LUA Script Error
Andree
LUA Script Error
Post by Andree »
Hi @all
i've find this Lua script (sorry I don't remember where) for summing consumption from each sensor in one dummy sensor.
This script work fine but sometimes (every minutes) generate an error in LOG on the line 180.
Someone can help me?
Script
-- Domoticz IDX and names of the needed devices
local DeviceName1 = "Consumo Luce Specchio Bagno"
local DeviceName2 = "Consumo Luce Bagno"
local DeviceName3 = "Consumo Luci Scale"
local DeviceName4 = "Consumo Luci Cucina"
local DeviceName5 = "Consumo Luci Parete Sala"
local DeviceName6 = "Consumo Lampada Sale"
local DeviceName7 = "Consumo Luci Camera"
local DeviceName8 = "Consumo Frigo"
local DeviceName9 = "Consumo Lavatrice"
local DeviceName10 = "Consumo Lavastoviglie"
local DeviceName11 = "Consumo HT Camera"
local DeviceName12 = "Consumo TV Sala"
local DeviceName13 = "Consumo HT Sala"
local DeviceName14 = "Consumo Cam Frigo"
local DeviceName15 = "Consumo Cam Pianta"
local DeviceName16 = "Consumo Cam Stufa"
local ConsumptionIDX = 538           -- IDX of the energy device that shows calculated Consumption
local ConsumptionDeviceName = "Consumo Totale"       -- Name of the energy device that shows calculated Consumption
-- Script parameters
Energy1 = 0 -- in Watt hours
Power1 = 0    -- in Watts
Energy2 = 0   -- in Watt hours
Power2 = 0   -- in Watts
Energy3 = 0 -- in Watt hours
Power3 = 0    -- in Watts
Energy4 = 0   -- in Watt hours
Power4 = 0   -- in Watts
Energy5 = 0 -- in Watt hours
Power5 = 0    -- in Watts
Energy6 = 0   -- in Watt hours
Power6 = 0   -- in Watts
Energy7 = 0   -- in Watt hours
Power7 = 0   -- in Watts
Energy8 = 0   -- in Watt hours
Power8 = 0   -- in Watts
Energy9 = 0   -- in Watt hours
Power9 = 0   -- in Watts
Energy10 = 0   -- in Watt hours
Power10 = 0   -- in Watts
Energy11 = 0   -- in Watt hours
Power11 = 0   -- in Watts
Energy12 = 0   -- in Watt hours
Power12 = 0   -- in Watts
Energy13 = 0   -- in Watt hours
Power13 = 0   -- in Watts
Energy14 = 0   -- in Watt hours
Power14 = 0   -- in Watts
Energy15 = 0   -- in Watt hours
Power15 = 0   -- in Watts
Energy16 = 0   -- in Watt hours
Power16 = 0   -- in Watts
EnergyConsumption = 0    -- in Watt hours
PowerConsumption = 0    -- in Watts
Debug = "NO"       -- Turn debugging on ("YES") or off ("NO")
-- Lua Functions
function update(device, id, power, energy, index)
   commandArray[index] = {['UpdateDevice'] = id .. "|0|" .. power .. ";" .. energy}
-- CommandArray
   Power1, Energy1 = otherdevices_svalues[DeviceName1]:match("([^;]+);([^;]+)")
   if Debug=="YES" then
      print("  ----- ".. DeviceName1 .. "Power = " .. Power1 .. " W");
      print("  ----- ".. DeviceName1 .. "Energy = " .. Energy1 .. " Wh");
   Power2, Energy2 = otherdevices_svalues[DeviceName2]:match("([^;]+);([^;]+)")
      print("  ----- ".. DeviceName2 .. "Power = " .. Power2 .. " W");
      print("  ----- ".. DeviceName2 .. "Energy = " .. Energy2 .. " Wh");
   Power3, Energy3 = otherdevices_svalues[DeviceName3]:match("([^;]+);([^;]+)")
      print("  ----- ".. DeviceName3 .. "Power = " .. Power3 .. " W");
      print("  ----- ".. DeviceName3 .. "Energy = " .. Energy3 .. " Wh");
   Power4, Energy4 = otherdevices_svalues[DeviceName4]:match("([^;]+);([^;]+)")
      print("  ----- ".. DeviceName4 .. "Power = " .. Power4 .. " W");
      print("  ----- ".. DeviceName4 .. "Energy = " .. Energy4 .. " Wh");
   Power5, Energy5 = otherdevices_svalues[DeviceName5]:match("([^;]+);([^;]+)")
      print("  ----- ".. DeviceName5 .. "Power = " .. Power5 .. " W");
      print("  ----- ".. DeviceName5 .. "Energy = " .. Energy5 .. " Wh");
   Power6, Energy6 = otherdevices_svalues[DeviceName6]:match("([^;]+);([^;]+)")
      print("  ----- ".. DeviceName6 .. "Power = " .. Power6 .. " W");
