Added: Node: 6 (0x06), CommandClass: SWITCH MULTILEVEL, Label: Level, Instance: 2
2017-10-01 08:40:02.962 OpenZWave: Value_Added: Node: 6 (0x06), CommandClass: SWITCH MULTILEVEL, Label: Bright, Instance: 2
2017-10-01 08:40:02.962 OpenZWave: Value_Added: Node: 6 (0x06), CommandClass: SWITCH MULTILEVEL, Label: Dim, Instance: 2
2017-10-01 08:40:02.963 OpenZWave: Value_Added: Node: 6 (0x06), CommandClass: METER, Label: Energy, Instance: 1
2017-10-01 08:40:02.963 OpenZWave: Value_Added: Node: 6 (0x06), CommandClass: METER, Label: Energy, Instance: 2
2017-10-01 08:40:02.963 OpenZWave: Value_Added: Node: 6 (0x06), CommandClass: METER, Label: Power, Instance: 1
2017-10-01 08:40:02.963 OpenZWave: Value_Added: Node: 6 (0x06), CommandClass: METER, Label: Power, Instance: 2
2017-10-01 08:40:02.964 OpenZWave: Value_Added: Node: 6 (0x06), CommandClass: ALARM, Label: Alarm Type, Instance: 1
2017-10-01 08:40:02.964 OpenZWave: Value_Added: Node: 6 (0x06), CommandClass: ALARM, Label: Alarm Level, Instance: 1
2017-10-01 08:40:02.964 OpenZWave: Value_Added: Node: 6 (0x06), CommandClass: ALARM, Label: SourceNodeId, Instance: 1
2017-10-01 08:40:02.964 OpenZWave: Value_Added: Node: 6 (0x06), CommandClass: ALARM, Label: Heat, Instance: 1
2017-10-01 08:40:02.964 OpenZWave: Value_Added: Node: 6 (0x06), CommandClass: ALARM, Label: Power Management, Instance: 1
2017-10-01 08:40:26.757 OpenZWave: Received timeout notification from HomeID: 4248490723, NodeID: 6 (0x06)
2017-10-01 08:40:28.748 OpenZWave: All Nodes queried
2017-10-01 08:43:03.617 OpenZWave: using config in: /var/lib/domoticz/Config/
2017-10-01 08:43:03.620 OpenZWave: Starting...
2017-10-01 08:43:03.620 OpenZWave: Version: 1.4-2754-ge4c265e2-dirty
2017-10-01 08:43:03.834 OpenZWave: Driver Ready
2017-10-01 08:43:03.836 OpenZWave: Value_Added: Node: 3 (0x03), CommandClass: SWITCH MULTILEVEL, Label: Step Size, Instance: 1
2017-10-01 08:43:03.836 OpenZWave: Value_Added: Node: 3 (0x03), CommandClass: SWITCH MULTILEVEL, Label: Inc, Instance: 1
2017-10-01 08:43:03.836 OpenZWave: Value_Added: Node: 3 (0x03), CommandClass: SWITCH MULTILEVEL, Label: Dec, Instance: 1
2017-10-01 08:43:03.836 OpenZWave: Value_Added: Node: 3 (0x03), CommandClass: SWITCH MULTILEVEL, Label: Level, Instance: 1
2017-10-01 08:43:03.836 OpenZWave: Value_Added: Node: 3 (0x03), CommandClass: SWITCH MULTILEVEL, Label: On, Instance: 1
2017-10-01 08:43:03.836 OpenZWave: Value_Added: Node: 3 (0x03), CommandClass: SWITCH MULTILEVEL, Label: Off, Instance: 1
2017-10-01 08:43:03.836 OpenZWave: Value_Added: Node: 3 (0x03), CommandClass: SWITCH MULTILEVEL, Label: Step Size, Instance: 2
2017-10-01 08:43:03.836 OpenZWave: Value_Added: Node: 3 (0x03), CommandClass: SWITCH MULTILEVEL, Label: Inc, Instance: 2
2017-10-01 08:43:03.836 OpenZWave: Value_Added: Node: 3 (0x03), CommandClass: SWITCH MULTILEVEL, Label: Dec, Instance: 2
2017-10-01 08:43:03.836 OpenZWave: Value_Added: Node: 3 (0x03), CommandClass: SWITCH MULTILEVEL, Label: Level, Instance: 2
2017-10-01 08:43:03.837 OpenZWave: Value_Added: Node: 3 (0x03), CommandClass: SWITCH MULTILEVEL, Label: Bright, Instance: 2
2017-10-01 08:43:03.837 OpenZWave: Value_Added: Node: 3 (0x03), CommandClass: SWITCH MULTILEVEL, Label: Dim, Instance: 2
