Hello all,
I'm trying to set up some (4) zwave devices. The controller (aeon-labs gen2) is set-up properly under domoticz. The zwave switches are included on the controller, and found bij domoticz. There are two neo coolcam powerplugs, one zwave.me switch and one greenwave powerplugs. When I look at the nerwork map, Al devices are connected to id5 (greenwave) but none are connected to id1 (controller). It works kind of, loosing connection pretty often so the switches don't come on or go off again.
What can I try to get things working properly?
Thanks in advance.
no devices connected to controller
mivo
Re: no devices connected to controller
do you try to put Zwave devices near controller ? To eliminate low radio signal issue.
My toys:
Raspberry Pi 3 + UPS PIco HV3.0 A Stack
Minibian (Raspbian Jessie) + Domoticz beta
RFLink 433 Gateway, 1wire DS18B20 temp sensors (GPIO)
RaZberry module + 2x Comet Z-Wave + Z-wave socket
Plugins: WeMo Switch, UPS PIco HV3.0A on GitHub
