Hi everyone. i try to add manualy a device via the RFlink button add new device.
Domotiz says new device created however its not listed under the device tab.
Im using this command : 20;4C;ANSLUTA;ID=d3d2;SWITCH=0;CMD=ON; and yes when changing the 20 to 10 it does work even through domoticz. but as said it does not create a new device.
Domoticz does not create new RFlink device
- sincze
- Domoticz version: 2024.4
Re: Domoticz does not create new RFlink device
Same issue here.stingone wrote: Monday 04 September 2017 17:24 Hi everyone. i try to add manualy a device via the RFlink button add new device.
I can PAIR, SWITCH ON / OFF the led strip with the 10;MiLightv1;0abc;04;0000;OFF command.
However no device is created in Domoticz. Running V3.8153 on a synology and R46 for RFLINK.
Pass2php
USB: RFXCom, ZWave, Sonoff 3
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
Solar: Omnik, PVOutput
Sensors: You name it I got 1.
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
Type Ansluta without capitals......got a message from RFlink now it works
Users browsing this forum: Bing [Bot], Google [Bot] and 1 guest
