Setting Domoticz Server time in Raspberry pi
cvasantrao
Post by cvasantrao »
I have installed domoticz on RPi3 and RPi3 shows the correct time. But domoticz time is about 3.5 hrs ahead. Can anybody help?
Trigun
Domoticz version: 4.10717
Re: Setting Domoticz Server time in Raspberry pi
Post by Trigun »
Sudo raspi-config, set time zone. This should work
SweetPants
Post by SweetPants »
cvasantrao wrote: Tuesday 12 September 2017 9:57 Hi,
Have you installed/configured NTP?
sudo apt-get install ntp
By default it will use a pre-configured NTP server in /etc/ntp.conf
change that to some servers (min 3) at your location
server <ip or domainname NTP server(s)>
sudo service ntp restart
This eventually should sync your clock to NTP, depending on the difference between the NTP server and your raspberry this can take hours/days
cvasantrao
Yes. My RPi shows the correct time. The problem is with Domoticz time.
emme
Domoticz version: latest
Post by emme »
...mmh what about
sudo timedatectl set-timezone Europe/<City>
sudo timedatectl set-ntp true
in domoticz be sure to have setted up the right GPS coordinates
"We always done this way"
cvasantrao
Yes. I have set the GPS coordinates right using 'to find your location click here'. The sunrise and sunset timings are also wrong. Tried everything.
jannl
Domoticz version: 2022.2
Post by jannl »
Hm, the fact that sunrise/sunset times are wrong implies the location setting are wrong. Do you see anything in the logfile(s)?
Verstuurd vanaf mijn SM-G930F met Tapatalk
SweetPants
cvasantrao wrote: Wednesday 13 September 2017 4:29 Yes. I have set the GPS coordinates right using 'to find your location click here'. The sunrise and sunset timings are also wrong. Tried everything.
Are you really sure you got the right longitude/latitude from the 'click here' search?
cvasantrao
Yes,because i have used these coordinates in arduino for a aquarium controller and i get the sunrise/sunset timings right.
axello2
Target OS: OS X
Post by axello2 »
any update on this issue? I seem to have the same problem after I moved my Domoticz installation.
Short answer: fixed it!
Gps coords in Domoticz:
lon: 4.887, lat: 52.383, which is Amsterdam (and correct)
Domoticz 3.8153 claims : SunRise: 07:51, SunSet: 15:36
Weather.com states:
Zonsopgang 08:50
Zonsondergang 16:37
So this simply seems a timezone offset.
Back to the terminal:
date: Mon 1 Jan 10:37:16 CET 2018 (which is correct)
BUT: this was because the timezone was set in the .profile.
I have used the timedatectl commands by *emme* above and now my Domoticz dashboard shows the correct sunset times!
Also the times in the Dashboard are better.
Thanks, and best wishes for 2018!
leby
Post by leby »
emme wrote: Tuesday 12 September 2017 12:35 ...mmh what about
Worked on my RPI as well..
/lennart
Rolandet
Domoticz version: 2021.1
Post by Rolandet »
leby wrote: Saturday 19 January 2019 14:50
Not wanting to bump a topic for nothing: timedatectl worked for me too.
Tnx
Custodes Septentrionum
