Sunset and sunrise trigger troubles
dk78
Post by dk78 »
I'm trying to close and open my curtains with the timer triggers sunset and sunrise. With sunset it's working, but with sunrise it won't. I've testing if the state is Open\Closed or On\Off and know that it's Open\Closed. So the curtains are closed with the sunset trigger after 20 minutes, but in the morning the curtains won't open automatically. Is there something I miss?
This is my script:
-- Script wat gordijnen open en dicht doet.
   active = true,
      timer = {'at sunset'},
		  {'at sunrise'}
   execute = function(domoticz, gordijnen)
		local mswitch = domoticz.devices('Masterswitch') -- Masterswitch die script laat uitvoeren of niet
		local gordijnen = domoticz.devices('Gordijnen voor')
      if (gordijnen.state == 'Open') and (mswitch.levelName == 'Automatisch') then
         gordijnen.close().afterMin(20)
	  elseif (gordijnen.state == 'Closed') and (mswitch.levelName == 'Automatisch') then
		 gordijnen.open().afterMin(15)
I'm running Domoticz on a RPi 2 with version V3.8300.
dk78
Re: Sunset and sunrise trigger troubles
Post by dk78 »
Hmm, when I"m looking at the script now, I think I see the issue. Can someone please confirm if it's in the manner to apply multiple timers?
Do I need to do it like this:
		['timer'] = {
			'sunset',
			'sunrise'
dk78
Post by dk78 »
Hmm, this didn't do the trick. I'll try no this method:
		timer = {
			'at sunset',
			'at sunrise'
To bad that it will trigger only twice a day. Hope tomorrow the curtains are open when I wake up.
dk78
Post by dk78 »
Yesterday I tried the following script, but it isn't working. I think it's because of the '(triggerInfo.trigger == 'at sunset')' and '(triggerInfo.trigger == 'at sunrise')'. Is there something I'm doing wrong?
   active = true,
		timer = {
    			'at sunset',
	    		'at sunrise'
      if (gordijnen.state == 'Open') and (triggerInfo.trigger == 'at sunset') and (mswitch.levelName == 'Automatisch') then
         gordijnen.close().afterMin(30)
	  elseif (gordijnen.state == 'Closed') and (triggerInfo.trigger == 'at sunrise') and (mswitch.levelName == 'Automatisch') then
EddyG
Post by EddyG »
Should it not be:
execute = function(domoticz, device, triggerInfo)
dk78
Post by dk78 »
Should that do the trick? I'll try it today at sunset. Thanks!
