OZW and FGS223 relays
stuiow
Domoticz version: 3.6857
Post by stuiow »
I have 2 relays that control 4 motorised valves on the back of my wood burning stove.
I have an issue with one relay (the 2 are identical).
One relay is only seeing 1 switch in OZW, i need to be able to control both switches.
How can i force OZW to see that 2nd switch again?
I've tried Refresh Node Info a few times but it isn't finding the second swtich.
Anything else i can try?
AS mentioned, i have another relay that is the same but both switches are found - is there a way to manually copy the settings from that relay and pop them into the other relay?
Cheers
Stuart
Now setup on a RPI3.
Also using Evohome HGI80, RFXTRX433E and a Aeotec Gen5 stick. Mainly a Gen5 Z-Wave system.
My weather (Davis vantage Pro2) data is obtained by weatherunderground
Now collecting rtl_433 data from Apollo Ultrasonic meter
DutchHans
Re: OZW and FGS223 relays
Post by DutchHans »
Its been mentioned several times here on the forum. A simple reboot might help.
Success, Hans
stuiow
Post by stuiow »
Sorry, should have mentioned i've followed that thread since creation and i've done the simple things like rebooting.
This is more a OZW issue than a domoticz issue.
I dont want to go down the route of excluding and including, but it's looking more likely, the deleting of the ozwxxxxxx.xml is quite a big thing for me to do on my z-wave network and i certainly am avoiding that option.
