OPEN 3 TXT FILE on different server
Mazzokun
Post by Mazzokun »
Hi all! I have 3 Solar inverter and I have a script to read and push to domoticz the data.
This is my script and work
   #!/usr/bin/php
    <?php
       ##### LOGIN SUNWAY INVERTER  #####
    $url = 'http://192.168.0.51/data/inverter.txt';
    $login = 'customer';
    $password = '00000000';
    $ch = curl_init();
    curl_setopt($ch, CURLOPT_URL,$url);
    curl_setopt($ch, CURLOPT_RETURNTRANSFER,1);
    curl_setopt($ch, CURLOPT_HTTPAUTH, CURLAUTH_ANY);
    curl_setopt($ch, CURLOPT_USERPWD, "$login:$password");
    $result = curl_exec($ch);
    curl_close($ch);
      #### ELEBORATING DATA #####
    $results = explode('#', $result);
    $actualPower = filter_var($results[0],FILTER_SANITIZE_NUMBER_FLOAT,FILTER_FLAG_ALLOW_FRACTION);
    $dailyPower = filter_var($results[7],FILTER_SANITIZE_NUMBER_FLOAT,FILTER_FLAG_ALLOW_FRACTION);
    $totalPower = filter_var($results[10],FILTER_SANITIZE_NUMBER_FLOAT,FILTER_FLAG_ALLOW_FRACTION);
      #### WATT TO KWATT #####
    $actualKPower= $actualPower * 1000;
    $dailyKPower=$dailyPower * 1000;
    $totalKPower=$totalPower * 1000;
     ##### STOP AT NIGHT #####
    if (empty($totalPower)) die ;
    ##### PUSH DATA TO DOMOTICZ #####
    file_get_contents( "http://127.0.0.1:8080/json.htm?type=command&param=udevice&idx=79&nvalue=0&svalue={$actualKPower};{$totalKPower}" );
    ### ALL ABOVE WORKS
Now I Have to open the second url and redo the exact procedure ( username and password are the same ) and redo the procedure for the third. But I don't know how. At the end I have to sum the three value and push them to domoticz
    $SumActual = $actualKPower1 + $actualKPower2 + $actualKPower3;
    $SumKTotal = $totalKPower1 + $totalKPower2 + $totalKPower3;
    file_get_contents( "http://127.0.0.1:8080/json.htm?type=command&param=udevice&idx=82&nvalue=0&svalue={$SumActual};{$SumKTotal}” );
But I miss how I can open the second and third url into the same php file. Any help? :)
freijn
Domoticz version: Stable
Re: OPEN 3 TXT FILE on different server
Post by freijn »
Copy the lines between
<?php
and
Then only change ( for the second copy ) The target ip adres in this line.
Then if you want them reported separately
change the target idx= into the correct one
file_get_contents( "http://127.0.0.1:8080/json.htm?type=com ... otalKPower}" );
of first add all up and send it to the 79 idx. Depending on your requirements
Mazzokun
Post by Mazzokun »
Done! works! Thank you :)
#!/usr/bin/php
<?php
 ##### LOGIN SUNWAY INVERTER 1 #####
$login1 = 'customer';
$password1 = '00000000';
$url1 = 'http://192.168.0.51/data/inverter.txt';
$ch1 = curl_init();
curl_setopt($ch1, CURLOPT_URL,$url1);
curl_setopt($ch1, CURLOPT_RETURNTRANSFER,1);
curl_setopt($ch1, CURLOPT_HTTPAUTH, CURLAUTH_ANY);
curl_setopt($ch1, CURLOPT_USERPWD, "$login1:$password1");
$result1 = curl_exec($ch1);
curl_close($ch1);
      #### RIELABORA DATI RICEVUTI#####
