User Variables in DZVents
- lonebaggie
Im having real problems understanding dzVents and the tables structures i'm trying to convert my Lua scripts and failing miserably.
what is the dzVents equivalent of :-
ur = uservariables["LW-Setting"]
i have tried
local ur = domoticz.variables('LW-Setting")
and countless other variants . I cannot find an example of manipulating user variables in dzVents
sorry for the stupid question , but i've wasted load of time on something so simple
i have tried
randytsuch
Re: User Variables in DZVents
active = true,
timer = {'Every 10 minutes on mon,tue,wed,thu,fri'}
execute = function(domoticz)
-- check time of the day
if (domoticz.time.isDayTime and domoticz.variables('myVar').value == 10) then
domoticz.variables('anotherVar').set(15)
--activate my scene
domoticz.setScene('Evening lights', 'On')
if (domoticz.devices('My PIR').lastUpdate.minutesAgo > 5) then
domoticz.devices('Bathroom lights').switchOff()
}So did you try something like ur.value ? That should read the current value.
And ur.set(new value) to set ur to a new value.
Also, what kind of variable is ur? I've used time and integers and strings
Also, if you search for "Variable object API" in the domoticz wiki, it describes all the attributes for a user variable.
Randy
- lonebaggie
Thank you . Miised that example
Finally I see the light. What Im trying to do is trigger the dzVents event to run from a table which is created from the contents of a user variable. The user variable contains a list of Idx numbers for devices separated by a "|" terminator. I convert the uservariable contents into a table using the "|" as a delimiter
However I cannot call the domoticz.variables('myvar').value outside of the execute function.
what I want to end up with is
Where IDNums is a table of Idx numbers . Is this possible ?
devices = IDNums
randytsuch
I figured this out last night
Again, from the wiki
The on-section holds all the events/triggers that are monitored by dzVents. If any of the events or triggers matches with the current event coming from Domoticz then the execute part of the script is executed. The on-section has four kinds of subsections that can all be used simultaneously! :
devices = { ...}: this is a list of devices. Each device can be: The name of your device between string quotes. You can use the asterisk (*) wild-card here e.g. PIR_* or *_PIR. E.g.: devices = { 'myDevice', 'anotherDevice', 123, 'pir*' }
The index (idx) of your device (the name may change, the index will usually stay the same, the index can be found in the devices section in Domoticz),
The name/idx of your device followed by a time constraint (similar to what you can do): ['myDevice'] = { 'at 15:*', 'at 22:** on sat, sun' } The script will be executed if myDevice was changed and it is either between 15:00 and 16:00 or between 22:00 and 23:00 in the weekend.
timer = { ... }: a list of time triggers like every minute or at 17:*. See below.
variables = { ... }: a list of user variable-names as defined in Domoticz ( Setup > More options > User variables). If any of the variables listed here changes, the script is executed.
security = { domoticz.SECURITY_ARMEDAWAY, domoticz.SECURITY_ARMEDHOME, domoticz.SECURITY_DISARMED}: a list of one or more security states. If the security state in Domoticz changes and it matches with any of the states listed here, the script will be executed. See /path/to/domoticz/scripts/dzVents/examples/templates/security.lua for an example. See Security Panel for information about how to create a security panel device.
So if you add a new sub section to the on section, with
variables = { domoticz.variables('LW-Setting")
Then your script will be called whenever you change the value of LW-Setting in the user variable page.
dannybloe
Sorry but you don't have access to the domoticz collections when defining the on-triggers. So you cannot do something like this
The reason for this is that the domoticz object hasn't been initialized at that point out of performance reasons as for each and every event that happens in Domoticz, all on-sections for all scripts are evaluated so this has to be as light-weight as possible.
So, you have to do something else to make this work. There are many ways you could do this and one is probably better than another. I guess the question is more: what do you try to achieve that requires you to use uservariables for this? You can create wild-card triggers in the on-section for instance or you can use create a table of id's inside your script at the top of the script file which makes it even easier to maintain as you can already manage and write the script from inside Domoticz' GUI. No need to do nasty string splitting with separators etc. That stuff only slows down things.
devices = { domoticz.variables('bla').value }
- lonebaggie
Thanks for everyone's help. I appreciate everybody's time taken in explaining my poor grasp of DZVents
I realise now I can only use domoticz object in the execute function
pvklink
- Domoticz version: latest b
@dannybloe
How can you set the variabele 'bla' with value 'red' ?
Jablotron connection, Ikea
dannybloe
pvklink
I did, perhaps we are not all as smart as persons that programm daily...
This is my first dzevents script, my lua script works perfect.
The only thing that does not work is to read a user variabele and to change it...
