Setting Domoticz Server time in Raspberry pi
Posted: Tuesday 12 September 2017 9:57
by cvasantrao
I have installed domoticz on RPi3 and RPi3 shows the correct time. But domoticz time is about 3.5 hrs ahead. Can anybody help?
Re: Setting Domoticz Server time in Raspberry pi
Posted: Tuesday 12 September 2017 9:58
by Trigun
Sudo raspi-config, set time zone. This should work
Posted: Tuesday 12 September 2017 10:56
by SweetPants
cvasantrao wrote: Tuesday 12 September 2017 9:57
Have you installed/configured NTP?
sudo apt-get install ntp
By default it will use a pre-configured NTP server in /etc/ntp.conf
change that to some servers (min 3) at your location
server <ip or domainname NTP server(s)>
sudo service ntp restart
This eventually should sync your clock to NTP, depending on the difference between the NTP server and your raspberry this can take hours/days
Posted: Tuesday 12 September 2017 12:11
by cvasantrao
Yes. My RPi shows the correct time. The problem is with Domoticz time.
Posted: Tuesday 12 September 2017 12:35
by emme
...mmh what about
sudo timedatectl set-timezone Europe/<City>
sudo timedatectl set-ntp true
in domoticz be sure to have setted up the right GPS coordinates
Posted: Wednesday 13 September 2017 4:29
by cvasantrao
Yes. I have set the GPS coordinates right using 'to find your location click here'. The sunrise and sunset timings are also wrong. Tried everything.
Posted: Wednesday 13 September 2017 7:12
by jannl
Hm, the fact that sunrise/sunset times are wrong implies the location setting are wrong. Do you see anything in the logfile(s)?
Verstuurd vanaf mijn SM-G930F met Tapatalk
Posted: Wednesday 13 September 2017 19:06
by SweetPants
cvasantrao wrote: Wednesday 13 September 2017 4:29
Are you really sure you got the right longitude/latitude from the 'click here' search?
Posted: Thursday 14 September 2017 5:21
by cvasantrao
Yes,because i have used these coordinates in arduino for a aquarium controller and i get the sunrise/sunset timings right.
Posted: Monday 01 January 2018 10:53
by axello2
any update on this issue? I seem to have the same problem after I moved my Domoticz installation.
Short answer: fixed it!
Gps coords in Domoticz:
lon: 4.887, lat: 52.383, which is Amsterdam (and correct)
Domoticz 3.8153 claims : SunRise: 07:51, SunSet: 15:36
Weather.com states:
Zonsopgang 08:50
Zonsondergang 16:37
So this simply seems a timezone offset.
Back to the terminal:
date: Mon 1 Jan 10:37:16 CET 2018 (which is correct)
BUT: this was because the timezone was set in the .profile.
I have used the
timedatectl commands by *emme* above and now my Domoticz dashboard shows the correct sunset times!
Also the times in the Dashboard are better.
Thanks, and best wishes for 2018!
Posted: Saturday 19 January 2019 14:50
by leby
emme wrote: Tuesday 12 September 2017 12:35
...mmh what about
Worked on my RPI as well..
Posted: Friday 01 February 2019 16:53
by Rolandet
leby wrote: Saturday 19 January 2019 14:50
...mmh what about
Not wanting to bump a topic for nothing: timedatectl worked for me too.
Tnx