2017-10-01 08:43:03.837 OpenZWave: Value_Added: Node: 3 (0x03), CommandClass: SENSOR MULTILEVEL, Label: Power, Instance: 4
2017-10-01 08:43:03.837 OpenZWave: Value_Added: Node: 3 (0x03), CommandClass: METER, Label: Energy, Instance: 1
2017-10-01 08:43:03.837 OpenZWave: Value_Added: Node: 3 (0x03), CommandClass: METER, Label: Power, Instance: 1
2017-10-01 08:43:03.837 OpenZWave: Value_Added: Node: 3 (0x03), CommandClass: ALARM, Label: Alarm Type, Instance: 1
2017-10-01 08:43:03.837 OpenZWave: Value_Added: Node: 3 (0x03), CommandClass: ALARM, Label: Alarm Level, Instance: 1
2017-10-01 08:43:03.837 OpenZWave: Value_Added: Node: 3 (0x03), CommandClass: ALARM, Label: SourceNodeId, Instance: 1
2017-10-01 08:43:03.837 OpenZWave: Value_Added: Node: 3 (0x03), CommandClass: ALARM, Label: Heat, Instance: 1
2017-10-01 08:43:03.837 OpenZWave: Value_Added: Node: 3 (0x03), CommandClass: ALARM, Label: Power Management, Instance: 1
2017-10-01 08:43:03.838 OpenZWave: Value_Added: Node: 3 (0x03), CommandClass: ALARM, Label: System, Instance: 1
2017-10-01 08:43:03.838 OpenZWave: Value_Added: Node: 4 (0x04), CommandClass: SWITCH MULTILEVEL, Label: Step Size, Instance: 1
2017-10-01 08:43:03.838 OpenZWave: Value_Added: Node: 4 (0x04), CommandClass: SWITCH MULTILEVEL, Label: Inc, Instance: 1
2017-10-01 08:43:03.838 OpenZWave: Value_Added: Node: 4 (0x04), CommandClass: SWITCH MULTILEVEL, Label: Dec, Instance: 1
2017-10-01 08:43:03.838 OpenZWave: Value_Added: Node: 4 (0x04), CommandClass: SWITCH MULTILEVEL, Label: Level, Instance: 1
2017-10-01 08:43:03.838 OpenZWave: Value_Added: Node: 4 (0x04), CommandClass: SWITCH MULTILEVEL, Label: On, Instance: 1
2017-10-01 08:43:03.838 OpenZWave: Value_Added: Node: 4 (0x04), CommandClass: SWITCH MULTILEVEL, Label: Off, Instance: 1
2017-10-01 08:43:03.838 OpenZWave: Value_Added: Node: 4 (0x04), CommandClass: SWITCH MULTILEVEL, Label: Step Size, Instance: 2
2017-10-01 08:43:03.838 OpenZWave: Value_Added: Node: 4 (0x04), CommandClass: SWITCH MULTILEVEL, Label: Inc, Instance: 2
2017-10-01 08:43:03.838 OpenZWave: Value_Added: Node: 4 (0x04), CommandClass: SWITCH MULTILEVEL, Label: Dec, Instance: 2
2017-10-01 08:43:03.838 OpenZWave: Value_Added: Node: 4 (0x04), CommandClass: SWITCH MULTILEVEL, Label: Level, Instance: 2
2017-10-01 08:43:03.838 OpenZWave: Value_Added: Node: 4 (0x04), CommandClass: SWITCH MULTILEVEL, Label: Bright, Instance: 2
2017-10-01 08:43:03.839 OpenZWave: Value_Added: Node: 4 (0x04), CommandClass: SWITCH MULTILEVEL, Label: Dim, Instance: 2
2017-10-01 08:43:03.839 OpenZWave: Value_Added: Node: 4 (0x04), CommandClass: SENSOR MULTILEVEL, Label: Power, Instance: 4
2017-10-01 08:43:03.839 OpenZWave: Value_Added: Node: 4 (0x04), CommandClass: METER, Label: Energy, Instance: 1
2017-10-01 08:43:03.839 OpenZWave: Value_Added: Node: 4 (0x04), CommandClass: METER, Label: Power, Instance: 1
2017-10-01 08:43:03.839 OpenZWave: Value_Added: Node: 4 (0x04), CommandClass: ALARM, Label: Alarm Type, Instance: 1
2017-10-01 08:43:03.839 OpenZWave: Value_Added: Node: 4 (0x04), CommandClass: ALARM, Label: Alarm Level, Instance: 1
2017-10-01 08:43:03.839 OpenZWave: Value_Added: Node: 4 (0x04), CommandClass: ALARM, Label: SourceNodeId, Instance: 1
2017-10-01 08:43:03.839 OpenZWave: Value_Added: Node: 4 (0x04), CommandClass: ALARM, Label: Heat, Instance: 1