1. read, like {domoticz.variables('denonstatus').value} -- denon on off
2. change it state by {domoticz.variabele('denonstatus')} = 'On'
Peter
script
Peter
script
active = true,
devices = {
'denon_volume'
execute = function(domoticz, denon_volume)
IP = domoticz.variables('ipdenon').value -- ip adress denon receiver
IPTV = domoticz.variables('iptv').value -- ip adress denon receiver
TVSTATUS=os.execute('ping -c1 ' .. IPTV)
--IP='192.168.20.26'
--IPTV='192.168.20.24'
MAXLEVEL=-30
DEFLEVEL=-40 --nog even checken of dit juist is
if (denon_volume.state == 'On') then --denon wordt op aan gezet
os.execute ("curl http://" .. (IP) .. "/MainZone/index.put.asp?cmd0=PutZone_OnOff%2FON" ); -- zet denon aan
--domoticz.variabele('denonstatus') = 'On' -- zet variabele ook op aan
if TVSTATUS then -- tv staat aan
denon_source.switchSelector(20).AFTER(2) -- zet versterker op tv (switch source gaat dan ook op tv)
denon_mixer.switchSelector(10).AFTER(2) -- set versterker op stereo
else -- tv staat uit, dus radio aan
denon_source.switchSelector(10).AFTER(2) -- set versterker op radio (switch source gaat dan ook op tv)
denon_radio.switchSelector(10).AFTER(2) -- set radio zender sky
denon_mixer.switchSelector(20).AFTER(2) -- set versterker op mch stereo
os.execute ("curl http://" .. (IP) .. "/MainZone/index.put.asp?cmd0=PutMasterVolumeSet/" .. (DEFLEVEL)); --set standaard volume zetten
domoticz.log('test2 aanzetten denon')
elseif (denon_volume.state == 'Off') then --denon wordt uit gezet
os.execute ("curl http://" .. (IP) .. "/MainZone/index.put.asp?cmd0=PutZone_OnOff%2FOFF" ); -- zet denon uit
--domoticz.variabele('denonstatus') = 'Off'
domoticz.log('test2 uitzetten denon')
else --denon geluid wordt harder of zachter gezet
if ({domoticz.variables('denonstatus').value} == 'Off') then -- als denon uitstaat terwijl volume wordt geactiveerd
--domoticz.variabele('denonstatus') = 'On' -- zet status denon aan
domoticz.log('test2 devices aanzetten nav geluidsaanpassing denon')
NewLevel = denon_volume.value - 80 ; -- zet het volume. eerst corrigeren met domoticz scaling
--NewLevel = math.min(NewLevel, 9.5); -- Top Domoticz Scale deze lijkt niet te werken
if tonumber(NewLevel) > MAXLEVEL then -- Peter toegevoegd volume maxlevel
NewLevel = MAXLEVEL -- maximaal geluidsniveau nog checken of dit wel werkt met math.min constructie
end -- einde toevoeging maxvolume
os.execute ("curl http://" .. (IP) .. "/MainZone/index.put.asp?cmd0=PutMasterVolumeSet/" .. (NewLevel)); --set volume
domoticz.log('test2 geluidsaanpassing denon')
Last edited by dannybloe on Thursday 15 February 2018 16:04, edited 3 times in total.
Reason: code block
Reason: code block
dannybloe
well, as the documentation link I just gave you shows:
Thtat's all
That implies:set(value): Tells Domoticz to update the variable.
domoticz.variables('denonstatus').set('On')
pvklink
Yes, that's great!
now to the next error in my logfile ..
pvklink
Do you also have a tip for the next 2 problem. This construct does not work in my scripts/dzvents.
I use this in my old lua scripts
I store ip adresses as characters in user variabels (setip/more options/ user variabeles)
local IPTV = domoticz.variables('iptv').value -- ip adress denon receiver
local TVSTATUS = os.execute('ping -c1 ' .. IPTV)
if TVSTATUS == 'True' then .....
Second problem, i have one device(selector switch) and i need to react to on, off and volume change
i used: devicechanged[RECEIVER_VOLUME] == 'On' or 'Off' or ELSE is a (volume change))
I my current DZvents i use
else seems to be ON or OFF en no volume change
do i use the wrong variable to check the change on/off/volume_change ?
Last edited by pvklink on Thursday 15 February 2018 18:10, edited 1 time in total.
- emme
first of all your sentence will restura True or False, not 'True' or 'False' (it's boolean, not a string
Unfortunately os.execute does NOT return true or false based on the command result, it returns true or false if the command was executed
If you want a ping a device and return its status why don't you use the System Alive Checker (Ping) hardware?
it creates a device switch that states On and off based on its presence done by a ping made from the server
"We always done this way"
pvklink
Ok, i do have a device pinger active, so i can use that! thanks!
