OZW and FGS223 relays
Posted: Friday 22 September 2017 13:29
I have 2 relays that control 4 motorised valves on the back of my wood burning stove.
I have an issue with one relay (the 2 are identical).
One relay is only seeing 1 switch in OZW, i need to be able to control both switches.
How can i force OZW to see that 2nd switch again?
I've tried Refresh Node Info a few times but it isn't finding the second swtich.
Anything else i can try?
AS mentioned, i have another relay that is the same but both switches are found - is there a way to manually copy the settings from that relay and pop them into the other relay?
Cheers
Stuart
Cheers
Stuart
