5ch led WiFi controller
kurniawan77
Post by kurniawan77 »
Does anyone know if this is based on esp8266?
Sent from my Nexus 6P using Tapatalk
swevm
Domoticz version: 8718
Re: 5ch led WiFi controller
Post by swevm »
Looks like a nice box.
Do you mind including where you found this one?
https://github.com/mertenats/Arilux_AL-LC0X
I believe the unit in your picture is named has a model name that end with "06".
/Magnus
Domoticz on RPi3 with Razberry: 10xZME WALLC-S, 14x Fib Switch, 6x Fib Wallplug, 1x Fib Motion Sensor, 2x Fib Smoke Sensor, 1x Fib Universal sensor (with 1-wire), 3x SwiidInter cordsw, ESPEasy [1-wire and relay], Kodi, Node-Red [Onkyo NR-828, UI etc]
kurniawan77
I found it here...
Original 16Million colors Wifi 5channels RGB/WW/CW led controller smartphone control music and timer mode wifi led controller
http://s.aliexpress.com/ErMvE7vQ
(from AliExpress Android)
I thought maybe I should ask around before I buy them. Maybe there are some who already bought them?
airmarshall
Post by airmarshall »
I've purchased a few of these in hope of getting them to work with domoticz. They are not esp8266 devices, they use the Hi-Flying LPB-100 chip, information and datasheets are available here:
http://www.hi-flying.com/products_detai ... Id=52.html
The devices does have a web interface but the default username and password have been changed, so I haven't been able to get in. If we are able to get access then we can learn more about what they are running and possibly update OTA to a firmware that will give us what we want.
The devices use the mobile app 'MagicHome' for control, so some packet sniffing might also shed some light on what we need to do to get these working in domoticz.
I've tried adding the device as a limitlessled unit, but that doesn't work. I'll try the Arilux plugin but I doubt that will work either as the unit isn't esp8266 based.
airmarshall
Adding the device as an RGBW Arilux AL-LC0x device does provide very basic on/off control of the white channel only. There is no colour or brightness control whatsoever, so some more work is required, but it seems the basic framework for control of the box without firmware modifications does exist.
Jan Jansen
Domoticz version: Stable
Post by Jan Jansen »
Perhaps the following link is useful: https://www.youtube.com/watch?v=XhhxWJSTwR0
