Blinds percentage value Update
mehdiakrim
Post by mehdiakrim »
Hello
I use this lua Script to controle blinds, I take the blinds bercentage value from dashboard and send it to my IPX800 via API.
val=  tonumber((otherdevices_svalues['Volet Salon TV']));
val1=101-val
if (devicechanged['Volet Salon TV'])
 then
--then val=  tonumber((otherdevices_svalues['VR']));
str= "http://192.168.1.152/api/xdevices.json?SetVR03="..val1
 commandArray['OpenURL']= str
if devicechanged['Volet Salon TV'] == 'On' then
     str1= "http://192.168.1.152/api/xdevices.json?SetVR03=0"
     commandArray['OpenURL']= str1
if devicechanged['Volet Salon TV'] == 'Off' then
     str1= "http://192.168.1.152/api/xdevices.json?SetVR03=100"
The probleme is when i get Pushes from my automate (ipx800) indication the current state of my blinds like this one for example :
http://ip:8080/json.htm?type=command&pa ... svalue=Off
it triggers the script and the blinds start moving again . its like a loop
So my question is : is there a way to change the cursor or (on/off) on my blinds icon without triggering the lua script related to it
Thank you
morilm
Target OS: OS X
Re: Blinds percentage value Update
Post by morilm »
You should try the "update device":
commandArray = {['UpdateDevice'] = otherdevices_idx[device_name]..'|0|0'}
first 0 is the nvalue, 0 = off, 1 = on
Second 0 is the svalue. Some switches use it for different values, like blind %
This way the corresponding event of the device will not be triggered
Hope it helps
Miguel
