sValues vs Current state - Satel Integra
petecz
Post by petecz »
I am trying to configure notifications via Pushover for alarm events.
I can only configure notifications for 'Current state' values, not for 'sValues'. What's the difference?
Why there is no 'current state' for few outputs?
How to handle it?
petecz
Re: sValues vs Current state - Satel Integra
Post by petecz »
Or I need other ideas for configuring notifications.... Only 'Arm partition' works at the moment.
Why 'text device' hasn't any current state, how to rewrite it from sValue?
mivo
Post by mivo »
not everything works in Blockly. This should work in dzVents scripting:
    active = true,
    logging = {
        level = domoticz.LOG_INFO,
        -- trigger on device with name
        devices = {'Text device'}
        -- check text value of device
        if device.text == 'ON' then
                -- log for debugging purpose
                domoticz.log('Text is ON')
                -- send notification, more parameters available - see Wiki
                domoticz.notify('Text is ON')
Complete syntax of domoticz.notify() function is on Wiki: https://www.domoticz.com/wiki/DzVents:_ ... object_API:
My toys:
Raspberry Pi 3 + UPS PIco HV3.0 A Stack
Minibian (Raspbian Jessie) + Domoticz beta
RFLink 433 Gateway, 1wire DS18B20 temp sensors (GPIO)
RaZberry module + 2x Comet Z-Wave + Z-wave socket
Plugins: WeMo Switch, UPS PIco HV3.0A on GitHub
petecz
Post by petecz »
hey it works thanks!
Two questions:
1) how to make else construction in dzVents
/something like
    active = true,
    logging = {
        devices = {'Brak zasilania'}
        if device.text == 'On' then
                domoticz.log('Brak zasilania')
                domoticz.notify('Brak zasilania')
        else device.text == 'Off' then
                domoticz.log('Powrot zasilania')
                domoticz.notify('Powrot zasilania')
but it doesn't work
2) Why Pushover is not working, despite the sending is done is logs? /email sending works ok/
mivo
Post by mivo »
Change else to this - normal LUA syntax, nothing specific to dzVents:
elseif device.text == 'Off' then
I have no experience with Pushover - do you set it in Setup / Settings / Notifications ? Does it send message when click on Test ?
My toys:
petecz
Post by petecz »
mivo wrote: Thursday 17 August 2017 8:39 Change else to this - normal LUA syntax, nothing specific to dzVents:
Ok, priority must be set as default level is no notification on smartphone ;)
domoticz.notify('Brak zasilania','Informacja z systemu alarmowego',domoticz.PRIORITY_NORMAL)
should be elseif additionally ended as I've got parse errors?
mivo
Post by mivo »
IF..ELSEIF should be enclosed by "end" - complete condition part of your original script should be:
My toys:
fantom
Post by fantom »
Hi.
Please write post about Satel Integra in this task: viewtopic.php?f=17&t=4260
I'm author of this module, and sometimes I may help
Fantom