2017-10-01 08:43:03.839 OpenZWave: Value_Added: Node: 4 (0x04), CommandClass: ALARM, Label: Power Management, Instance: 1
2017-10-01 08:43:03.839 OpenZWave: Value_Added: Node: 4 (0x04), CommandClass: ALARM, Label: System, Instance: 1
2017-10-01 08:43:03.840 OpenZWave: Value_Added: Node: 6 (0x06), CommandClass: SWITCH BINARY, Label: Switch, Instance: 1
2017-10-01 08:43:03.840 OpenZWave: Value_Added: Node: 6 (0x06), CommandClass: SWITCH BINARY, Label: Switch, Instance: 2
2017-10-01 08:43:03.840 OpenZWave: Value_Added: Node: 6 (0x06), CommandClass: SWITCH MULTILEVEL, Label: Step Size, Instance: 1
2017-10-01 08:43:03.840 OpenZWave: Value_Added: Node: 6 (0x06), CommandClass: SWITCH MULTILEVEL, Label: Inc, Instance: 1
2017-10-01 08:43:03.840 OpenZWave: Value_Added: Node: 6 (0x06), CommandClass: SWITCH MULTILEVEL, Label: Dec, Instance: 1
2017-10-01 08:43:03.840 OpenZWave: Value_Added: Node: 6 (0x06), CommandClass: SWITCH MULTILEVEL, Label: Level, Instance: 1
2017-10-01 08:43:03.840 OpenZWave: Value_Added: Node: 6 (0x06), CommandClass: SWITCH MULTILEVEL, Label: Bright, Instance: 1
2017-10-01 08:43:03.840 OpenZWave: Value_Added: Node: 6 (0x06), CommandClass: SWITCH MULTILEVEL, Label: Dim, Instance: 1
2017-10-01 08:43:03.840 OpenZWave: Value_Added: Node: 6 (0x06), CommandClass: SWITCH MULTILEVEL, Label: Step Size, Instance: 2
2017-10-01 08:43:03.840 OpenZWave: Value_Added: Node: 6 (0x06), CommandClass: SWITCH MULTILEVEL, Label: Inc, Instance: 2
2017-10-01 08:43:03.840 OpenZWave: Value_Added: Node: 6 (0x06), CommandClass: SWITCH MULTILEVEL, Label: Dec, Instance: 2
2017-10-01 08:43:03.840 OpenZWave: Value_Added: Node: 6 (0x06), CommandClass: SWITCH MULTILEVEL, Label: Level, Instance: 2
2017-10-01 08:43:03.841 OpenZWave: Value_Added: Node: 6 (0x06), CommandClass: SWITCH MULTILEVEL, Label: Bright, Instance: 2
2017-10-01 08:43:03.841 OpenZWave: Value_Added: Node: 6 (0x06), CommandClass: SWITCH MULTILEVEL, Label: Dim, Instance: 2
2017-10-01 08:43:03.841 OpenZWave: Value_Added: Node: 6 (0x06), CommandClass: METER, Label: Energy, Instance: 1
2017-10-01 08:43:03.841 OpenZWave: Value_Added: Node: 6 (0x06), CommandClass: METER, Label: Energy, Instance: 2
2017-10-01 08:43:03.841 OpenZWave: Value_Added: Node: 6 (0x06), CommandClass: METER, Label: Power, Instance: 1
2017-10-01 08:43:03.841 OpenZWave: Value_Added: Node: 6 (0x06), CommandClass: METER, Label: Power, Instance: 2
2017-10-01 08:43:03.842 OpenZWave: Value_Added: Node: 6 (0x06), CommandClass: ALARM, Label: Alarm Type, Instance: 1
2017-10-01 08:43:03.842 OpenZWave: Value_Added: Node: 6 (0x06), CommandClass: ALARM, Label: Alarm Level, Instance: 1
2017-10-01 08:43:03.842 OpenZWave: Value_Added: Node: 6 (0x06), CommandClass: ALARM, Label: SourceNodeId, Instance: 1
2017-10-01 08:43:03.842 OpenZWave: Value_Added: Node: 6 (0x06), CommandClass: ALARM, Label: Heat, Instance: 1
2017-10-01 08:43:03.842 OpenZWave: Value_Added: Node: 6 (0x06), CommandClass: ALARM, Label: Power Management, Instance: 1
2017-10-01 08:43:22.117 OpenZWave: Received timeout notification from HomeID: 4248490723, NodeID: 6 (0x06)
2017-10-01 08:43:23.145 OpenZWave: All Nodes queried
2017-10-01 08:46:04.146 OpenZWave: using config in: /var/lib/domoticz/Config/
2017-10-01 08:46:04.147 OpenZWave: Starting...
