So, now my puzzle:
Due to the fact, that The Netherlands, are up north on the map, during summer, the sunrise is very early. And I mean, during high summer, even around 5:15 (21st of June). I do use a twilight sensor to switch on/off stuff in and around the house. Works like a charm. But, this works nice in end may, june and beginning of Juli.
Now, here it comes: I want to write a script, that does the following:
Switch on the lights in the bedroom in between 04:45 and 05:10, when it is still dark. Then, switch on the lights in the living room and kitchen in between 05:20 and 05:35. But don't do the latter (livingroom and kitchen) after either sunrise, or the twilight sensor detected light. In other words, make a summer proof script. Using the timer will work during fall, winter and spring....
So, can this be done in dzVents? A little help in the form of hints would be very much appreciated!
Update: Figured it out myself. daytime, nighttime.....
Jacco
