If Then
bing69
If Then
Post by bing69 »
Another problem. The first IF THEN works. The second not. And I do not know why ??? :oops:
    active = true,
        devices = {
            'Voordeur',
            'Pir_Gang2',
            'Pir_Gang'
    execute = function(domoticz,Voordeur)
            local Pir_gang = domoticz.devices('Pir_Gang')
            local Pir_gang2 = domoticz.devices('Pir_Gang2')
            local BridgeLamp = domoticz.devices('Bridge Lamp')
            local gang = domoticz.devices('Gang')
            local zonondergang = domoticz.devices('zonondergang')
        if (Voordeur.state == 'Open') and (zonondergang.state == 'On')  then
            gang.switchOn()
            BridgeLamp.switchOn()
            BridgeLamp.switchOff()
            gang.switchOff().afterSec(30)
        if (Voordeur.state == 'Open') and (zonondergang.state == 'Off') then
mivo
Re: If Then
Post by mivo »
I think there is a problem with IF conditions and ELSE parts of these conditions. When first IF is evaluated as true (Voordeur.state == 'Open') and (zonondergang.state == 'On'), this part is executed:
gang.switchOn()
But second IF condition is inverse of first in some cases (Voordeur.state == 'Open') and (zonondergang.state == 'Off'), so ELSE part can be executed also in same script run:
Commands from dzVents (LUA) are passed to Domoticz after all scripts finishes, so last command for same device wins - BridgeLamp.switchOff() in this case.
You need to better figure out possible states of devices and then modify IF conditions - maybe nested IFs, or IF..ELSEIF will solve your problem.
My toys:
Raspberry Pi 3 + UPS PIco HV3.0 A Stack
Minibian (Raspbian Jessie) + Domoticz beta
RFLink 433 Gateway, 1wire DS18B20 temp sensors (GPIO)
RaZberry module + 2x Comet Z-Wave + Z-wave socket
Plugins: WeMo Switch, UPS PIco HV3.0A on GitHub
bing69
Re: If Then
Post by bing69 »
Thanks, fixit now!
