first steps
bing69
first steps
Post by bing69 »
Just started the first steps in dzvents. Have many switches with a space in the name. Can I use that? Get an error every time.
In the example in the Wiki there is something I do not understand, i see Room switch and roomSwitch is that right?
active = true,
devices = {
'Room switch'
execute = function(domoticz, roomSwitch)
if (roomSwitch.state == 'On' and domoticz.devices('Living room').temperature > 18) then
domoticz.devices('Another switch').switchOn()
domoticz.notify('This rocks!',
'Turns out that it is getting warm here',
domoticz.PRIORITY_LOW)
tlpeter
Re: first steps
Post by tlpeter »
At the devices you need to enter the device name which you are going to do something with.
The function of just a name i think.
If you put in domoticz. Abc then you need to use Abc for the rest of the script like Abc.state this can be different than the switch name in domoticz.
bing69
Re: first steps
Post by bing69 »
tlpeter wrote:At the devices you need to enter the device name which you are going to do something with.
Thanks, i give 't a try tomorrow!
hekm77
Re: first steps
Post by hekm77 »
Hi. I'm newby in dzVents too.
How can I use domoticz.devices().forEach(function() .. end) instead of for n, Lamp in pairs(Lamps) do .. end in my script?
    active = true,
        devices = {
            'PIR'
    logging = {
        level = domoticz.LOG_ERROR
         local Lamps  = {'Light-1', 'Light-2'}
        if (switch.state == 'On') then
                       if (domoticz.time.matchesRule('at 06:00-08:00')) then
                           domoticz.devices(Lamp).dimTo(10)
bing69
Re: first steps
Post by bing69 »
Yes!! the first (simple) script works.
    active = true,
        devices = {
            'Deur Berging',
            'Deur berging buiten'
    execute = function(domoticz, DeurBerging)
            local DeurBergingBuiten = domoticz.devices('Deur berging buiten')
            local LampBerging = domoticz.devices('Lamp berging')
        if (DeurBerging.state == 'Open') or (DeurBergingBuiten.state == 'Open') then
            LampBerging.switchOn()
            LampBerging.switchOff().afterSec(15)
dannybloe
Re: first steps
Post by dannybloe »
The documentation should give you examples in how to use the forEach() function. Isn't that helping you?
hekm77
Re: first steps
Post by hekm77 »
dannybloe wrote:The documentation should give you examples in how to use the forEach() function. Isn't that helping you?
Not yet, unfortunately. Can you show in my script example?
dannybloe
Re: first steps
Post by dannybloe »
Well, in your case you want to loop over your array of lamp names and that is just a standard lua table/array so you loop is perfectly suited for that. dzVents forEach is if want to loop over all devices or over a set of filtered devices (or over any of the dzVents collections). But in your situstion that is not the case. So I wouldn't change your code.
What I would change is restrict your code differently to the time-frame you wish your PIR to be active. Now you check the current time inside the loop over and over again while all you need to do is:
devices = { ['PIR'] = 'at 06:00-08:00' }
And remove the check in your execute function.
hekm77
Re: first steps
Post by hekm77 »
dannybloe wrote:Well, in your case you want to loop over your array of lamp names and that is just a standard lua table/array so you loop is perfectly suited for that. dzVents forEach is if want to loop over all devices or over a set of filtered devices (or over any of the dzVents collections). But in your situstion that is not the case. So I wouldn't change your code.
Means in my case all is correct.
I use "domoticz.time.matchesRule" function as a condition for turn on a group of lamps at different times with different brightness.
Special thanks for the dzVents!
dannybloe
Re: first steps
Post by dannybloe »
I don't agree. Your if is executed for all lamps in your array. There is no need to evaluate the rule inside your loop as the result is the same for every loop iteration. That's why you can remove it from the loop and do it before the loop. If it evaluates to false there is no need for your loop in the first place. And moving it to the on-section is even better as it won't end up in your log as well as dzVents won't even call your execute function if it doesn't match the time rule.
hekm77
Re: first steps
Post by hekm77 »
dannybloe wrote:I don't agree. Your if is executed for all lamps in your array. There is no need to evaluate the rule inside your loop as the result is the same for every loop iteration. That's why you can remove it from the loop and do it before the loop. If it evaluates to false there is no need for your loop in the first place. And moving it to the on-section is even better as it won't end up in your log as well as dzVents won't even call your execute function if it doesn't match the time rule.
I'm sorry. That was part of the script
    active = true,
        devices = {
            'Холл-Движение'
    logging = {
         local DummyDevice = domoticz.devices('Холл-Dummy')
         local WhiteLamp1  = domoticz.devices('Холл-1')
         local WhiteLamp2  = domoticz.devices('Холл-2')
         local RGBGateway  = domoticz.devices('miШлюз RGB')
         local WhiteLamps  = {'Холл-1', 'Холл-2'}
         local url = "http://user:[email protected]:8080/json.htm?type=command&param=setcolbrightnessvalue&idx=97&hue=36&brightness=5&iswhite=false"
               if ((WhiteLamp1.state == 'Off' and WhiteLamp2.state == 'Off') and DummyDevice.state == 'On') then
                    for n, WhiteLamp in pairs(WhiteLamps) do
                       if (domoticz.time.matchesRule('at 06:00-08:00 on mon, tue, wed, thu, fri')) then
                           domoticz.devices(WhiteLamp).dimTo(10)
                       if (domoticz.time.matchesRule('at 08:00-22:00 on mon, tue, wed, thu, fri')) then
                            domoticz.devices(WhiteLamp).dimTo(100)
                       if (domoticz.time.matchesRule('at 22:00-23:30')) then
                       if (domoticz.time.matchesRule('at 23:30-00:00')) then
                            domoticz.devices(WhiteLamp).dimTo(1)
                       if (domoticz.time.matchesRule('at 06:00-10:00 on sat, sun')) then
                       if (domoticz.time.matchesRule('at 10:00-22:00 on sat, sun')) then
                if (RGBGateway.state == 'Off') then
                       if (domoticz.time.matchesRule('at 00:00-06:00')) then
                           NightMode = 'curl -s '..'"'..url..'"'..' &'
                           os.execute(NightMode)
dannybloe
Re: first steps
Post by dannybloe »
Ah okay I get it.
bing69
Re: first steps
Post by bing69 »
I get on my way slowly. Have already made various scripts and blocky's.
Pushover also works but I have a question about how I get telegram (bone) method working.
Does this work in the same way as in SH?
curl --data chat_id=19959367 --data-urlencode "text=Some complex text $25 78%" "https://api.telegram.org/bot_mijn code/sendMessage?chat_id=Mijn_id&text=Er is aangebeld!"
dannybloe
Re: first steps
Post by dannybloe »
Please start a seperate topic for this.