      print("  ----- ".. DeviceName6 .. "Energy = " .. Energy6 .. " Wh");
   Power7, Energy7 = otherdevices_svalues[DeviceName7]:match("([^;]+);([^;]+)")
      print("  ----- ".. DeviceName7 .. "Power = " .. Power7 .. " W");
      print("  ----- ".. DeviceName7 .. "Energy = " .. Energy7 .. " Wh");
   Power8, Energy8 = otherdevices_svalues[DeviceName8]:match("([^;]+);([^;]+)")
      print("  ----- ".. DeviceName8 .. "Power = " .. Power8 .. " W");
      print("  ----- ".. DeviceName8 .. "Energy = " .. Energy8 .. " Wh");
   Power9, Energy9 = otherdevices_svalues[DeviceName9]:match("([^;]+);([^;]+)")
      print("  ----- ".. DeviceName9 .. "Power = " .. Power9 .. " W");
      print("  ----- ".. DeviceName9 .. "Energy = " .. Energy9 .. " Wh");
   Power10, Energy10 = otherdevices_svalues[DeviceName10]:match("([^;]+);([^;]+)")
      print("  ----- ".. DeviceName10 .. "Power = " .. Power10 .. " W");
      print("  ----- ".. DeviceName10 .. "Energy = " .. Energy10 .. " Wh");
   Power11, Energy11 = otherdevices_svalues[DeviceName11]:match("([^;]+);([^;]+)")
      print("  ----- ".. DeviceName11 .. "Power = " .. Power11 .. " W");
      print("  ----- ".. DeviceName11 .. "Energy = " .. Energy11 .. " Wh");
   Power12, Energy12 = otherdevices_svalues[DeviceName12]:match("([^;]+);([^;]+)")
      print("  ----- ".. DeviceName12 .. "Power = " .. Power12 .. " W");
      print("  ----- ".. DeviceName12 .. "Energy = " .. Energy12 .. " Wh");
 Power13, Energy13 = otherdevices_svalues[DeviceName13]:match("([^;]+);([^;]+)")
      print("  ----- ".. DeviceName13 .. "Power = " .. Power13 .. " W");
      print("  ----- ".. DeviceName13 .. "Energy = " .. Energy13 .. " Wh");
   Power14, Energy14 = otherdevices_svalues[DeviceName14]:match("([^;]+);([^;]+)")
      print("  ----- ".. DeviceName14 .. "Power = " .. Power14 .. " W");
      print("  ----- ".. DeviceName14 .. "Energy = " .. Energy14 .. " Wh");
   Power15, Energy15 = otherdevices_svalues[DeviceName15]:match("([^;]+);([^;]+)")
      print("  ----- ".. DeviceName15 .. "Power = " .. Power15 .. " W");
      print("  ----- ".. DeviceName15 .. "Energy = " .. Energy15 .. " Wh");
   Power16, Energy16 = otherdevices_svalues[DeviceName16]:match("([^;]+);([^;]+)")
      print("  ----- ".. DeviceName16 .. "Power = " .. Power16 .. " W");
      print("  ----- ".. DeviceName16 .. "Energy = " .. Energy16 .. " Wh");
   -- Calculate consumption
   PowerConsumption = Power1 + Power2 + Power3 + Power4 + Power5 + Power6 + Power7 + Power8 + Power9 + Power10 + Power11 + Power12 + Power13 + Power14 + Power15 + Power16
      print("  ----- PowerConsumption = " .. PowerConsumption .. " W");
   EnergyConsumption = Energy1 + Energy2 + Energy3 + Energy4 + Energy5 + Energy6 + Energy7 + Energy8 + Energy9 + Energy10 + Energy11 + Energy12 +Energy13 + Energy14 + Energy15 + Energy16
      print("  ----- EnergyConsumption = " .. EnergyConsumption .. " Wh");
   -- Update comsumption device in Domoticz
   if devicechanged[DeviceName1] or devicechanged[DeviceName2] or devicechanged[DeviceName3] or devicechanged[DeviceName4] or devicechanged[DeviceName5] or devicechanged[DeviceName6] or devicechanged[DeviceName7] or devicechanged[DeviceName8] or devicechanged[DeviceName9] or devicechanged[DeviceName10] or devicechanged[DeviceName11] or devicechanged[DeviceName12] or devicechanged[DeviceName13] or devicechanged[DeviceName14] or devicechanged[DeviceName15] or devicechanged[DeviceName16] then
      update(ConsumptionDeviceName, ConsumptionIDX, PowerConsumption, EnergyConsumption,1)
Error
2017-09-06 12:13:00.144 Error: EventSystem: in Consumo Totale: [string "---------------------------------------------..."]:180: attempt to index global 'devicechanged' (a nil value)
jvdz
Domoticz version: 4.107
Re: LUA Script Error
Post by jvdz »
Set the events to act upon from ALL to DEVICES.