2017-10-01 08:46:04.148 OpenZWave: Version: 1.4-2754-ge4c265e2-dirty
2017-10-01 08:46:04.348 OpenZWave: Driver Ready
2017-10-01 08:46:04.352 OpenZWave: Value_Added: Node: 3 (0x03), CommandClass: SWITCH MULTILEVEL, Label: Step Size, Instance: 1
2017-10-01 08:46:04.352 OpenZWave: Value_Added: Node: 3 (0x03), CommandClass: SWITCH MULTILEVEL, Label: Inc, Instance: 1
2017-10-01 08:46:04.353 OpenZWave: Value_Added: Node: 3 (0x03), CommandClass: SWITCH MULTILEVEL, Label: Dec, Instance: 1
2017-10-01 08:46:04.353 OpenZWave: Value_Added: Node: 3 (0x03), CommandClass: SWITCH MULTILEVEL, Label: Level, Instance: 1
2017-10-01 08:46:04.353 OpenZWave: Value_Added: Node: 3 (0x03), CommandClass: SWITCH MULTILEVEL, Label: On, Instance: 1
2017-10-01 08:46:04.353 OpenZWave: Value_Added: Node: 3 (0x03), CommandClass: SWITCH MULTILEVEL, Label: Off, Instance: 1
2017-10-01 08:46:04.354 OpenZWave: Value_Added: Node: 3 (0x03), CommandClass: SWITCH MULTILEVEL, Label: Step Size, Instance: 2
2017-10-01 08:46:04.354 OpenZWave: Value_Added: Node: 3 (0x03), CommandClass: SWITCH MULTILEVEL, Label: Inc, Instance: 2
2017-10-01 08:46:04.354 OpenZWave: Value_Added: Node: 3 (0x03), CommandClass: SWITCH MULTILEVEL, Label: Dec, Instance: 2
2017-10-01 08:46:04.354 OpenZWave: Value_Added: Node: 3 (0x03), CommandClass: SWITCH MULTILEVEL, Label: Level, Instance: 2
2017-10-01 08:46:04.354 OpenZWave: Value_Added: Node: 3 (0x03), CommandClass: SWITCH MULTILEVEL, Label: Bright, Instance: 2
2017-10-01 08:46:04.355 OpenZWave: Value_Added: Node: 3 (0x03), CommandClass: SWITCH MULTILEVEL, Label: Dim, Instance: 2
2017-10-01 08:46:04.355 OpenZWave: Value_Added: Node: 3 (0x03), CommandClass: SENSOR MULTILEVEL, Label: Power, Instance: 4
2017-10-01 08:46:04.355 OpenZWave: Value_Added: Node: 3 (0x03), CommandClass: METER, Label: Energy, Instance: 1
2017-10-01 08:46:04.355 OpenZWave: Value_Added: Node: 3 (0x03), CommandClass: METER, Label: Power, Instance: 1
2017-10-01 08:46:04.356 OpenZWave: Value_Added: Node: 3 (0x03), CommandClass: ALARM, Label: Alarm Type, Instance: 1
2017-10-01 08:46:04.356 OpenZWave: Value_Added: Node: 3 (0x03), CommandClass: ALARM, Label: Alarm Level, Instance: 1
2017-10-01 08:46:04.356 OpenZWave: Value_Added: Node: 3 (0x03), CommandClass: ALARM, Label: SourceNodeId, Instance: 1
2017-10-01 08:46:04.356 OpenZWave: Value_Added: Node: 3 (0x03), CommandClass: ALARM, Label: Heat, Instance: 1
2017-10-01 08:46:04.357 OpenZWave: Value_Added: Node: 3 (0x03), CommandClass: ALARM, Label: Power Management, Instance: 1
2017-10-01 08:46:04.357 OpenZWave: Value_Added: Node: 3 (0x03), CommandClass: ALARM, Label: System, Instance: 1
2017-10-01 08:46:04.357 OpenZWave: Value_Added: Node: 4 (0x04), CommandClass: SWITCH MULTILEVEL, Label: Step Size, Instance: 1
2017-10-01 08:46:04.357 OpenZWave: Value_Added: Node: 4 (0x04), CommandClass: SWITCH MULTILEVEL, Label: Inc, Instance: 1
2017-10-01 08:46:04.358 OpenZWave: Value_Added: Node: 4 (0x04), CommandClass: SWITCH MULTILEVEL, Label: Dec, Instance: 1
2017-10-01 08:46:04.358 OpenZWave: Value_Added: Node: 4 (0x04), CommandClass: SWITCH MULTILEVEL, Label: Level, Instance: 1
2017-10-01 08:46:04.358 OpenZWave: Value_Added: Node: 4 (0x04), CommandClass: SWITCH MULTILEVEL, Label: On, Instance: 1
