Aeon ZW096 Thermostat Clock
coolwine1962
Domoticz version: 2020.1
Post by coolwine1962 »
Is there somebody who can explain the use of the Thermostat clock which appears in the device view of domoticz when you add this new device to your hardware
what can you do with this device ?
There are four entry's
Lightswitch
CM113, Electrisave
General kWh
General Voltage
General Thermostat Clock
THX
1 x Raspberry Pi4 Raspbian
1 x ANT GP433Mhz
1 x Rfxcom
1 x RainSensor
1 x Kaku Doorbel
1 X Aeon Z-Wave USB Stick
25 x Fibaro WallPlug
2 x ZRC90
2 x Aeotec MultiSensor
6 x zWave Greenwave 6
4 x zWave Greenwave 1
1 x Pi slave for Electra and Gas
emme
Domoticz version: latest
Re: Aeon ZW096 Thermostat Clock
Post by emme »
COMMAND_CLASS_CLOCK is intend to synch the controller time to the device time and used in action schedules whitch is an option not covered in Domoticz and in the Open Zwave stack (I presume)
In other controllers (like fibaro HomeCenter for example) you should be able to store a schedule inside the device, so it will run regardless the controller state
...well.. this is what I have understood :P :P
"We always done this way"
coolwine1962
THX for the info,
so it is shown in domoticz, but no function.
1 x ANT GP433Mhz
1 x Rfxcom
1 x RainSensor
1 x Kaku Doorbel
2 x ZRC90
