How can i get last state of device ?
landaisbenj
Domoticz version: stable
Post by landaisbenj »
Hello.
I seek on french board, but we don't find a solution for my need.
I want to return last state of a device, and no lastupdate...
Like devicechanged table indicating the new state for the device that triggered the device event, can we have a table who contain last state ?
Because if i have a device who juste update to on and on and on and on, i can't do a notif for the first on without having 4 notif.
Platforme: Rpbi3b
Domoticz: Last stable
Bridge: RFLINK last stable
zicht
Domoticz version: 2023.1+
Re: How can i get last state of device ?
Post by zicht »
You Can do a check with Otherdevices['devicenname']
so to avoid what you write :
if (otherdevices['yourdevicename'] == 'On') then commandArray['yourdevicename']='Off' end
this would only change to off if current state is on
I agree i observed also :
There are sometimes conditions by timing that the script is fired again before commandarray has finished last action so other devices is still on off in the table. But i can live with that as it is not so often that happens (DB update or externa scripts running are causes)
landaisbenj
zicht wrote: Saturday 12 August 2017 10:42
Yes but if my device send a 'on' signal three time ago, commandarray as send 3 time ago too (if i check devicechanged)...
I want to send a commandarray just on the first 'on'...
Platforme: Rpbi3b
jannl
Domoticz version: 2022.2
Post by jannl »
I think you could use a dummy switch which you set to on the first time only
Egregius
Domoticz version: v2024.7
Post by Egregius »
In pass2php I store all states in php caches. That way I can compare the new state with the previous state.
landaisbenj
Thank you. i look at this
Platforme: Rpbi3b
lonebaggie
Post by lonebaggie »
I have written a universal LUA script to link switches together
viewtopic.php?f=38&t=19217
One of the options is to update a User variable ( it can trigger it as well ) with pre-set info
45||19|USwith %n% triggered at %t%
will set User Variable with Idx 19 with "Switch Hall Lights triggered at 12:45:10" when switch 45 triggered. This will also trigger any User variable scripts
Does this help ?
