Alarm system, forced to disarm
Thomasdc
Post by Thomasdc »
Hi!
I was wondering if this was possible with the security panel in domoticz:
normaly you enter the code to disarm your alarm system.
But is it possible to give an secondary code to disarm the system but also send a notification?
for example
your alarm system is on, but someone forces you to disarm your home..
so that way you could enter an other code then normal an disarm it.
the home will be disarmed but at the same time someone will get a notification that the alarm system was disarmen under force...
an other question about the alarm system that i have:
is it possible to use different "zones"? so one code (dis)arms one zone, an other (dis)arms an other zone?
