Page 1 of 3
Dashticz - Module Moonphases
Posted: Wednesday 13 September 2017 15:01
by htilburgs
Re: Dashticz - Module Moonphases
Posted: Wednesday 13 September 2017 15:05
by htilburgs
As of sometime today (don't know exactly when), I've an error:
Error: EventSystem: in /home/pi/domoticz/scripts/lua/check_time_moon.lua: /home/pi/domoticz/scripts/lua/check_time_moon.lua:62: attempt to concatenate global 'moonriseMinute' (a nil value)
When I check manualy, then I see that the Moonrise is missing.
Has this something to do with Wunderground not sending the correct information?
"moonrise": {
"hour":"",
"minute":""
"response": {
"version":"0.1",
"termsofService":"http://www.wunderground.com/weather/api/d/terms.html",
"features": {
"astronomy": 1
},"moon_phase": {
"percentIlluminated":"47",
"ageOfMoon":"22",
"phaseofMoon":"Waning Gibbous",
"hemisphere":"North",
"current_time": {
"hour":"14",
"minute":"56"
"sunrise": {
"hour":"7",
"minute":"09"
"sunset": {
"hour":"19",
"minute":"56"
"moonrise": {
"hour":"",
"minute":""
"moonset": {
"hour":"15",
"minute":"24"
"sun_phase": {
"sunrise": {
"hour":"7",
"minute":"09"
"sunset": {
"hour":"19",
"minute":"56"
Re: Dashticz - Module Moonphases - Empty Moonrise
Posted: Wednesday 13 September 2017 15:28
by htilburgs
Just found and article from Wunderground on
https://apicommunity.wunderground.com/w ... g-sometime
moonrise: {
hour: "",
minute: ""
moonset: {
hour: "11",
minute: "46"
This happens when a day does not have a moon rise. In this case, the moon rose yesterday.
And now for the million dollar question "how can we solve this in the source, when this happens" ???
Posted: Wednesday 13 September 2017 15:50
by EdwinK
So ,that was the problem
Posted: Wednesday 13 September 2017 15:52
by htilburgs
Yip, but now the solution....
Haven't found anything yet. I'm looking in the lua script, but nothing works (yet).
Maybe somebody has a great idea??
Posted: Wednesday 13 September 2017 20:47
by htilburgs
Ok, with some help I've changed the part of the script. That should avoid giving an error and in your textsensor would get --:--
-- moonrise
moonriseHour, moonriseMinute = string.match(s, [["moonrise": {"hour":"(%d+)","minute":"(%d+)"]])
if moonriseHour == nil then moonriseHour = '--' end
if moonriseMinute == nil then moonriseMinute = '--' end
if debug then print("Moonrise:\t"..moonriseHour..":"..moonriseMinute) end
-- moonset
moonsetHour, moonsetMinute = string.match(s, [["moonset": {"hour":"(%d+)","minute":"(%d+)"]])
if moonsetHour == nil then moonsetHour = "--" end
if moonsetMinute == nil then moonsetMinute = "--" end
if debug then print("Moonset:\t"..moonsetHour..":"..moonsetMinute) end
Updated Wiki also....
Posted: Wednesday 20 September 2017 20:42
by Jmerino
I just installed the module and I'm doing something wrong because it doesn't show the picture.
It seems that the sensors and the lua script its working fine because all are filled correctly.
I modified the custom.js to include the module but nothing.
I need some help please
Posted: Wednesday 20 September 2017 21:14
by marxkemp
Same here. We must have done something wrong..
Verstuurd vanaf mijn SM-G930F met Tapatalk
Posted: Friday 22 September 2017 7:54
by Jmerino
Solved
Posted: Friday 22 September 2017 8:12
by marxkemp
What did you do?
Posted: Friday 22 September 2017 8:29
by Jmerino
My problem was here:
var _IDXmoonpicture = IDX_Number; //index of the uservariabele MoonPicture
I declared correctly in the code but after a deep revision of the code I detected another declaration in the vars at the beginning of code with 0 value.
Just change this idx with the correct one and delete the new var declared by myself.
Now here is new moon and only show a black circle but it seems will be ok.
Posted: Friday 22 September 2017 13:14
by marxkemp
Ah, yes. Found it.
We have a 5% moon today but i think the picture is wrong now (full black moon)..
Posted: Monday 09 October 2017 10:10
by jimicek
I think there is an error in the moon script: "waardecheck" should be replaced by "is_waxing" to give the correct moon phase picture
Posted: Monday 09 October 2017 23:59
by jvanthof
The Moon Phase module is not showing the images of the moon... I think I have followed all the instructions to the letter. The /var/tmp/phases.tmp file is filled with info. The dummy devices and user variables get filled with information (e.g. the MoonPicture variable contains "moon.89.png") but on the dashticz website: nada...
When I inspect the elements using the developer tools of Safari, it looks like the image is not properly set in the DOM:
<div class="col-xs-12 transbg imgblock imgblock17610" data-id="buttons.UNKNOWN">
<div class="col-xs-12">
<div class="moon"></div>
</div>
</div>
The "buttons.UNKNOWN" doesn't look right...
My CONFIG.js (I thinks there's a typo on the Wiki btw...) contains these lines:
buttons.moon = {width:12, isimage:true, refreshimage:60000, image:'moon'}
and
columns[1] = {}
columns[1]['blocks'] = ['garbage','s1',buttons.moon]
columns[1]['width'] = 5;
Anyone knows what I'm missing?
BTW, infinite credits to all that worked on Domoticz, Dashticz and plugins/addons... I bow to you all!!
Posted: Tuesday 10 October 2017 8:46
by CaesarPL
Posted: Tuesday 10 October 2017 10:20
by EdwinK
CaesarPL wrote: Tuesday 10 October 2017 8:46
Is
properly set?
Looks okay to me.
Posted: Wednesday 11 October 2017 14:13
by jvanthof
Found it!!
It seems the Wiki is slightly outdated:
does not work for me. Replacing it with
did the trick!
PS. I updated the wiki page...
Posted: Wednesday 08 November 2017 21:39
by marxkemp
This is bugging me for some time. How do I show the Maanfase and Maanpercentage in the blocks beneath the moon image?
I guess its adding the IDX with a different icon?
Posted: Thursday 09 November 2017 0:48
by htilburgs
jvanthof wrote: Wednesday 11 October 2017 14:13
Found it!!
did the trick!
Thnx for updating the wiki. Overlooked this one....
Posted: Monday 04 December 2017 20:59
by PeJeWe
Dus this module works without a Wunderground API key?
