How many hours on
mongoose
How many hours on
Post by mongoose »
Have had a search but couldnt find anything.
Id like to see how long a switch has been on for. Is this currently possible or something new. If there is a script please point me in the right direction
Would be handy to see how many hours my tv has been on for a day, week etc so I can restrict my kids :lol: how long a door has been open or how long a light has been on. Currently in graphs it displays when on and when off. But it could be extended. Or in a dummy switch.
Egregius
Domoticz version: v2024.7
Re: How many hours on
Post by Egregius »
I use the lightlog json command to calculate that in PHP, for example my freezer:
echo '<div>
		<table class="brander">';
	$datas=json_decode(file_get_contents('http://127.0.0.1:8080/json.htm?type=lightlog&idx='.apcu_fetch('idiepvries'),true,$ctx),true);
	$status='';$tijdprev=$time;$totalon=0;
	if(!empty($datas['result'])){
		foreach($datas['result'] as $data){
		//6:20:06
			$level=$data['Level'];
			$tijd=strtotime($data['Date']);
			if($tijd<$eendag)break;
			$period=($tijdprev-$tijd);
			if($data['Status']=='On'){$totalon=$totalon+$period;$style="color:#FF4400";}else{$style="color:#1199FF";}
			$tijdprev=$tijd;
			//if($status!=$data['Status']){
				echo '
				<tr>
					<td style="'.$style.'">'.$data['Date'].'</td>
					<td style="'.$style.'">&nbsp;'.$data['Status'].'&nbsp;</td>
					<td style="'.$style.'">&nbsp;'.convertToHours($period).'</td>
				</tr>';
				$status=$data['Status'];
	echo '
			</table>
		</div>
		<div class="fix" style="top:18px;left:260px;width:60px;">'.convertToHours($totalon).'</div>';[code]
mongoose
Post by mongoose »
Cool thank you for that.
Can you explain how you are using it? like dummy switch? if so what kind, or outside of domoticz etc?
Cheers
Larry
Egregius
Post by Egregius »
Outside, it's part of php floorplan.
mcestoni
Post by mcestoni »
Hola, lo que deseas hacer se puede perfectamente enviando los datos a influx y consultandolos con Grafana.
Desde Grafana puedes calcular todo lo que quieras, incluso enviar alertas despues de un determinado tiempo de uso
Saludos
SweetPants
Post by SweetPants »
mcestoni wrote: Sunday 13 August 2017 15:32 Hola, lo que deseas hacer se puede perfectamente enviando los datos a influx y consultandolos con Grafana.
Saludos
English please!!! :mrgreen: :mrgreen: :mrgreen:
mongoose
Post by mongoose »
He says use Grafana.com :) good ol google translate, I would have liked to have it in Domoticz directly. :)
D'rMorris
Post by D'rMorris »
You can do it in LUA as well.
First create a function that calculates the time difference:
function timedifference (s)
  year = string.sub(s, 1, 4)
  month = string.sub(s, 6, 7)
  day = string.sub(s, 9, 10)
  hour = string.sub(s, 12, 13)
  t1 = os.time()
  return difference
Then you could calculate how long something is on by using this code:
if (devicechanged['TVof yourkids'] == 'On')
then
difference_in_days = math.floor(difference / 86400)
difference_in_hours = math.floor((difference - difference_in_days * 86400) / 3600)
difference_in_minutes = math.floor(((difference - difference_in_days * 86400) - (difference_in_hours * 3600)) / 60)
print('<b style="color:Red">>> Devices ' .. difference_in_days .. ' days, ' .. difference_in_hours .. ' hours and ' .. difference_in_minutes .. ' minutes ago</b>')
Then you could update a virtual text sensor or something with the values in days / hours / minutes.
mongoose
Post by mongoose »
Thanks for that! I'll give it a go! 🙂
Wob76
Post by Wob76 »
viewtopic.php?t=18848
Sent from my SM-G935F using Tapatalk