2017-10-01 08:46:04.358 OpenZWave: Value_Added: Node: 4 (0x04), CommandClass: SWITCH MULTILEVEL, Label: Off, Instance: 1
2017-10-01 08:46:04.358 OpenZWave: Value_Added: Node: 4 (0x04), CommandClass: SWITCH MULTILEVEL, Label: Step Size, Instance: 2
2017-10-01 08:46:04.358 OpenZWave: Value_Added: Node: 4 (0x04), CommandClass: SWITCH MULTILEVEL, Label: Inc, Instance: 2
2017-10-01 08:46:04.359 OpenZWave: Value_Added: Node: 4 (0x04), CommandClass: SWITCH MULTILEVEL, Label: Dec, Instance: 2
2017-10-01 08:46:04.359 OpenZWave: Value_Added: Node: 4 (0x04), CommandClass: SWITCH MULTILEVEL, Label: Level, Instance: 2
2017-10-01 08:46:04.359 OpenZWave: Value_Added: Node: 4 (0x04), CommandClass: SWITCH MULTILEVEL, Label: Bright, Instance: 2
2017-10-01 08:46:04.359 OpenZWave: Value_Added: Node: 4 (0x04), CommandClass: SWITCH MULTILEVEL, Label: Dim, Instance: 2
2017-10-01 08:46:04.359 OpenZWave: Value_Added: Node: 4 (0x04), CommandClass: SENSOR MULTILEVEL, Label: Power, Instance: 4
2017-10-01 08:46:04.359 OpenZWave: Value_Added: Node: 4 (0x04), CommandClass: METER, Label: Energy, Instance: 1
2017-10-01 08:46:04.359 OpenZWave: Value_Added: Node: 4 (0x04), CommandClass: METER, Label: Power, Instance: 1
2017-10-01 08:46:04.360 OpenZWave: Value_Added: Node: 4 (0x04), CommandClass: ALARM, Label: Alarm Type, Instance: 1
2017-10-01 08:46:04.360 OpenZWave: Value_Added: Node: 4 (0x04), CommandClass: ALARM, Label: Alarm Level, Instance: 1
2017-10-01 08:46:04.360 OpenZWave: Value_Added: Node: 4 (0x04), CommandClass: ALARM, Label: SourceNodeId, Instance: 1
2017-10-01 08:46:04.360 OpenZWave: Value_Added: Node: 4 (0x04), CommandClass: ALARM, Label: Heat, Instance: 1
2017-10-01 08:46:04.360 OpenZWave: Value_Added: Node: 4 (0x04), CommandClass: ALARM, Label: Power Management, Instance: 1
2017-10-01 08:46:04.361 OpenZWave: Value_Added: Node: 4 (0x04), CommandClass: ALARM, Label: System, Instance: 1
2017-10-01 08:46:04.361 OpenZWave: Value_Added: Node: 6 (0x06), CommandClass: SWITCH BINARY, Label: Switch, Instance: 1
2017-10-01 08:46:04.361 OpenZWave: Value_Added: Node: 6 (0x06), CommandClass: SWITCH BINARY, Label: Switch, Instance: 2
2017-10-01 08:46:04.362 OpenZWave: Value_Added: Node: 6 (0x06), CommandClass: SWITCH MULTILEVEL, Label: Step Size, Instance: 1
2017-10-01 08:46:04.362 OpenZWave: Value_Added: Node: 6 (0x06), CommandClass: SWITCH MULTILEVEL, Label: Inc, Instance: 1
2017-10-01 08:46:04.362 OpenZWave: Value_Added: Node: 6 (0x06), CommandClass: SWITCH MULTILEVEL, Label: Dec, Instance: 1
2017-10-01 08:46:04.362 OpenZWave: Value_Added: Node: 6 (0x06), CommandClass: SWITCH MULTILEVEL, Label: Level, Instance: 1
2017-10-01 08:46:04.362 OpenZWave: Value_Added: Node: 6 (0x06), CommandClass: SWITCH MULTILEVEL, Label: Bright, Instance: 1
2017-10-01 08:46:04.362 OpenZWave: Value_Added: Node: 6 (0x06), CommandClass: SWITCH MULTILEVEL, Label: Dim, Instance: 1
2017-10-01 08:46:04.362 OpenZWave: Value_Added: Node: 6 (0x06), CommandClass: SWITCH MULTILEVEL, Label: Step Size, Instance: 2
2017-10-01 08:46:04.362 OpenZWave: Value_Added: Node: 6 (0x06), CommandClass: SWITCH MULTILEVEL, Label: Inc, Instance: 2
2017-10-01 08:46:04.363 OpenZWave: Value_Added: Node: 6 (0x06), CommandClass: SWITCH MULTILEVEL, Label: Dec, Instance: 2
