Help me to right direction DzVents
poudenes
Domoticz version: 3.8993
Post by poudenes »
Hi All,
I want change all my blocky to dzVents. Have played with some simple switch actions. But don't know how to handle this:
I have a Between sunset - sunrise, and couple of "AND" devices on or off that will trigger a action. In DzVents i see only 1 ON after active.
If someone can help me out then i can understand how to do this for rest of the blocky actions
Toyman
Re: Help me to right direction DzVents
Post by Toyman »
I believe, in "on" section you should put timer as a trigger (after sunset and before sunrise)
and then in "execute" section just put "if device1 is on and device 2 is off and so on", then "switch evening scene on".
The script will be checked every minute between sunset and sunrise and executed if condictions are met
