I have Domoticz running for quite a while now. Recently I have added an RFXCOM tranceiver to my system. It already controls an Action Doorbell perfectly. But now I'm trying to add a few AMST-606 door contacts with mixed results. I add the contacts with the "Learn" button, then opening the contact.
The first contact I added worked for 2 "switches" and then stopped working. I removed the contact from Domoticz, removed the battery and tried again. Since then, this contact is functioning. I want to add another 4 contacts in the same way as the other, but they will not add.
I get messages like "already in use by Bewegingssensor Woonkamer", but for most of the time I only get a Time-out.
Am I doing something wrong? Can you guys help me with some directions how to add my other door contacts?
Regards, Martijn
AMST-606 Door contacts
b_weijenberg
- Target OS: -
Re: AMST-606 Door contacts
Try with only the AC protocol enabled and check if the sensors are correct received.
RFX-433, RFX-433EMC, RFX-868
mvisser
I've just tried, it doesn't fix my problem... Also did a firmware upgrade to ext2 /1020 after that, which didn't help either. I did get one more message "Already in use...", but that is a Philips Hue device. The other devices it mentioned are also Philips Hue devices, the only other 433 mhz device I've got is a Doorbell chime...
b_weijenberg
- Target OS: -
Please check with RFXmngr if the sensor is correct received with only the AC protocol enabled.
The timers are not enabled in the sensors?
mvisser
Timers are disabled, I only receive data from the working door contact in RFXmngr. The other 2, which I took from the packaging this morning don't show data...
mvisser
I just replaced the batteries with the ones that came with my cheapo door chime from Action, and presto, the door contacts work... So the KaKu batteries have worked for 1 minute, nice quality. Thanks for your help b_weijenberg!