2017-10-01 08:46:04.363 OpenZWave: Value_Added: Node: 6 (0x06), CommandClass: SWITCH MULTILEVEL, Label: Level, Instance: 2
2017-10-01 08:46:04.363 OpenZWave: Value_Added: Node: 6 (0x06), CommandClass: SWITCH MULTILEVEL, Label: Bright, Instance: 2
2017-10-01 08:46:04.363 OpenZWave: Value_Added: Node: 6 (0x06), CommandClass: SWITCH MULTILEVEL, Label: Dim, Instance: 2
2017-10-01 08:46:04.363 OpenZWave: Value_Added: Node: 6 (0x06), CommandClass: METER, Label: Energy, Instance: 1
2017-10-01 08:46:04.363 OpenZWave: Value_Added: Node: 6 (0x06), CommandClass: METER, Label: Energy, Instance: 2
2017-10-01 08:46:04.363 OpenZWave: Value_Added: Node: 6 (0x06), CommandClass: METER, Label: Power, Instance: 1
2017-10-01 08:46:04.364 OpenZWave: Value_Added: Node: 6 (0x06), CommandClass: METER, Label: Power, Instance: 2
2017-10-01 08:46:04.364 OpenZWave: Value_Added: Node: 6 (0x06), CommandClass: ALARM, Label: Alarm Type, Instance: 1
2017-10-01 08:46:04.364 OpenZWave: Value_Added: Node: 6 (0x06), CommandClass: ALARM, Label: Alarm Level, Instance: 1
2017-10-01 08:46:04.364 OpenZWave: Value_Added: Node: 6 (0x06), CommandClass: ALARM, Label: SourceNodeId, Instance: 1
2017-10-01 08:46:04.364 OpenZWave: Value_Added: Node: 6 (0x06), CommandClass: ALARM, Label: Heat, Instance: 1
2017-10-01 08:46:04.365 OpenZWave: Value_Added: Node: 6 (0x06), CommandClass: ALARM, Label: Power Management, Instance: 1
2017-10-01 08:46:22.348 OpenZWave: Received timeout notification from HomeID: 4248490723, NodeID: 6 (0x06)
2017-10-01 08:46:23.372 OpenZWave: All Nodes queried
2017-10-01 08:49:04.666 OpenZWave: using config in: /var/lib/domoticz/Config/
2017-10-01 08:49:04.667 OpenZWave: Starting...
2017-10-01 08:49:04.667 OpenZWave: Version: 1.4-2754-ge4c265e2-dirty
2017-10-01 08:49:04.863 OpenZWave: Driver Ready
2017-10-01 08:49:04.866 OpenZWave: Value_Added: Node: 3 (0x03), CommandClass: SWITCH MULTILEVEL, Label: Step Size, Instance: 1
2017-10-01 08:49:04.866 OpenZWave: Value_Added: Node: 3 (0x03), CommandClass: SWITCH MULTILEVEL, Label: Inc, Instance: 1
2017-10-01 08:49:04.866 OpenZWave: Value_Added: Node: 3 (0x03), CommandClass: SWITCH MULTILEVEL, Label: Dec, Instance: 1
2017-10-01 08:49:04.867 OpenZWave: Value_Added: Node: 3 (0x03), CommandClass: SWITCH MULTILEVEL, Label: Level, Instance: 1
2017-10-01 08:49:04.867 OpenZWave: Value_Added: Node: 3 (0x03), CommandClass: SWITCH MULTILEVEL, Label: On, Instance: 1
2017-10-01 08:49:04.867 OpenZWave: Value_Added: Node: 3 (0x03), CommandClass: SWITCH MULTILEVEL, Label: Off, Instance: 1
2017-10-01 08:49:04.867 OpenZWave: Value_Added: Node: 3 (0x03), CommandClass: SWITCH MULTILEVEL, Label: Step Size, Instance: 2
2017-10-01 08:49:04.867 OpenZWave: Value_Added: Node: 3 (0x03), CommandClass: SWITCH MULTILEVEL, Label: Inc, Instance: 2
2017-10-01 08:49:04.867 OpenZWave: Value_Added: Node: 3 (0x03), CommandClass: SWITCH MULTILEVEL, Label: Dec, Instance: 2
2017-10-01 08:49:04.867 OpenZWave: Value_Added: Node: 3 (0x03), CommandClass: SWITCH MULTILEVEL, Label: Level, Instance: 2
2017-10-01 08:49:04.867 OpenZWave: Value_Added: Node: 3 (0x03), CommandClass: SWITCH MULTILEVEL, Label: Bright, Instance: 2
2017-10-01 08:49:04.867 OpenZWave: Value_Added: Node: 3 (0x03), CommandClass: SWITCH MULTILEVEL, Label: Dim, Instance: 2
