How can I change switch icon?
TheTool
Post by TheTool »
I have installed Broadlink RM plugin and learned a few IR commands, but they have default icon...
to change icon I need to change the switch type from "Push On Button" to "On/Off"
but then it only send the command once every two click (hence when it's "Switching on")
I don't get it, how can I fix that?
and if I wan't it to actually send another ir command when it's "Switching off" how it can be done?
frustrated.. :?
lonebaggie
Re: How can I change switch icon?
Post by lonebaggie »
You cannot change the push on or push off icon. Had the same issue. Have written a universal script which allows you to link nominated switch's together. One action of this is you can create an on/off switch that automatically turns off when turned on without triggering the off action !.
See
viewtopic.php?f=38&t=19217
TheTool
Post by TheTool »
So why this option is there if it's not possible to use it?
that doesn't make sense. There has to be an option to assign a command to the "off option".
In the Broadlink wiki page it says to paste the script command to do it, like this:
"script://C:/Program Files (x86)/Domoticz/plugins/BroadlinkRM2/plugin_send.cmd C:/RMpro/BroadlinkRM2-2-13.ini"
But somehow it doesn't work for me :/
Lebo2d9
Domoticz version: L stab
Post by Lebo2d9 »
Hi ,
You can upload custom icon's.
When you have your switch you can edit the switch and change the switch icon.
Then in off delay you add 1second. (The switch will be off afyter 1 second).
Then you can add for the "on" action and the "off" action the same action.
Domoicz on RPI3 (wifi) directly connected 3x ds18b20 for CV temp, Evohome (9 zone), 1 remote 220V switch based on ESP-12. RFXtrx433E, 16x AMST-606, 5 Somfy RTS motors
Domoticz on RPI3(wifi) as slave for terraruim control
More to come
baileyshaw437
Post by baileyshaw437 »
Sorry to say but you cannot change that button theme, it is there by default.
