dzVents Wiki in pairs
Posted: Monday 07 August 2017 10:37
by jkimmel
A special kind of persistent variables: history = true[edit]
In some situation, storing a previous value for a sensor is not enough and you would like to have more previous values for example when you want to calculate an average over several readings or see if there was a constant rise or decrease. Of course you can define a persistent variable holding a table:
active = true,
devices = {'MyTempSensor'}
data = {
previousData = { initial = {} }
execute = function(domoticz, sensor)
-- add new data
table.insert(domoticz.data.previousData, sensor.temperature)
-- calculate the average
local sum = 0, count = 0
for i, temp in pairs(domoticz.data.previousData) do
sum = sum + temp
count = count + 1
local average = sum / count
In pairs isn't valid anymore?
Re: dzVents Wiki in pairs
Posted: Monday 07 August 2017 12:25
by dannybloe
You need to use forEach to iterate over the values. See the docs about this.
Posted: Monday 07 August 2017 16:53
by jkimmel
dannybloe wrote:You need to use forEach to iterate over the values. See the docs about this.
I quoted out of the docs!
Posted: Monday 07 August 2017 16:58
by dannybloe
Eh yeah. Guess I didn't get your question. Sorry. What exactly is the problem?
Posted: Tuesday 08 August 2017 17:30
by jkimmel
This quote is from the actual wiki. Docs should be updated, the example is outdated
Posted: Wednesday 09 August 2017 8:25
by DewGew
How do I convert this code from lua to dzVents:
for i, v in pairs(devicechanged) do phone = i end
print('<font color="green">' ..phone.. ' is home</font>')
Posted: Wednesday 09 August 2017 9:36
by dannybloe
domoticz.changedDevices.forEach(function(device)
domoticz.log(device.name .. ' is home', domoticz.LOG_INFO)
end)
RTLM
Posted: Wednesday 09 August 2017 10:10
by DewGew
dannybloe wrote:Code: Select all
end)
RTLM
GREAT Thanks
Edit:
Correct code is:
domoticz.changedDevices().forEach(function(device)
end)
