2 sensors esp easy - esp12
Posted: Sunday 13 August 2017 0:00
by DaWauZ
How should I connect 2 sensors i2c ?
I have 1 now on the sda and scl and is working fine.
When I add an extra device it is giving me the same gpio pins I am already using. Can I connect the wires of both sensors together? Sounds strange but I don't know exactly.
I tried on other pins but nothing special happens.
BME-280 and BH1750 sensors.
Edit:
I found out that you can use rules to rule the gpio ports. I cant find a good example for ruling 2 sensors, does someone had an example for me?
Re: 2 sensors esp easy - esp12
Posted: Monday 14 August 2017 6:09
by randytsuch
You can connect multiple devices on an I2C bus as long as they have different addresses.
If they are different i2c devices, they should have different addresses.
Posted: Monday 14 August 2017 6:47
by DaWauZ
OK so connecting wires together is nog problem?
Finally I found this wiki and drawings, is it needed to connect the 3v and sda / scl lines and resistors, I will not use a display.
https://www.letscontrolit.com/wiki/inde ... C2%B2C_Bus
by reading it triple times, it seams to be needed, 2 10kohm.
