sValues vs Current state - Satel Integra
Posted: Sunday 13 August 2017 18:07
by petecz
I am trying to configure notifications via Pushover for alarm events.
I can only configure notifications for 'Current state' values, not for 'sValues'. What's the difference?
Why there is no 'current state' for few outputs?
How to handle it?
Re: sValues vs Current state - Satel Integra
Posted: Tuesday 15 August 2017 10:21
by petecz
Or I need other ideas for configuring notifications.... Only 'Arm partition' works at the moment.
Why 'text device' hasn't any current state, how to rewrite it from sValue?
Posted: Wednesday 16 August 2017 17:58
by mivo
not everything works in Blockly. This should work in dzVents scripting:
active = true,
logging = {
level = domoticz.LOG_INFO,
-- trigger on device with name
devices = {'Text device'}
-- check text value of device
if device.text == 'ON' then
-- log for debugging purpose
domoticz.log('Text is ON')
-- send notification, more parameters available - see Wiki
domoticz.notify('Text is ON')
Complete syntax of domoticz.notify() function is on Wiki:
https://www.domoticz.com/wiki/DzVents:_ ... object_API:
Posted: Thursday 17 August 2017 8:21
by petecz
hey it works thanks!
Two questions:
1) how to make else construction in dzVents
/something like
active = true,
logging = {
devices = {'Brak zasilania'}
if device.text == 'On' then
domoticz.log('Brak zasilania')
domoticz.notify('Brak zasilania')
else device.text == 'Off' then
domoticz.log('Powrot zasilania')
domoticz.notify('Powrot zasilania')
but it doesn't work
2) Why Pushover is not working, despite the sending is done is logs? /email sending works ok/
Posted: Thursday 17 August 2017 8:39
by mivo
Change
else to this - normal LUA syntax, nothing specific to dzVents:
I have no experience with Pushover - do you set it in Setup / Settings / Notifications ? Does it send message when click on Test ?
Posted: Thursday 17 August 2017 9:57
by petecz
mivo wrote: Thursday 17 August 2017 8:39
Change
Ok, priority must be set as default level is no notification on smartphone
domoticz.notify('Brak zasilania','Informacja z systemu alarmowego',domoticz.PRIORITY_NORMAL)
should be elseif additionally ended as I've got parse errors?
Posted: Thursday 17 August 2017 10:28
by mivo
IF..ELSEIF should be enclosed by "end" - complete condition part of your original script should be:
elseif device.text == 'Off' then
Posted: Monday 16 October 2017 19:55
by fantom
Hi.
Please write post about Satel Integra in this task:
viewtopic.php?f=17&t=4260
I'm author of this module, and sometimes I may help
Fantom
