I've a Blockly that turns my hall light on and off dependent on movement and LUX. The brightness the light is set to should be 80% between 9am and 9pm and 60% outwith those hours.
The movement and LUX part of the script works fine but the light always comes on at 60%.
The system time is correct. Can anyone see what is wrong with my logic.
Time condition not working Topic is solved
anno
- Domoticz version: all
Re: Time condition not working
you need the time also in else if
long time domiticz user, running 8 domoticz installations on vm's nuc i3. And espeay hosting more than 30.
tozzke
- Domoticz version: Stable
Else if's in Domoticz (or in Blockly?) aren't "real" else if's, more something like or if's
So you'll have to add a time condition to the second part in this manner:
'and [[Time > [21:00]] or [Time <= [9:00]]'
when you pass midnight in a time condition, you'll have to use 'or' because Domoticz calculates with time on the same day. It can't be after 21:00 AND before 9:00 on the same day, therefore or
Padster
Thanks guys for the answer - its been driving me nuts.
Lebo2d9
- Domoticz version: L stab
I use a dummy switch that is set by times and check the status of the switch in blockly.
Domoicz on RPI3 (wifi) directly connected 3x ds18b20 for CV temp, Evohome (9 zone), 1 remote 220V switch based on ESP-12. RFXtrx433E, 16x AMST-606, 5 Somfy RTS motors
Domoticz on RPI3(wifi) as slave for terraruim control
More to come
More to come