$results1 = explode('#', $result1);
$actualPower1 = filter_var($results1[0],FILTER_SANITIZE_NUMBER_FLOAT,FILTER_FLAG_ALLOW_FRACTION);
$dailyPower1 = filter_var($results1[7],FILTER_SANITIZE_NUMBER_FLOAT,FILTER_FLAG_ALLOW_FRACTION);
$totalPower1 = filter_var($results1[10],FILTER_SANITIZE_NUMBER_FLOAT,FILTER_FLAG_ALLOW_FRACTION);
$actualKPower1 = $actualPower1 * 1000;
$dailyKPower1 = $dailyPower1 * 1000;
$totalKPower1 = $totalPower1 * 1000;
       ##### LOGIN SUNWAY INVERTER 2 #####
$login2 = 'customer';
$password2 = '00000000';
$url2 = 'http://192.168.0.52/data/inverter.txt';
$ch2 = curl_init();
curl_setopt($ch2, CURLOPT_URL,$url2);
curl_setopt($ch2, CURLOPT_RETURNTRANSFER,1);
curl_setopt($ch2, CURLOPT_HTTPAUTH, CURLAUTH_ANY);
curl_setopt($ch2, CURLOPT_USERPWD, "$login2:$password2");
$result2 = curl_exec($ch2);
curl_close($ch2);
$results2 = explode('#', $result2);
$actualPower2 = filter_var($results2[0],FILTER_SANITIZE_NUMBER_FLOAT,FILTER_FLAG_ALLOW_FRACTION);
$dailyPower2 = filter_var($results2[7],FILTER_SANITIZE_NUMBER_FLOAT,FILTER_FLAG_ALLOW_FRACTION);
$totalPower2 = filter_var($results2[10],FILTER_SANITIZE_NUMBER_FLOAT,FILTER_FLAG_ALLOW_FRACTION);
$actualKPower2= $actualPower2 * 1000;
$dailyKPower2=$dailyPower2 * 1000;
$totalKPower2=$totalPower2 * 1000;
##### LOGIN SUNWAY INVERTER 3 #####
$login3 = 'customer';
$password3 = '00000000';
$url3 = 'http://192.168.0.53/data/inverter.txt';
$ch3 = curl_init();
curl_setopt($ch3, CURLOPT_URL,$url3);
curl_setopt($ch3, CURLOPT_RETURNTRANSFER,1);
curl_setopt($ch3, CURLOPT_HTTPAUTH, CURLAUTH_ANY);
curl_setopt($ch3, CURLOPT_USERPWD, "$login3:$password3");
$result3 = curl_exec($ch3);
curl_close($ch3);
$results3 = explode('#', $result3);
$actualPower3 = filter_var($results3[0],FILTER_SANITIZE_NUMBER_FLOAT,FILTER_FLAG_ALLOW_FRACTION);
$dailyPower3 = filter_var($results3[7],FILTER_SANITIZE_NUMBER_FLOAT,FILTER_FLAG_ALLOW_FRACTION);
$totalPower3 = filter_var($results3[10],FILTER_SANITIZE_NUMBER_FLOAT,FILTER_FLAG_ALLOW_FRACTION);
$actualKPower3= $actualPower3 * 1000;
$dailyKPower3=$dailyPower3 * 1000;
$totalKPower3=$totalPower3 * 1000;
$SommaActual = $actualKPower1 + $actualKPower2 + $actualKPower3;
$SommaKTotal = $totalKPower1 + $totalKPower2 + $totalKPower3;
file_get_contents( "http://127.0.0.1:8080/json.htm?type=command&param=udevice&idx=83&nvalue=0&svalue={$actualKPower1};{$totalKPower1}" );
file_get_contents( "http://127.0.0.1:8080/json.htm?type=command&param=udevice&idx=84&nvalue=0&svalue={$actualKPower2};{$totalKPower2}" );
file_get_contents( "http://127.0.0.1:8080/json.htm?type=command&param=udevice&idx=85&nvalue=0&svalue={$actualKPower3};{$totalKPower3}" );
file_get_contents( "http://127.0.0.1:8080/json.htm?type=command&param=udevice&idx=86&nvalue=0&svalue={$SommaActual};{$SommaKTotal}" );
file_get_contents( "http://127.0.0.1:8080/json.htm?type=command&param=udevice&idx=22&nvalue=0&svalue={$SommaActual};{$SommaKTotal}" );