Jos
Andree
Post by Andree »
Thx Work!
vicho
Post by vicho »
Andree wrote: Wednesday 06 September 2017 17:16Thx Work!
Can you share the working one script. I have the same problem and can't solve it.
jvdz
Post by jvdz »
It has nothing to do with the script itself. You need to set the trigger correctly in de editor!
vicho
Post by vicho »
jvdz wrote: Friday 17 June 2022 21:21 It has nothing to do with the script itself. You need to set the trigger correctly in de editor!
Sorry, but can you give me more info how to do that. I can't find where to set the triger for this script. This is the scrip that I use to compute Shelly 3EM total usage and it work and compute the total energy. But ger this error at some time. I think it trigger on changes of some power or energy device.
local DeviceName1 = "EVN P0"
local DeviceName2 = "EVN P1"
local DeviceName3 = "EVN P2"
local ConsumptionIDX = 64  			-- IDX of the energy device that shows calculated Consumption
local ConsumptionDeviceName = "EVN Total" 		-- Name of the energy device that shows calculated Consumption
-- Lua Functions
-- CommandArray
	if devicechanged[DeviceName1] or devicechanged[DeviceName2] or devicechanged[DeviceName3] then
		update(ConsumptionDeviceName, ConsumptionIDX, PowerConsumption, EnergyConsumption, 1)
jvdz
Post by jvdz »
vicho wrote: Sunday 19 June 2022 9:19 Sorry, but can you give me more info how to do that. I can't find where to set the triger for this script.
As I stated: In the Editor page, where you have edited this script you can define the Event it triggers on:
Set the appropriate event type as shown in the Wiki:
https://www.domoticz.com/wiki/Events#Us ... icz_itself
vicho
Post by vicho »
jvdz wrote: Sunday 19 June 2022 9:40 As I stated: In the Editor page, where you have edited this script you can define the Event it triggers on:
Thank you a lot. Finaly I find it :). I never seen this big box for trigerr choose for last 6-7 years of ussing Domoticz :).
jvdz
Post by jvdz »
Well it really is important to have a script only trigger with the right event or else your system will start doing things at the wrong times or get pretty busy! ;)
vicho
Post by vicho »
jvdz wrote: Sunday 19 June 2022 13:37 Well it really is important to have a script only trigger with the right event or else your system will start doing things at the wrong times or get pretty busy! ;)
This is the only one script on LUA that I use and never seen that I can choose the trigers. Other some scripts that I use are writen on dzVents and all work well.
BTW I start to do all from the beginign before one or maybe two weeks. I update my domoticz (use it from 6-7 years ago) and it crash.
I have lots of mysensors 2,4gz + mysensors 866mhz + 433MHZ RFX (heat pump + UFH for my house + solar pannel for hot water + some energy meters). Now I start to install Shelly 3em and 5x 1kW inverters + 6Kw solar panels + 48V power wall. This project is still in progress.
Alll work well, but i never seen before, that I can to choose the trigers for LUA scripst. Thank you again!
p.s. Sorry for my bad English :)
