MiLight Red-Green weakness
Posted: Sunday 06 August 2017 21:22
by thps
He Forum,
if i change the color of my milight-Devices to red, the color is changed to green and otherwhise its the same. I think my NRF24L01 has some problems to deal with red and green.
Any Ideas how to solfe this?
I´m using the R46 Firmware witht the Domoticz Beta Branch.
greetz
THPS
Re: MiLight Red-Green weakness
Posted: Saturday 16 September 2017 23:51
by sebvi
I've got the same problem running the latest stable version (3.8153) with RFlink R47 firmware.
Any help would be much appreciated.
Posted: Sunday 17 September 2017 0:22
by Stuntteam
We are checking the Domoticz part of the code..
Posted: Tuesday 19 September 2017 13:03
by sebvi
I found the following on github.
https://github.com/domoticz/domoticz/pull/1366
It is not clear to me if and which lines have to be changed in the latest version.
Posted: Monday 02 October 2017 11:13
by Milifax
Any news on this? Same problem here with MiLight Led lamps.
Running on version v3.8423
Posted: Saturday 07 October 2017 19:58
by poudenes
sebvi wrote: Saturday 16 September 2017 23:51
How do you use the R47 Firmware with DOmoticz and Milight? I have add my Wifi iBox inside Domoticz and use it with that.
Is it possible to pair them now directly inside domoticz?
Posted: Sunday 08 October 2017 10:30
by sebvi
I control them directly from my rflink with the NRF24L01. I can pair them, but as stated earlier the red and green colours are switched when using the colour slider in domoticz.
Posted: Sunday 08 October 2017 17:45
by djjonesy
this line is added: int iHue = ((255 - pLed->value) + 108) & 0xFF;
and still is in today's code i think the +108 needs correcting so that red and green are good
Posted: Monday 09 October 2017 21:58
by donk7413
I have this issue too
Posted: Monday 09 October 2017 23:02
by Stuntteam
Should be solved for Milight RGBW in the next beta version.
Also corrected for other milight types..but you might need r48 (available soon)
Posted: Tuesday 10 October 2017 16:34
by Milifax
Stuntteam wrote: Monday 09 October 2017 23:02
Works with the latest beta! Great! Thanks!
Posted: Friday 13 October 2017 21:10
by mosjonathan
I alsof conform this is working as expected.
Thanks for the fix
Posted: Wednesday 18 October 2017 15:19
by tlpeter
This is still a problem but for me for the Fibaro RGBW module.
If i select green then i get red and otherwise.
Is this system wide or per protocol?
Posted: Wednesday 18 October 2017 19:13
by Stuntteam
Per protocol.. and it has been fixed for RFlink..
