Manufacturer, ID and Type data lost on reboot
philchillbill
Post by philchillbill »
I notice about once every two weeks or so that if I reboot the Ubuntu NUC on which Domoticz is running, some of the data in my z-wave configuration is lost (Manufacturer, ID and Type all become blank or zero). Sometimes it happens for all my devices, at other times only for my Neo Coolcam door/window switches. If I reboot Domoticz several times and look in the hardware tab at z-wave devices, sometimes the table is fully blank, sometimes it's partially-populated.
Deleting the zwcfg_ file in /Config helps sometimes, not at others. In other words, the problem does not seem very reproducible ;) I've had it for months and it happens with stable and beta versions of Domoticz.
Anybody got any ideas why this happens?
ulf_slask
Re: Manufacturer, ID and Type data lost on reboot
Post by ulf_slask »
Hi.
I have the same problem as you described!
Skickat från min F5121 via Tapatalk
philchillbill
I've played with this further and have found that if I (1) stop the Domoticz service, (2) overwrite the /Config/zwcfg_ file with a known-good saved version, and (3) restart Domoticz all is well until the next reboot of the NUC. So it seems as if upon a reboot of the system that the zwcfg_ file is being corrupted with bad data. Does Domoticz just receive this data from ozwcp untouched or does Domoticz create this file from what it gets 'told' by ozwcp?
