dzVents - how to start / install?
Posted: Tuesday 25 July 2017 16:31
by renerene
If installed the latest beta version Domotic, versions V3.8125.
If have unchecked the box 'disable dzVentz' in settings and added the test script from
https://github.com/dannybloe/dzVents. After saving the test script in the build-in domoticz editor the log shows:
2017-07-25 16:28:28.341 EventSystem: reset all events...
2017-07-25 16:28:28.353 EventSystem: Write file: /home/pi/domoticz/scripts/dzVents/generated_scripts/dzTest.lua
But after switching the dummy switch: nothing.
also adding extra print or domoticz.notify commands don't show in the log
How to start with dzvents? Is it built in, or do have to download anyththing from github?
Other settings to check?
Re: dzVents - how to start / install?
Posted: Tuesday 25 July 2017 16:37
by dannybloe
Hi renerene.
First of all, there's a dzVents sub-forum in the Lua form. Next time you can use that.
Second, check the documentation > getting started (don't use my old github page coz that is old dzVents and has a slightly different syntax).
Documentation
dzVents forum
Posted: Tuesday 25 July 2017 20:03
by renerene
thank you Will put future posts in the correct section.
For now gettin hopeless. 127.0.0.1 is in Local Networks (settings)
1) nog log messages
2) on purpose there is a typo mistake: no syntax error in log
active = true,
'dummy'
execute = function(domoticz, switch)
if (switch.state == 'On') then
prdfsgint ('On')
domoticz.log('Off')
result:
2017-07-25 19:57:50.408 (stroommeter-USB1) P1 Smart Meter (Stroom)
2017-07-25 19:57:55.810 User: hegge30 initiated a switch command (804/dummy/On)
2017-07-25 19:57:57.170 (Dummy) Light/Switch (dummy)
2017-07-25 19:57:57.222 (RFlink) Temp + Humidity (RFLINK-badkamer thermo hygro sensor)
Posted: Tuesday 25 July 2017 20:09
by dannybloe
Did you also mark the script as active using the checkbox 'Event active' in the web editor?
- Screen Shot 2017-07-25 at 20.09.14.png (29.3 KiB) Viewed 2023 times
and
doesn't seem right to me.
Posted: Tuesday 25 July 2017 20:27
by randytsuch
On statement appears to be incorrect
active = true,
devices = {
'Room switch'
execute = function(domoticz, roomSwitch)
if (roomSwitch.state == 'On' and domoticz.devices('Living room').temperature > 18) then
domoticz.devices('Another switch').switchOn()
domoticz.notify('This rocks!',
'Turns out that it is getting warm here',
domoticz.PRIORITY_LOW)
Posted: Tuesday 25 July 2017 20:29
by dannybloe
Ah, good catch. Old syntax indeed.
So please read the getting started and watch the getting started video (see dzVents subforum, first post).
Posted: Tuesday 25 July 2017 23:39
by renerene
UPDATE - SOLVED
Yes, it works. My first steps in dzVents.
New questions will be post in correct forum subfolder
active = true,
devices = {'dummy'}
domoticz.log ('Hello???')
domoticz.log ('On')
domoticz.log('Off')
