How many hours on
Posted: Friday 11 August 2017 10:17
by mongoose
Have had a search but couldnt find anything.
Id like to see how long a switch has been on for. Is this currently possible or something new. If there is a script please point me in the right direction
Would be handy to see how many hours my tv has been on for a day, week etc so I can restrict my kids
how long a door has been open or how long a light has been on. Currently in graphs it displays when on and when off. But it could be extended. Or in a dummy switch.
Re: How many hours on
Posted: Friday 11 August 2017 10:30
by Egregius
I use the lightlog json command to calculate that in PHP, for example my freezer:
echo '<div>
<table class="brander">';
$datas=json_decode(file_get_contents('http://127.0.0.1:8080/json.htm?type=lightlog&idx='.apcu_fetch('idiepvries'),true,$ctx),true);
$status='';$tijdprev=$time;$totalon=0;
if(!empty($datas['result'])){
foreach($datas['result'] as $data){
//6:20:06
$level=$data['Level'];
$tijd=strtotime($data['Date']);
if($tijd<$eendag)break;
$period=($tijdprev-$tijd);
if($data['Status']=='On'){$totalon=$totalon+$period;$style="color:#FF4400";}else{$style="color:#1199FF";}
$tijdprev=$tijd;
//if($status!=$data['Status']){
echo '
<tr>
<td style="'.$style.'">'.$data['Date'].'</td>
<td style="'.$style.'"> '.$data['Status'].' </td>
<td style="'.$style.'"> '.convertToHours($period).'</td>
</tr>';
$status=$data['Status'];
echo '
</table>
</div>
<div class="fix" style="top:18px;left:260px;width:60px;">'.convertToHours($totalon).'</div>';[code]
Posted: Saturday 12 August 2017 2:01
by mongoose
Cool thank you for that.
Can you explain how you are using it? like dummy switch? if so what kind, or outside of domoticz etc?
Cheers
Larry
Posted: Saturday 12 August 2017 6:27
by Egregius
Outside, it's part of php floorplan.
Posted: Sunday 13 August 2017 15:32
by mcestoni
Hola, lo que deseas hacer se puede perfectamente enviando los datos a influx y consultandolos con Grafana.
Desde Grafana puedes calcular todo lo que quieras, incluso enviar alertas despues de un determinado tiempo de uso
Saludos
Posted: Sunday 13 August 2017 15:39
by SweetPants
mcestoni wrote: Sunday 13 August 2017 15:32
Saludos
English please!!!
Posted: Monday 14 August 2017 2:08
by mongoose
He says use Grafana.com
good ol google translate, I would have liked to have it in Domoticz directly.
Posted: Monday 14 August 2017 13:13
by D'rMorris
You can do it in LUA as well.
First create a function that calculates the time difference:
function timedifference (s)
year = string.sub(s, 1, 4)
month = string.sub(s, 6, 7)
day = string.sub(s, 9, 10)
hour = string.sub(s, 12, 13)
t1 = os.time()
return difference
Then you could calculate how long something is on by using this code:
if (devicechanged['TVof yourkids'] == 'On')
then
difference_in_days = math.floor(difference / 86400)
difference_in_hours = math.floor((difference - difference_in_days * 86400) / 3600)
difference_in_minutes = math.floor(((difference - difference_in_days * 86400) - (difference_in_hours * 3600)) / 60)
print('<b style="color:Red">>> Devices ' .. difference_in_days .. ' days, ' .. difference_in_hours .. ' hours and ' .. difference_in_minutes .. ' minutes ago</b>')
Then you could update a virtual text sensor or something with the values in days / hours / minutes.
Posted: Monday 14 August 2017 13:27
by mongoose
Thanks for that! I'll give it a go!
Posted: Monday 11 September 2017 14:35
by Wob76
viewtopic.php?t=18848
Sent from my SM-G935F using Tapatalk