2017-10-01 08:49:04.867 OpenZWave: Value_Added: Node: 3 (0x03), CommandClass: SENSOR MULTILEVEL, Label: Power, Instance: 4
2017-10-01 08:49:04.868 OpenZWave: Value_Added: Node: 3 (0x03), CommandClass: METER, Label: Energy, Instance: 1
2017-10-01 08:49:04.868 OpenZWave: Value_Added: Node: 3 (0x03), CommandClass: METER, Label: Power, Instance: 1
2017-10-01 08:49:04.868 OpenZWave: Value_Added: Node: 3 (0x03), CommandClass: ALARM, Label: Alarm Type, Instance: 1
2017-10-01 08:49:04.868 OpenZWave: Value_Added: Node: 3 (0x03), CommandClass: ALARM, Label: Alarm Level, Instance: 1
2017-10-01 08:49:04.868 OpenZWave: Value_Added: Node: 3 (0x03), CommandClass: ALARM, Label: SourceNodeId, Instance: 1
2017-10-01 08:49:04.868 OpenZWave: Value_Added: Node: 3 (0x03), CommandClass: ALARM, Label: Heat, Instance: 1
2017-10-01 08:49:04.868 OpenZWave: Value_Added: Node: 3 (0x03), CommandClass: ALARM, Label: Power Management, Instance: 1
2017-10-01 08:49:04.868 OpenZWave: Value_Added: Node: 3 (0x03), CommandClass: ALARM, Label: System, Instance: 1
2017-10-01 08:49:04.869 OpenZWave: Value_Added: Node: 4 (0x04), CommandClass: SWITCH MULTILEVEL, Label: Step Size, Instance: 1
2017-10-01 08:49:04.869 OpenZWave: Value_Added: Node: 4 (0x04), CommandClass: SWITCH MULTILEVEL, Label: Inc, Instance: 1
2017-10-01 08:49:04.869 OpenZWave: Value_Added: Node: 4 (0x04), CommandClass: SWITCH MULTILEVEL, Label: Dec, Instance: 1
2017-10-01 08:49:04.869 OpenZWave: Value_Added: Node: 4 (0x04), CommandClass: SWITCH MULTILEVEL, Label: Level, Instance: 1
2017-10-01 08:49:04.869 OpenZWave: Value_Added: Node: 4 (0x04), CommandClass: SWITCH MULTILEVEL, Label: On, Instance: 1
2017-10-01 08:49:04.869 OpenZWave: Value_Added: Node: 4 (0x04), CommandClass: SWITCH MULTILEVEL, Label: Off, Instance: 1
2017-10-01 08:49:04.869 OpenZWave: Value_Added: Node: 4 (0x04), CommandClass: SWITCH MULTILEVEL, Label: Step Size, Instance: 2
2017-10-01 08:49:04.869 OpenZWave: Value_Added: Node: 4 (0x04), CommandClass: SWITCH MULTILEVEL, Label: Inc, Instance: 2
2017-10-01 08:49:04.869 OpenZWave: Value_Added: Node: 4 (0x04), CommandClass: SWITCH MULTILEVEL, Label: Dec, Instance: 2
2017-10-01 08:49:04.869 OpenZWave: Value_Added: Node: 4 (0x04), CommandClass: SWITCH MULTILEVEL, Label: Level, Instance: 2
2017-10-01 08:49:04.870 OpenZWave: Value_Added: Node: 4 (0x04), CommandClass: SWITCH MULTILEVEL, Label: Bright, Instance: 2
2017-10-01 08:49:04.870 OpenZWave: Value_Added: Node: 4 (0x04), CommandClass: SWITCH MULTILEVEL, Label: Dim, Instance: 2
2017-10-01 08:49:04.870 OpenZWave: Value_Added: Node: 4 (0x04), CommandClass: SENSOR MULTILEVEL, Label: Power, Instance: 4
2017-10-01 08:49:04.870 OpenZWave: Value_Added: Node: 4 (0x04), CommandClass: METER, Label: Energy, Instance: 1
2017-10-01 08:49:04.870 OpenZWave: Value_Added: Node: 4 (0x04), CommandClass: METER, Label: Power, Instance: 1
2017-10-01 08:49:04.870 OpenZWave: Value_Added: Node: 4 (0x04), CommandClass: ALARM, Label: Alarm Type, Instance: 1
2017-10-01 08:49:04.870 OpenZWave: Value_Added: Node: 4 (0x04), CommandClass: ALARM, Label: Alarm Level, Instance: 1
2017-10-01 08:49:04.870 OpenZWave: Value_Added: Node: 4 (0x04), CommandClass: ALARM, Label: SourceNodeId, Instance: 1
