Doorbell blocky
gwabber
Domoticz version: 3.8153
Doorbell blocky
Post by gwabber »
Hi Everyone,
i'm trying to create a blocky that turns on a relay when the doorbell is pressed. This purpose is that it only happens when it is between 07.00 and 17.00 hour. Then the relay should turn of after then minutes.
The doorbell has status 'on' in Domoticz and I created the following Blocky, but it doesnt work as it should. What am I doing wrong?
Thanks in advance!
blocky kopie.jpg (27.29 KiB) Viewed 1246 times
VMWare ESXI, Ubuntu 20.04. Zwave and RFXCom
cobra045
Domoticz version: 3.4834
Re: Doorbell blocky
Post by cobra045 »
Hi gwabber,
You are using the wrong time option
Do not use the time option (00:00) but the logic option (0)
Cobra045
gwabber
Re: Doorbell blocky
Post by gwabber »
Thanks for your reply! I'm going to ty that.
I also think there is something wrong with the first part. When the doorbell is pressed the log doesnt show that the blocky is activated.
rinse
Re: Doorbell blocky
Post by rinse »
Just came across this post trying to solve exactly the same problem (but with outside lamp instead of a relay). for me it turned out to be "group on" instead of on for the doorbell. hope this helps the next guy.
