lua script trigger
tiga
lua script trigger
Post by tiga »
i have this lua script i made
if (devicechanged['zonnescherm'] == 'On' and otherdevices['auto omhoog zonnescherm ondergang'] == 'On' and otherdevices['telefoon 1'] == 'Off' and otherdevices['telefoon 2'] == 'Off') then
    commandArray['auto zonnescherm omhoog']='Active'
    print ('zonnescherm gaat vanzelf omhoog')
    commandArray['auto zonnescherm omhoog']='Inactive'
    print ('zonnescherm gaat niet vanzelf omhoog')
i run it in DEVICE mode
but it gets triggerd every vew seconds.
i want it to run only when one of the devices is changed in state.
i use it to close my "zonnescherm" 30 minutes befor sunset
lonebaggie
Re: lua script trigger
Post by lonebaggie »
Use a dzVents script and trigger it to start a 30 mins before sunset
see
http://www.domoticz.com/forum/viewtopic.php?t=19171
Nautilus
Post by Nautilus »
I think the biggest problem in your script is the "else"-part. You have basically told the script to run on each device change and execute one of the two parts of the script. The first part is executed only when the changed device is 'zonnescherm' and it changes to 'On' and the second part (= else) is then run in all other cases (= every time a device changes its state except if it is 'zonnescherm' turning 'On').
So, you need to think in which situation you want to run the second part:
And come up with proper condition. That said, I don't quite understand how this script relates to "i use it to close my "zonnescherm" 30 minutes befor sunset" - I guess you are you triggering that with a normal device timer? Maybe something like this would work:
elseif devicechanged['zonnescherm'] == 'Off' then
...but you might need to define it even more strictly than this - depending when you want it to run :)