2017-10-01 08:49:04.871 OpenZWave: Value_Added: Node: 4 (0x04), CommandClass: ALARM, Label: Heat, Instance: 1
2017-10-01 08:49:04.871 OpenZWave: Value_Added: Node: 4 (0x04), CommandClass: ALARM, Label: Power Management, Instance: 1
2017-10-01 08:49:04.871 OpenZWave: Value_Added: Node: 4 (0x04), CommandClass: ALARM, Label: System, Instance: 1
2017-10-01 08:49:04.875 OpenZWave: Value_Added: Node: 6 (0x06), CommandClass: SWITCH BINARY, Label: Switch, Instance: 1
2017-10-01 08:49:04.875 OpenZWave: Value_Added: Node: 6 (0x06), CommandClass: SWITCH BINARY, Label: Switch, Instance: 2
2017-10-01 08:49:04.875 OpenZWave: Value_Added: Node: 6 (0x06), CommandClass: SWITCH MULTILEVEL, Label: Step Size, Instance: 1
2017-10-01 08:49:04.875 OpenZWave: Value_Added: Node: 6 (0x06), CommandClass: SWITCH MULTILEVEL, Label: Inc, Instance: 1
2017-10-01 08:49:04.875 OpenZWave: Value_Added: Node: 6 (0x06), CommandClass: SWITCH MULTILEVEL, Label: Dec, Instance: 1
2017-10-01 08:49:04.875 OpenZWave: Value_Added: Node: 6 (0x06), CommandClass: SWITCH MULTILEVEL, Label: Level, Instance: 1
2017-10-01 08:49:04.875 OpenZWave: Value_Added: Node: 6 (0x06), CommandClass: SWITCH MULTILEVEL, Label: Bright, Instance: 1
2017-10-01 08:49:04.875 OpenZWave: Value_Added: Node: 6 (0x06), CommandClass: SWITCH MULTILEVEL, Label: Dim, Instance: 1
2017-10-01 08:49:04.876 OpenZWave: Value_Added: Node: 6 (0x06), CommandClass: SWITCH MULTILEVEL, Label: Step Size, Instance: 2
2017-10-01 08:49:04.876 OpenZWave: Value_Added: Node: 6 (0x06), CommandClass: SWITCH MULTILEVEL, Label: Inc, Instance: 2
2017-10-01 08:49:04.876 OpenZWave: Value_Added: Node: 6 (0x06), CommandClass: SWITCH MULTILEVEL, Label: Dec, Instance: 2
2017-10-01 08:49:04.876 OpenZWave: Value_Added: Node: 6 (0x06), CommandClass: SWITCH MULTILEVEL, Label: Level, Instance: 2
2017-10-01 08:49:04.876 OpenZWave: Value_Added: Node: 6 (0x06), CommandClass: SWITCH MULTILEVEL, Label: Bright, Instance: 2
2017-10-01 08:49:04.876 OpenZWave: Value_Added: Node: 6 (0x06), CommandClass: SWITCH MULTILEVEL, Label: Dim, Instance: 2
2017-10-01 08:49:04.876 OpenZWave: Value_Added: Node: 6 (0x06), CommandClass: METER, Label: Energy, Instance: 1
2017-10-01 08:49:04.876 OpenZWave: Value_Added: Node: 6 (0x06), CommandClass: METER, Label: Energy, Instance: 2
2017-10-01 08:49:04.876 OpenZWave: Value_Added: Node: 6 (0x06), CommandClass: METER, Label: Power, Instance: 1
2017-10-01 08:49:04.876 OpenZWave: Value_Added: Node: 6 (0x06), CommandClass: METER, Label: Power, Instance: 2
2017-10-01 08:49:04.877 OpenZWave: Value_Added: Node: 6 (0x06), CommandClass: ALARM, Label: Alarm Type, Instance: 1
2017-10-01 08:49:04.877 OpenZWave: Value_Added: Node: 6 (0x06), CommandClass: ALARM, Label: Alarm Level, Instance: 1
2017-10-01 08:49:04.877 OpenZWave: Value_Added: Node: 6 (0x06), CommandClass: ALARM, Label: SourceNodeId, Instance: 1
2017-10-01 08:49:04.877 OpenZWave: Value_Added: Node: 6 (0x06), CommandClass: ALARM, Label: Heat, Instance: 1
2017-10-01 08:49:04.877 OpenZWave: Value_Added: Node: 6 (0x06), CommandClass: ALARM, Label: Power Management, Instance: 1
2017-10-01 08:49:22.880 OpenZWave: Received timeout notification from HomeID: 4248490723, NodeID: 6 (0x06)
2017-10-01 08:49:23.919 OpenZWave: All Nodes queried
