Device Snooze [Solved]
Wob76
Post by Wob76 »
Still fairly new to Domoticz and looking for some direction, I have managed to use dzVents to automate a few things with my AC, now I want to add a snooze function, before I go and look at a long script to do this, is there an easier option I am missing?
I have a wireless switch that is linked to Domoticz, it has multiple press options (Click, Double Click, Long Press, etc).
At first I was thinking of just using a scene to say turn the AC on then off after X min, but that seems a little limited.
Then I considered looking at some time function within dventz, say setting .PowerOn.forMin(30) but I read a post that said the timer can not be cancelled once it is issued. I would like to be able to add time or disable the timer.
So now I am thinking I could have the Switch record a time when Clicked, then turn off when it has been 30 min, and the same for a double click, but make it 60 min, and if I long press have the timer cancel.
It would be nice to have the script just add another 30min to the existing time for each press.
I am thinking of using my RGB light to indicate the timer is on, and use a different colour for the 30min\60min timer, or maybe just flash it to indicate the timer has been set. My partner doesn't want to open the app. But I would like a counter, so linking it back to a dummy counter would be nice.
Looking forward to thoughts from the experts ;)
Thanks,
Wob
BakSeeDaa
Re: Device Snooze
Post by BakSeeDaa »
Wob76 wrote: Thursday 17 August 2017 6:40 ...
Looking forward to thoughts ...
Hi Wob
What if you use 2 script level persistent variables in your script.
singleClick = { history = true, maxItems = 10 }
doubleClick = { history = true, maxItems = 10 }
Then, Invoke your script every minute and also each time you click one of your buttons. Every time you click a button you add a new data entry. Then you do some arithmetic to calculate the remaining minutes (without storing the result). Use the timestamp of the first data entry and accumulate the time added by all clicks. Then subtract the current time. If the remaining minutes is <= 0, or if you press the cancel button, do a reset( ) on the data. You can't reset() your data until all accumulated time has been used. Now when you have an accumulated time, turn the AC on or OFF if necessary.
Works in theory, at least in my brain. :D
Wob76
Re: Device Snooze
Post by Wob76 »
Thanks for the reply, I'll give your suggestion a try when I get a chance, and If can wrap my head around it :)
Wob76
Re: Device Snooze
Post by Wob76 »
Finally got around to revisiting this, I have since started using Dashticz and wanted to include a countdown timer to show, Only just started testing my idea, but it seems to work.
I created 2 devices, a selector switch, using the Label Add 15, Add 30, etc, and a text device to use as a countdown timer.
Pushing one of the selector values will add that value to the timer and turn on the "device" if its off, off will reset it to 0, but leave device on.
Script activates both with the selector switch and every minute.
If timer triggered it will take 1 from the countdown timer. This does result in some rounding of the timer as it trigger on the minute, but accurate enough for my needs.
I will look at just linking the push button I have to the above selector values, this enables a little more flexibility to enable both a physical button and some control in the app.
Still testing so I am sure I will modify some more, but thought I would post for anyone else looking for something similar.
-- Switches
local TIMER_SWITCH = "AC Timer Switch"
local TIMER = "AC Timer"
local AC_SWITCH = "Test Switch" -- AC Power
local LOGGING = true
        timer = { "every 1 minutes", },
		devices = {
			TIMER_SWITCH
        local timer_out = domoticz.devices(TIMER)
        local timer = timer_out.text:gsub(' Mins','')
        timer = tonumber(timer)
        local ac_power = domoticz.devices(AC_SWITCH)
        if (item.isDevice) then
            if (item.state ~= "Off") then
                local addtime = item.state:gsub('Add ','')
                domoticz.log('Adding time: '..addtime, domoticz.LOG_ERROR)
                timer = timer + addtime
                timer_out.updateText(timer.." Mins")
                ac_power.switchOn().checkFirst()
                domoticz.log('Turning off timer', domoticz.LOG_ERROR)
                timer = 0
        if (item.isTimer and timer > 0) then
            timer = timer - 1
            if (timer == 0) then
                domoticz.log('Turning the AC Off', domoticz.LOG_ERROR)
                ac_power.switchOff().checkFirst()
                domoticz.devices(TIMER_SWITCH).switchOff().checkFirst()
Wob76
Re: Device Snooze
Post by Wob76 »
Some slight changes,
I should note it was written for 2.41 of dzVents.
Needed to shrink my buttons so reduced from "Add 15" to "+15".
Wanted to have Mins shown Off rather than 0 Mins.
I made the Selector switch silently return to Off, so it actions like a multi toggle switch.
A couple of test runs, happy with how it functions, and code is pretty simple, so hopefully shouldn't need much tweaking.
Scripts has 3 devices,
TIMER_SWITCH = Selector = For Adding Time
TIMER = Text Device = For Storing\Showing Time
AC_SWITCH = Controlled Device = Switch that is actioned.
They look like this in my Mobile Dashitcz Page
-- Switches
local AC_SWITCH = "AC Power"
		devices = {
			TIMER_SWITCH
        local timer = timer_out.text:gsub(" Mins","")
        if (timer ~= "Off") then
            timer = 0
                local addtime = item.state:gsub("+","")
                domoticz.log('Adding time: '..addtime, domoticz.LOG_FORCE)
                item.switchOff().silent()
                domoticz.log('Turning off timer', domoticz.LOG_FORCE)
                timer = 0
                timer_out.updateText("Off")
            timer = timer - 1
                domoticz.log('Turning the AC Off', domoticz.LOG_FORCE)
