2 sensors esp easy - esp12
DaWauZ
Post by DaWauZ »
How should I connect 2 sensors i2c ?
I have 1 now on the sda and scl and is working fine.
When I add an extra device it is giving me the same gpio pins I am already using. Can I connect the wires of both sensors together? Sounds strange but I don't know exactly.
I tried on other pins but nothing special happens.
BME-280 and BH1750 sensors.
Edit:
I found out that you can use rules to rule the gpio ports. I cant find a good example for ruling 2 sensors, does someone had an example for me?
Raspberry Pi 2 model B with domoticz
OMV NAS installed on thin client HP T610
Openelec Kodi Mediaplayer on thin client HP T520 (and with multiboot windows 10)
randytsuch
Re: 2 sensors esp easy - esp12
Post by randytsuch »
You can connect multiple devices on an I2C bus as long as they have different addresses.
If they are different i2c devices, they should have different addresses.
DaWauZ
Post by DaWauZ »
OK so connecting wires together is nog problem?
Finally I found this wiki and drawings, is it needed to connect the 3v and sda / scl lines and resistors, I will not use a display.
https://www.letscontrolit.com/wiki/inde ... C2%B2C_Bus
by reading it triple times, it seams to be needed, 2 10kohm.
