dzVents Wiki in pairs
jkimmel
Domoticz version: 2021.1
Post by jkimmel »
A special kind of persistent variables: history = true[edit]
In some situation, storing a previous value for a sensor is not enough and you would like to have more previous values for example when you want to calculate an average over several readings or see if there was a constant rise or decrease. Of course you can define a persistent variable holding a table:
        active = true,
            devices = {'MyTempSensor'}
        data = {
            previousData = { initial = {} }
        execute = function(domoticz, sensor)
            -- add new data
            table.insert(domoticz.data.previousData, sensor.temperature)
            -- calculate the average
            local sum = 0, count = 0
            for i, temp in pairs(domoticz.data.previousData) do
                sum = sum + temp
                count = count + 1
            local average = sum / count
In pairs isn't valid anymore?
Rfxcom
Raspi 4
dannybloe
Re: dzVents Wiki in pairs
Post by dannybloe »
You need to use forEach to iterate over the values. See the docs about this.
jkimmel
Post by jkimmel »
dannybloe wrote:You need to use forEach to iterate over the values. See the docs about this.
I quoted out of the docs!
Rfxcom
Raspi 4
dannybloe
Post by dannybloe »
Eh yeah. Guess I didn't get your question. Sorry. What exactly is the problem?
jkimmel
Post by jkimmel »
This quote is from the actual wiki. Docs should be updated, the example is outdated
Rfxcom
Raspi 4
DewGew
Domoticz version: V4.10618
Post by DewGew »
How do I convert this code from lua to dzVents:
for i, v in pairs(devicechanged) do phone = i end
print('<font color="green">' ..phone.. ' is home</font>')
dannybloe
Post by dannybloe »
domoticz.changedDevices.forEach(function(device)
	domoticz.log(device.name .. ' is home', domoticz.LOG_INFO)
end)
RTLM
DewGew
Post by DewGew »
end)
RTLM
GREAT Thanks :)
Edit:
Correct code is:
domoticz.changedDevices().forEach(function(device)
end)
