Call another script possible in LUA ?
sebitop
Post by sebitop »
maybe a stupid question I will ask but is it possible to call a LUA script from another ?
why i'm asking this ? simply because on my side I have several time scripts which are activated every minute, if some of them are used to control the state of some devices, others are scripts running once a day (like blind close or one to define new variable everyday).
then my idea was to run a single script testing the current time and then if the time is equal to launch another complex one.
Yes I could try dzvents but I don't have the time yet to convert all my current scripts
Yes I could run everything in a single script (complex to debug)
thanks for your help
seb
domoticz on Raspberry Pi + RFXcom LAN moded
Blyss / DI.O / ESP / Arduino
georgesattali
Re: Call another script possible in LUA ?
Post by georgesattali »
to call another script, you can use :
dofile('/home/pi/domoticz/scripts/lua/anotherscript.lua')
Bye
GD
sebitop
Post by sebitop »
will try it
merci georges :)
zicht
Domoticz version: 2023.1+
Post by zicht »
You could also use functions, put major stuff there and then call that from a device or time script...
package.path = package.path .. ';' .. 'C:/PROGRA~2/domoticz/scripts/lua/functions.lua;'
local my1 = require ("functions")
example in function.lua
function round(num, numDecimalPlaces)
  if numDecimalPlaces and numDecimalPlaces>0 and num~=nil and num~=0 then
    local mult = 10^numDecimalPlaces
    return math.floor(num * mult + 0.5) / mult
  return math.floor(num + 0.5)
and you can call that in time.lua
x=3.141627890876546
y= round(x,2)
y will contain only 3.14
